1997 850R Wagon - White/Black - 145k
    Results 1 to 33 of 33
      Apr 2006
      DE
      For sale is my 1997 850R Wagon. White exterior, black interior, 145k miles. I am selling this car because I bought a new daily driver. If I did not already have an 850 T5R project car, I would be keeping this one given its rarity and condition.
      VIN: YV1LW5822V2289791
      I am the second owner. I purchased the car from the original owner in 2013 with 104k miles. Clean carfax, no accidents. Carfax shows regular servicing at a local Volvo dealer from new until my ownership. The car was garaged by the original owner, and garaged for 90% of my ownership. I am not a smoker, nor was the original owner.
      The car is stock, aside from a strut bar and a few cosmetic upgrades (rear spoiler, euro rails, sidemarkers, e-code headlight lenses and turn signals, euro wide angle mirrors, HIDs, V70 tail lights, V70 3rd brake light, Pegs, T5-R steering wheel, stainless steel exhaust tip). The seats in the car are from a lower mileage 1998 V70R. I did a charcoal interior swap and prefer the V70R seats because they look cooler and are more comfortable IMO. All power and heated seat functions work as they should. Oil changed every 3k-4k miles with an OEM filter. The car also has a GROM Bluetooth adapter installed so you can stream music through the stock radio and also talk on the phone hands-free.
      Below is an extensive list of everything that has been done to the car since my ownership. All parts used are new OEM Volvo parts unless otherwise indicated. I maintain this car religiously. Of particular note, at 112k the PCV, timing belt, water pump and pulleys were replaced, and at 128k the valve stem seals and RMS were replaced by a Volvo master tech. The underside of the dashboard and mounting tabs are fully rebuilt and reinforced with fiberglass. See my writeup for more details: https://forums.swedespeed.com/showth...50-Dash-Repair. The dashboard is silent.
      This car is an extremely rare find in this color combination and condition. 850s are becoming extremely difficult to find with lower mileage and in good condition, and even more so for T5R/R models. The car is located in Wilmington, DE, 20 mins from the Philly international airport for non-local buyers. The price is $6,000.00. SOLD SOLD SOLD
      Pictures:
      PARTS/MAINTENANCE LIST:
      OEM Rear Spoiler (used) - 106k
      OEM Spoiler Mounting Kit - 106k
      OBX Strut Bar - 106k
      Oil Change - Castrol 10w30 w/ OEM Filter - 107k
      OEM Sachs Front Struts (x2) - 110k
      OEM Spring Seats (x2) - 110k
      OEM Strut Mounts (x2) - 110k
      OEM Endlinks (x2) - 110k
      Bump Stops (x2) - 110k
      OEM Strut Bolts (x4) - 110k
      OEM Outer Tie Rod (right) - 110k
      Alignment, Tires Balanced - 110k
      850 Euro Rails (used) - 110k
      OEM Euro Rail Trim Kit - 110k
      V70 Rain Diverters - 110k
      OEM Front Wiper Blade Kit - 110k
      DDM HID Kit 4500k - 110k
      E-code headlight lenses - 110k
      OEM PCV Kit - 112k
      OEM Timing Belt/Water Pump/Pulleys/Tensioner/Serp Belt - 112k
      OEM Lower Transmission Mount - 112k
      OEM Pegasus Wheels 17x8 (x4) - 112.2k
      General G-MAX AS-03 Tires 215/45/17 (+road hazard) (x4) - 112k
      OEM Oil Cooler Lines (upper + lower) - 113k
      Oil Change - Castrol 10w30 + OEM Filter - 113k
      OEM Lift Gate Striker (on bottom of latch) - 113k
      Replaced Interior Switch Bulbs - 113k
      V70 Rear Upper Tail Lights (used) - 115k
      Clear Sidemarkers - 115k
      OEM Motorsports Badge - 115k
      Oil Change - Castrol 10w30 w/ OEM Filter - 116.7k
      Tires Rotated - 116.7k
      E-code turn signals (Depo) - 117k
      OEM E-code bulb holders (for turn signals) - 117k
      OEM Tailgate Struts (x2) - 117k
      V70 3rd Brake Light (used) - 117k
      V70 3rd Brake Light Relay (used) - 117k
      Sound deadening installed on all doors - 117k
      OEM Front Brake Hoses - 120k
      OEM Rear Brake Pads - 120k
      ATE Rear Brake Rotors - 120k
      Brake Fluid Flush - 120k
      Oil Change - Castrol 10w30 + OEM Filter - 120k
      Tires Rotated - 120k
      OEM Turn Signal Stalk - 120k
      Rear Armrest w/ Cupholders (used) - 123k
      Homelink Visor (used) - 123k
      Oil Change - Castrol 10w30 + OEM Filter - 123k
      OEM V70R Floor Mats - 124k
      OEM Inner Tie Rods (x2) - 124k
      OEM Outer Tie Rod (left) - 124k
      Alignment - 124k
      OEM Spark Plugs - 125k
      Bosch Fuel Filter - 125k
      Heater Core (new improved aftermarket) - 125k
      OEM Heater Core O-rings - 125k
      OEM Exhaust Hanger Hook (and repair kit) - 125k
      Dynomax SS Exhaust Tip 4" - 125k
      OEM Radiator - 126k
      OEM Rad Upper Hose - 126k
      OEM Rad Lower Hose - 126k
      OEM Thermostat - 126k
      OEM Thermostat Bolts - 126k
      OEM Coolant Temp Sensor - 126k
      OEM Reservoir Hose (Upper) - 126k
      Coolant Flush (Volvo Coolant) - 126k
      Tires Rotated - 127.5k
      OEM Distributor Cap - 127.7k
      OEM Distributor Rotor - 127.7k
      OEM Spark Plug Wires - 127.7k
      OEM Rear Cam Seal (behind cam sensor) - 127.7k
      Tki Motorsport - Engine Overhaul: 128.8k
      ---OEM Valve Seals
      ---OEM RMS
      ---OEM Lower Front Engine Mount (under crank)
      ---OEM Turbo Inlet Cooling Hose
      ---OEM Cam Seals (x4)
      ---Oil Change - OEM Oil and OEM Filter
      ---Transmission Oil Replaced OEM Fluid (7 qts)
      ---OEM Fuel Neck Clamps (upper and lower)
      ---Coolant Flush (Volvo Coolant)
      ---OEM Oil Pump Gasket Kit
      Oil Change - Castrol 10w30 + OEM Filter - 131k
      OEM Front Brake Pads - 134k
      ATE Front Brake Rotors - 134k
      OEM Rear Brake Pads - 134k
      Brembo Rear Brake Rotors - 134k
      Oil Change - Castrol 10w30 + OEM Filter - 135k
      OEM Starter Motor - 137k
      OEM Front Wiper Blade Kit - 138.5k
      Oil Change - Castrol 10w30 + OEM Filter - 139k
      Tires Rotated - 139k
      Bosch O2 Sensor (front) - 140.5k
      OEM Battery - 141.5k
      Complete rebuild of dashboard and mounting tabs - 141.5k
      Auto-Down Passenger Window Relay - 141.5k
      ABS Module Rebuilt (Midwest ABS) - 141.7k
      Oil Change - Castrol 10w40 + OEM Filter - 142.5k
      OEM Euro Wide Angle Mirrors (used) - 144k
      OEM Control Arms (x2) - 144k
      Bosch Icon Wiper Blades - 145k
      1995 Yellow 854 T-5R Manual - garage queen: Built 2004 2.3L RN Motor - TKi Motorsport - iPd - EST - AEM - SPM - Koni - BSR - Autometer - HKS - OZ Racing - Garrett - Porsche/Brembo - do88se - Snaab - etc, etc. (My Garage)
      2020 VW Jetta GLI AB - daily driver
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      That's a sharp ride, man. GLWTS.
      Is the yellow an estate? The "my garage" link is dead...
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
      Apr 2006
      DE
      Quote Originally Posted by ZZZZZZZ View Post
      Yellow sedan. Sorry to disappoint
      Fixed the "My garage" link: http://volvospeed.com/vs_forum/colle...olvo-850-t-5r/
      SwedeSpeed.com
      Aug 2005
      Northern MD
      No disappointment. Yellow is yellow. Estate, however...
      This white wagon looks really, really nice. Too bad not manual like the T5R!
      Quote Originally Posted by Oreo931 View Post
    7. #5
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      Nice R wagon
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 117K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 158,000 miles and still near perfect!
    8. #6
      Member maronha's Avatar
      Mar 2008
      WV
      Quote Originally Posted by JRL View Post
      Nice R wagon
      Very! I really do like white. Why is it that I want this. GLWS, it should not take long.
      2006 Sonic V70R GT 152k
      2013 XC90 R Design Electric Silver 53K (The Wife's)
      2015 Silverado High Country 1500 4WD Ruby Metallic 82k
    9. #7
      Nov 2004
      Very nice wagon.
      late 2007 V70R GT, Electric Silver, Nord, - 4C delete with Bilies on stock springs- adjustable rear spring perches 135,xxx
      1995 Olive Green T5-R 855, 220K, everything works except headlight wipers!
      1996 Civic Hatch Yo! Koni/Eibach Pro/ST sway bars/99-00 SI FR brakes/D16y5 lean burn swap(40 mpg going 80 mph!)/DC sports 421 header/2.5" all the way back/Vibrant Reso/magnaflow muffler/s2000 seat and steering wheel/rebuilt transmission/d16Y8 being rebuilt on an engine stand with ported head/ARP yada yada/12lb flywheel/new 75.5mm oem pistons/ported recoated rotors m45 JRSC/Mfactory LSD in a box/water meth setup/220 HP/150 ftlbs is just a kiss away!
    10. #8
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by maronha View Post
      Obviously because you have good taste
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 280k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 141k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    11. #9
      Apr 2006
      DE
      Bump. Pics added. Would only let me include 30 pics in one post. Here are the extras that wouldn't fit in the original post.
    12. #10
      Junior Member whitev70r's Avatar
      Feb 2003
      Vancouver, BC
      This is a collector, very nice!
      05 V70 2.5T Sport Edition, Hilton Tune Stage 1, IPD front strut mount, CX Racing coilovers, 5mm front/10mm rear spacers - current baby.
      98 V70R AWD - Eurosport Tuning Dual Exhaust, lowered on Vogtland with Bilstein Touring, SOLD
      05 V70 2.5T AWD - No mods, got tired of the high rear end sticking up. SOLD
      98 V70 AWD - lowered on TME springs, Koni, IPD ECU, Volvo Dual Exhaust ... RIP
      Summer play vehicle - 09 Suzuki Gladius 650cc
    13. #11
      Apr 2010
      Such a nice wagon, on the wrong coast though. (Sadface)
      05 VR FG Gobi MT
    14. #12
      Jan 2014
      Boston, MA
      New pics look great. You should bring this over to the meet at Annapolis Volvo on Monday, maybe get some extra publicity for it there. (plus I kinda just want to see it )
    15. #13
      Apr 2006
      DE
      Bump.
    16. #14
      Apr 2006
      DE
      SOLD!!
    17. #15
      Aug 2005
      Northern MD
      Good for you! Hope it went to a nice home. Great car.
      SOLD!!
    18. #16
      Mar 2008
      WV
      SOLD!!
      Someone from the forum?
    19. #17
      Apr 2006
      DE
      Sold to a car enthusiast, soon to be Volvo enthusiast. Car will be going to Florida.
    20. #18
      Apr 2006
      DE
      The car is back up for sale, for $1000 more than I sold it and with 25k more miles...
      https://tampa.craigslist.org/pnl/cto/6926432553.html
    21. #19
      Aug 2005
      Northern MD
      "Car is from west coast." You're in Delaware! LOL... unless you recently moved.
    22. #20
      Apr 2006
      DE
      no, this has never been a west coast car. always east coast. first owner was based in MD. then i owned it in DE. then it went to current seller in FL. car was always garaged though, and never had any apparent rust.
    23. #21
      Member Bearclaw's Avatar
      Dec 2007
      Seattle, WA
      Looks like somebody was carrying a bunch of chickens in the way-way-back? Or just a few???
      Vacuum cleaners are very, very difficult to operate
      Barry
      2007 V70R GT, Electric Silver / Nordkap
      2012 XC70 T6,CPO, Black Sapphire/Off-Black, Premier Plus, Climate, Polestar
      2000 V70R, Venetian Red / Two-Tone, with generally working headlight wipers!
      "It's a dirty story 'bout a Volvo man, and his clinging wife doesn't understand..."
    24. #22
      Mar 2008
      WV
      At least it’s bullet proof! Great looking car though.
    25. #23
      Jan 2014
      Boston, MA
      Quote Originally Posted by Bearclaw View Post
      +1 when are they coming out with one I can open from a smartphone app???
    26. #24
      Mar 2019
      richmond
      is yellow t5r sedan for sale?
    27. #25
      Jul 2020
      I'm the current owner! Funny, I stumbled across this thread looking for details on the number of white 855Rs that were made. Engine is currently apart because the PO didn't mention that the heater core was leaking.....had to take the interior apart to clean up, bypassed the heater core, and promptly blew the head gasket after the car cranked a couple times (head got badly warped after the car over-heated from losing all its coolant into the carpet ). found a new head from a '98 v70r, some NA cams, and a 16t. New lifters, full stage 0 etc..should hopefully have it running again in the next week! All the way in California now. made the trip cross-country just fine
    28. #26
      Jun 2010
      West Chester, PA
      nvm
      - Greg
      96 855 R-M - Red/Tan 112k
      2014 XC90 71k Black/Chestnut 71k
      98 V70 T5-M - Blue/Charcoal 201k - SOLD
      96 854 GLT-R - Olive/Tan 132k - SOLD
      2016 GTI DSG PP LP Autobahn 67k
      2013 GLI DSG Autobahn 79k
    29. #27
      Apr 2006
      DE
      Quote Originally Posted by adjasont View Post
      Hey there!
      Sorry to hear that about the engine ... I had the exact same thing happen to one of my volvos. Glad to hear you're fixing her up.
    30. #28
      Feb 2006
      Sonoma County, CA
      Glad to hear your getting it back to the state it should be.
      Post some pictures when you have the chance.
      Sent from my SM-G965U using Tapatalk
    31. #29
      Feb 2006
      Sonoma County, CA
      Hey there!
      You still have the yellow, Adam?
    32. #30
      Apr 2006
      DE
      Quote Originally Posted by ryan850 View Post
      Sure do
      Barely get to drive it though
    33. #31
      Feb 2006
      Sonoma County, CA
      Sure do
      Nice! Why only the occasional drive?
    34. #32
      Jan 2014
      Boston, MA
      story of 2020
    35. #33
      Feb 2006
      Sonoma County, CA
      Quote Originally Posted by JaredR View Post
      story of 2020
      That def true...
      Although, mine had been sitting for all of 2019 so I'll actually be driving it more in 2020.
      I think you'll be on the same plan also .
      Car looks awesome btw. Im sure it puts a huge smile on your face now that you get to drive it.
    36. Remove Advertisements
