Need exhaust for 98 S70
    Results 1 to 6 of 6
      Jul 2016
      I've owned 5 Volvos in the past. Several 740s a couple 240s.
      Just picked up a 98 S70 T5 in decent shape to use to commute the 15 miles I drive back and forth to work. It's in decent shape but the exhaust system is pretty beat up and I would like to replace the entire thing right from the turbo to the tail pipe and never worry about it again.
      My google search skills are failing me. What is everyone running for an exhaust? Is there a complete kit out there that I haven't seen yet?
      Picture of the car, because everyone likes pictures...
      Has tons of service history. Tires are brand new, timing belt and associated tensioner, pulleys and water pump were just done 15k miles ago. Interior is slightly beat up.
      I'm looking for a stock, quiet exhaust.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Stock replacement. Its literally the downpipe/cat and then the suitcase muffler and pipes as one piece.
      https://www.fcpeuro.com/products/vol...70-v70-291-221
      2003 V70 T5 - Mystic/Graphite - M56LK - 201k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 292k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      May 2014
      A quick search shows you can also get that part here:
      http://www.eeuroparts.com/Parts/8949...kSwaAsD58P8HAQ
      I just noticed the $19 'handling' (probably to wrap it up for shipment-understandable). This makes it virtually the same price.
      SwedeSpeed.com
      Oct 2013
      I have original downpipe through the suitcase to the rear muffler attachment. Where are you located? Would be willing to give you the part that includes the suitcase if you know how to ship it. Have no use for it myself. The rest,front section, would be $80 plus shipping.
      98 Saffron, titans, two tone seats, jewels, dual tips, rip kit,
      98 t5m, dual exhaust, RN motor, R bumper, pegs
      99 Laser,[I] lifted, push bar, jewels, 3inch exh, s60R motor, manual trans, c70 front/ rear subframes, ARD tune, crappy paint, satelites
      00 Venetain Red, IPD tune, sways, KW coilovers, RIP kit, DO88 IC, ABM's, dual magnaflows
      99 Red v70R, Dual tip, propus rims,
    7. #5
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      You need stock if you want quiet. I'd also consider converting to an angle flange turbo setup while your're at it.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 136k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: COMING SOON! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    8. #6
      Junior Member mattlach's Avatar
      Jun 2013
      Boston, MA
      Would this be the same part for a 2000 non-turbo fwd V70?
    9. Remove Advertisements
