Service Light reset procedures for different Volvo's. - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 57 of 57
    1. #36
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: (lady_b_s40)
      Hello, again, MV.
      Your 2001 S40 is a "different" Volvo as it was born out of a marriage (miscarraige?) between Volvo and Mitsubishi.
      Try posting your specific S40 problems here...
      https://forums.swedespeed.com/zeroforum?id=11
      ...then wait just a few minutes for the S40 pro's to jump in with all the good advice.
      George Dill
      Junior Member bullitt210's Avatar
      Oct 2007
      Plano - TX
      Re: Service Light reset procedures for different Volvo's. (MadeInJapan)
      Anyone have info regarding reset procedure on 2007 S80?
    4. #38
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: Service Light reset procedures for different Volvo's. (bullitt210)
      Junior Member pdlv70's Avatar
      Apr 2009
      Would you have this also for the 2008/9 V70?
    7. #40
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: Service Light reset procedures for different Volvo's. (pdlv70)
      Quote, originally posted by pdlv70 »
      Welcome to Swedespeed.
      Do you have the paper copy of the owners manual?
      George Dill
    8. #41
      Nov 2009
      does anyone know how to reset the immobilizer, our S40 is stranded and I want to avoid towing to the dealership if possible.
    9. #42
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Re: Service Light reset procedures for different Volvo's. (harrismsu)
    10. #43
      Sep 2006
      Near Ararat, Victoria, Australia
      Quote, originally posted by MadeInJapan »
      The SRI reset tool applies to '86 and '87 850's as well as '98 S/V/XC/C 70's.
      '86 and '87 850's??????
    11. #44
      Sep 2010
      I have found out on my 2000 s80 t6 turbo that the xc 70 set reset is the same, now i just neeed the reaaly bad for the red triangle to reset check engine reset feature, then maybe my reote will work again the oldest remote is in another town great for me i have two keys but easier if you have the second remote working too. these are quirky cars.
    12. #45
      Junior Member Ken Secor's Avatar
      Dec 2008
      Vermont
      Given the multitude of variations by model, by year, by design parameters required to simply reset the maintenance service light, perhaps someone could provide a matrix of the four or five methods one can actually use to reset that light -and then list the year, model and nuances involved and have something like this: If you are resetting any 1992-2004 model XYZ - use method 2. If a 2006-2010 model ABC or a 2006-2011 model DEF use method 1.
      Assuming there are only a few ways to reset all years and models, one would think dealers would have a factory authored reset procedure "cheat-sheet" for service personnel to refer to so as to reset any year or model?
      If not, someone who has the procedure wriiten don for any and all models might jump in here?
      Given the majority of newer models don't have keys that can be placed in "position I or II" - much of what has been offered as solutions are inappropriate - or worse yet, so convoluted in the procedural description as to confuse, not help.
    13. #46
      Oct 2010
      Seattle Wa
      Arrow My S60R
      Resetting the service light on my 2006 S60R reset was easy, this is how...
      1. Turn key to position one
      2. Press and hold the left knob for odometer reset for three to four seconds
      3. While holding the odometer reset control for the allotted time, turn the key to position two continuing to hold the odometer reset.
      4. The exclamation light will begin to flash, after waiting for four flashes let go of the odometer reset.
      Your light is now off.
      Hope this helps.
      This is for the service warning that appears on your digital information display in the bottom left of your instrument cluster. NOT the check engine light.
    14. #47
      Member HunterBD's Avatar
      Jun 2011
      Bryn Mawr
      This totally worked on my Y2K XCSE. Use the link http://www.gendan.co.uk/article_6.html#volvo_s I reset it my Service Light in about 12 seconds!
    15. #48
      Jul 2009
      Which one of these procedures works for a 2009 S40? I've tried a few of these methods and still can't get it to reset.
    16. #49
      Senior Member
      Aug 2004
      Temple, Texas, USA
      Quote Originally Posted by dg32 View Post
      http://volvospeed.com/volvo_repairs_...ght_reset.html
      George Dill
    17. #50
      Senior Member
      Aug 2004
      Temple, Texas, USA
      For the early S40 from Mitsu...
      Quote Originally Posted by Becca View Post
      This is what my fiance found out for the S40:
      Turn the ignition switch to 1
      Hold down the trip odometer reset button until it flashes 3 times (usually 10-15 seconds).
      Turn key off, wait 1 second, start the engine and you're done.
      George Dill
    18. #51
      Senior Member
      Aug 2004
      Temple, Texas, USA
    19. #52
      Jul 2009
      Quote Originally Posted by gdill2 View Post
      Tried this and still couldn't get it to work. Thanks for the help anyway...
    20. #53
      Senior Member
      Aug 2004
      Temple, Texas, USA
    21. #54
      Senior Member
      Aug 2004
      Temple, Texas, USA
    22. #55
      Jun 2008
      Works on a 06 XC70 ... but I had to let up on the 4th flash ! .. 5 or more flashes and it was not reset.
      John
      Knoxville TN
      06 V70 R @ 79K
      06 XC70 @ 75K
      87 764TI / 89 765TI / 95 944NA / 96 964 / 96 965 all now else where.
    23. #56
      Its good post and contains good info.
      Graduated from Soran University with First Class Degree with Honours in Computer Science.
    24. #57
      CO USA
      Question 1995 855 turbo service light reset
      http://www.brickboard.com/ARCH...shtml
      BrickBoard Archives
      The files contained in this listing have been automatically archived from the active forums. Because the vast majority of posts are now in one place, this archive is considered legacy. You should use the SEARCH feature OR choose your topic and select date tabs within the forum you choose.
      Service Reminder Light Reset Notes[ALL/1988] posted by Dave Stevens on
      Sunday, 18 January 1998, at 3:55 a.m.
      Based on notes from assorted sources, I've finally tried to come up with a summary of the service reminder light reset methods for various Volvo models and years in the hopes that this might be the last thread on the subject:
      '88-'89 240 (5000mi/8000km) ... lift up reset lever on back of instrument cluster (behind 9 o'clock position on back of speedo); simplest access is by removing under dash panel and reaching up; Hint: lying upside down under the dash with a flashlight may be simplest the first time
      '90-on 240, '87 760, '87-'90 740/780 (5000mi/8000km) ... push in reset button on back of instrument cluster (behind and just above rightmost idiot light); 240 access can either be from under dash as above or by removing instrument cluster; 740/760 with air bags (SRS knee bolster) requires removal of instrument cluster to access; Hint: carefully slide plastic covers off to reveal instrument cluster mounting screws; Caution: when removing instrument cluster do not pull on wires connected to fragile circuit board on back
      '88-on 760, '89-on 740/940 with old-style OBD(I) system (5000mi/8000km) ... push in reset button behind rubber grommet on face of instrument cluster (lower left); Caution: when replacing rubber grommet do not poke all the way through the hole into no man's land (subtract one Brick Badge point)
      '92-'95 850 with old-style OBD(I) system (9300mi/1500km, 12months or 750hrs) ... with ignition on, reset at diagnostic unit under hood (right side forward) using push button to enter function code 4 then reset code 1-5-1 (morse code style holding button <1sec for each count, pause <1sec between counts, pause 3-5 seconds between digits, pause 5-10 seconds before/after function code)
      '96-on 850/70/90 with new-style OBDII system (9300mi/15000km, 12months or 750hrs) ... reset by going to your nearest Volvo service centre and making a new friend; your new friend will do the reset with a Volvo Scan Tool system tester ($$$$ if you want to buy it) which connects to the interior OBDII diagnostic socket; IPD has an aftermarket reset tool for 850's only (an OBDII compliant connector with Volvo 850 reset code), but at U$300 it's pretty expensive for just this one trick; other aftermarket OBDII units (including advertised PC based systems) will normally only be able to perform the basic US-EPA compliant diagnostic functions on a Volvo. EPA standards do not include service reminder reset (this is part of the Volvo proprietary OBDII extended codes and diagnostic procedures). If you have no other choice and feel you have to defeat the OBDII reminder system then do it by removing the warning bulb (subtract 10 points from your Brick Badge).
      up to '87 740/240 ... post-it note on rear view mirror is your service reminder
      up to '74 140 ... putting key in ignition and having all dash lights come on is your service reminder
      up to '68 120/540 ... having oil pressure warning light coming on as you round a corner is your service reminder light; reset by topping up with oil from pan that you keep under your parked car
      Notes:
      -These reset procedures are for the SERVICE warning lamp (time to change the oil) not the CHECK ENGINE lamp (time to consult with your mechanic) which indicates that a possible component failure or unusual running condition has been detected by the EFI computer.
      -The service reminder light will come on for about 2 minutes after starting the engine once the counter reaches the service interval. Actually it starts coming on about 200 miles before the interval as an early warning.
      -240 EGR/LAMBDA service reminder reset (US-California market only?) ... EGR valve (15,000mi) or Lambda Sond oxygen sensor (30,000mi) service reminder lights on 240's so equipped are reset with a push button on the back of the little counter box located above the driver's left knee (there's a short slave speedo cable from it to the back of the instrument cluster); Hint: if you turn your ignition on and there's no EGR or SOND warning lamp then you don't need to know this.
      -Service lights are set for the maximum recommended routine service intervals. When you perform service, remember to reset the counter at the same time whether or not the reminder lamp was coming on.
      If any of the above information is incorrect or incomplete, please add to this thread for future reference. In the literature I've noted a number of inconsistencies in correlating model years to the above. Variations are probably VIN range specific (production date, market code, etc.).
      Re: Service Reminder Light Reset Notes[ALL/1988] posted by Jim Bradley on
      Sunday, 18 January 1998, at 9:53 a.m.
      My '89 780 Turbo w/air bag resets through the rubber grommet hole in the face of the cluster. I don't know if the 6 cyl. is different, but the B230FT uses the procedure described for '88-on 760 and '89-on 740/940. Thanks for compiling this info.
      Re: Service Reminder Light Reset Notes[ALL/1988] posted by MARK H on
      Sunday, 18 January 1998, at 9:26 p.m.
      Thanks Dave Stevens: I know that was alot of work! I prefer the pre 68 method of reseting the light, I used it my self on my 140.Now I own a $300.00 reset tool that has to be sent in every year to be up dated to work on every new model year.I hate it; this is Volvo trying to make customers go back to the dealer. I feel this is going to back fire on Volvo and the dealers.When I was at the dealer as a mechanic I forgot to reset the service light maybe once or twice a week.That is with the reset button right in front of your face. I like the service light reminder but keep it simple. What happen to maintance free low cost services. It is more complicated and expensive to reset the light then doing a oil change. Every customer that comes through the door at my shop wants to know if we can turn this light off.When I say, yes! they fell like they have been unleashed from the dealer. (Dealer loses a customer I gain a customer.)
      Re: Service Reminder Light Reset Notes[ALL/1988] posted by Henry T. Mui on
      Monday, 19 January 1998, at 2:51 p.m.
      Thanks! Dave,
      The 88'-on 760, 89'-on 740/940 with old style OBD (1) system you need to push the button with the engine and ignition system off! Other than that It's all correct!
      Re: Service Reminder Light Reset Notes[ALL/1988] posted by Paul Elliott on
      Thursday, 22 January 1998, at 9:16 a.m.
      I have a '95 850 Turbo, and use the method you list, and is confirmed in both the Haines manual, and Volvo srvc literature...However, my documentation, including owners manual, etc, states that this car *is* fully OBDII, not OBDI as you indicate.
      It has the OBDII port on the console AND has the device at the front right
      in engine bay. Is this normal?
      Can I use the one under the hood to reset the light?
      tia
      ~Roo
    25. Remove Advertisements
