T5 Tires 215 50 17 vs 235 45 17 ??
    Results 1 to 15 of 15
      Junior Member Bigslick's Avatar
      Apr 2015
      Modesto, CA
      Time to replace my crappy Pro-contacts @ 21k miles..
      I noticed a 235/45/17 vs the OEM Standard 215/50/17 I currently have on there..
      Any reason to go with the 235 45 vs the 215 50 ?
      2015 T5 2.5 AWD - IPD Rear Sway - Custom Tint - Aftermarket Rear Spoiler.
      Member
      May 2013
      Near Nashville Tennessee
      Funny you should ask. When we traded our first S60 for our current one, part of the deal was we could keep our 235/45/17's from our old car. The service department was closed when we picked it up so we had to drive on the 215's for a few days, and even my wife noticed the difference. The car was squirrely on the highway and didnt handle as well. Love the slightly wider tires.
      2013 S60 T5 AWD, 100,000+ miles in 14 states, Premier Plus, Beechwood Leather, Climate, BLIS, NJORD Rims Caspian Blue Metallic, Pirelli P7 Cinturato Plus
      Previous: 2017 Nissan 370z Sport, 2009 Audi A4 Quattro 2.0T & 2000 Mitsubishi Eclipse GT
      Member PureDrive07's Avatar
      Jul 2006
      Colonia, NJ
      The 215/50 tires are mounted on 17x7 wheels and the 235/45 tires are mounted on 17x8 wheels. That's why they are so different. We had the 215/50 tire/wheel and it performed great in the rain and snow, but in dry weather and on the highway you could notice the handling was a bit weird if you caught grooves in the roadway.
      Sent from my iPhone 6 Plus using Tapatalk
      2015 V60 T6 AWD R-Design - Passion Red/Off Black [HIS] - Platinum/Tech/Climate/19" IxionII, Polestar Winglets, IPD Catback Exhaust, IPD Rear Sway Bar, 15mm Spacers and KN Filter.
      2019 XC60 T6 AWD Inscription - Crystal White/Charcoal [HERS] - Nappa Leather w/Massage/Advanced/Heated Steering & Rear Seats/Sport Steering Wheel & Charcoal Headliner/20" Wheels
      ​Past: 1994 940Turbo/2004 S40LSE/2007 S60R/2010 Mazda 3/2012 S60RD/2013 S60T5AWD/2016 XC60T6AWD
      SwedeSpeed.com
      Member
      May 2013
      Quote Originally Posted by PureDrive07 View Post
      Forgot to mention this. We kept rims and tires.
    7. #5
      Oct 2013
      Chardon, OH
      Volvo also recommends a steering deflection limiter be installed to prevent the tires from rubbing when you upsize. I believe it slightly increases the turning radius.
      I've had the 215s on the car, and for everyday driving, they are plenty wide. I could see wanting the 235s if you went to the track.
      My plan is to look for sticky summers at the 215 width for every day driving.
    8. #6
      Member Bmo Pete's Avatar
      Mar 2014
      N. Maryland
      Quote Originally Posted by Bigslick View Post
      215's are very skinny for this car. If you want to use the same 17x7 rims, they can handle 225's.
      Rebel Blue, the new red! Intro & Updates Link
      Current
      ’18 V90 T6 AWD R-Design | '18 V90 CC T6 AWD Ocean Race Edition
      '05 CLK55 AMG Vert
      Prior Volvo's
      '15.5 XC60 T6 3.0 ORE Plat | '15 V60 T6 3.0 AWD RD Plat | '15 S60 T6 3.0 RD Plat |’07 S40 T5
    9. #7
      Apr 2015
      Modesto, CA
      Quote Originally Posted by Bmo Pete View Post
      Im on the 17x7.. You saying the 235's are too wide? So do 225s?
    10. #8
      Mar 2014
      N. Maryland
      Yes, on those wheels, I would do a 225/45 or possibly a 235/50 (if fender well clearance), because 235/45-17's on 7" wide rims are too wide in combination with too short of a sidewall, according to accepted standards. You have to take both tire tread width (235) and tire sidewall aspect ratio (45) into account. Too much pinching of the tire by having too narrow of a rim will cause tire sidewall deformation while turning, which makes for poor handling and excessive uneven tread wear, than the tire is designed for.
      Check-out this online calculator to help your decision:
      http://www.tyresizecalculator.com/ty...ize-calculator
      Current
      '05 CLK55 AMG Vert
      Prior Volvo's
    11. #9
      Apr 2015
      Modesto, CA
      This is excellent - thanks Pete.. In case anyone is wondering - going with G-FORCE COMP-2 A/S ..
    12. #10
      Mar 2014
      N. Maryland
      This is excellent - thanks Pete.. In case anyone is wondering - going with [FONT="]G-FORCE COMP-2 A/S .. [/FONT]
      You're welcome! What size did you decide on?
      Current
      '05 CLK55 AMG Vert
      Prior Volvo's
    13. #11
      May 2011
      North Aurora, IL
      I have those tires on my '12 T5 right now (235/45/17). They're quiet for the passengers, but they make a "sticky floor" type of noise outside. Definitely louder for people outside, but the wet traction and steering response has been great! I've put about 5K on them so far with no signs of wear. Definitely a more aggressive looking tire as well. I've lost about 1 MPG from my Pirelli Cinturato P7 AS+ tires that I had on before these.
      Steve
      Current: 2016 Volvo XC60 T6 AWD Platinum
      Bright Silver Metallic exterior, Off-Black interior
      Previous: 2012 Volvo S60 T5
      Vibrant Copper exterior, Beechwood Brown/Off-black interior
      Premium, Climate, and Multimedia Packages; Rear Entertainment, Xenons, PCC, Njord Wheels
    14. #12
      Apr 2015
      Modesto, CA
      Went with 235/45/17 - and SOO MUCH better. They just feel much more stable and responsive..
      Happy with the BF's so far - pretty quiet, very sticky. Overall - highly recommended.
      P.S. - No clearance or rubbing issues.
      P.P.S - The OEM ProContacts lasted 21k miles to the wear bars on two of them and 1/32" on the other two - Mixed spirited driving - dry climate.
    15. #13
      Mar 2014
      N. Maryland
      I still believe that 7" rim is a tad too narrow for those spec tires, so hopefully you won't have any wear issues.
      Current
      '05 CLK55 AMG Vert
      Prior Volvo's
    16. #14
      Apr 2015
      Modesto, CA
      CHecked here:
      http://www.willtheyfit.com/ - no issues
      And talked with the techs there -they think they will be just fine. So we shall see.
    17. #15
      Mar 2014
      N. Maryland
      Cool
      CHecked here:
      This calculator addresses the fender room/wheel and tire location, but not the tire protrusion and angle of that protrusion from the edge of the rim (you can see it in the illustration).
      http://www.willtheyfit.com/index.php...t2=55#isPage=1
      It shouldn't be a problem unless you are a very agressive driver. Also be sure to rotate the tires every 5-7K miles and have the suspension aligned at least once per year.
      Current
      '05 CLK55 AMG Vert
      Prior Volvo's
    18. Remove Advertisements
