Latest Sensus Road Map and Voice Control Update Info - Page 11
    Page 11 of 11 FirstFirst ... 7 8 9 10 11
    Results 351 to 368 of 368
    1. #351
      Junior Member ClarkG's Avatar
      Jun 2016
      Indiana, USA
      Quote Originally Posted by frontgear View Post
      I did mine without any problem, also ExFAT on macOS Catalina. Make sure you use the USB port on the right side and don't plug anything else in the other USB port.
      2016 XC90s only have 1 USB port. I’m guessing there’s an issue with 2016s. Like I said before this isn’t the first time I’ve done these updates so I know what I’m doing.
      2016 XC90 T6-AWD Momentum Plus
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      Quote Originally Posted by ClarkG View Post
      If you had requested the dual port for your MY16 XC90 be installed (at no cost to you as the owner at least in the US), then you would have dual ports - where you would typically use the one bordered in white. There is a TJ for that and multiple threads regarding it.
      With v1293, I found that the USB install will not work while the OTA update for the home region (or any other region) is in progress.
      BTW: My MY16 XC90 has dual USB ports since ~ 2018.
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 02 Jul. 2020 | 46K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
    4. #353
      Junior Member frontgear's Avatar
      Apr 2018
      v1296 for NA is out (since 3/19)
      2018 XC90 T6 AWD Osmium Gray/Amber
      SwedeSpeed.com
      Mar 2017
      Southern California, USA
      Thx
    7. #355
      May 2015
      Twin Cities, MN
      v1300 roadmaps posted 23 April 2020
    8. #356
      Sep 2004
      Is Sensus Update SPA North America version 2.0.0.0 (6.9 MB) the one which works with macOS Catalina?
      Thanks.
      RNB
      Present autos:
      2018 XC90 T6 delivered 8/28/17: Momentum Plus; Convenience; 20" double 5 spoke wheels; Pirelli Scorpion Verde tires changed to Michelin Premier LTX 8,300 miles; heated steering wheel; charcoal leather; luminous sand
      1930 Model A Ford Cabriolet
      Volvo history: 2005 S40; 2005 XC90; 2009 XC90; 2014 XC60; 2018 XC90
    9. #357
      May 2015
      Twin Cities, MN
      Quote Originally Posted by rnb View Post
      Thanks.
      RNB
      I am on my mobile so I cannot see the version or file size. Nonetheless, just go to latest Sensus Roadmap update for MY16+ and MacOS and you should be good to go.
      My file name matches yours. “Sensus_Update_SPA_North_America.dmg”
    10. #358
      Mar 2017
      Quote Originally Posted by Gary-16-Xc90 View Post
      That sounds correct, but it is for the downloader. You download the downloader then run that, and that downloads the gigabytes of map data...
    11. #359
      Sep 2004
      The question is, does "Sensus Update SPA North America version 2.0.0.0" (which is 6.9 MB in size) work with macOS Catalina? Is it the awaited 64 bit program? Previous "Sensus Update SPA North America" programs are 32 bit and will not work with Catalina. Don't want to update my Mac to Catalina until I am sure I can download the Sensus map updates.
      Thanks.
      RNB
      Present autos:
    12. #360
      May 2015
      Twin Cities, MN
      Thanks.
      RNB
      Yes, it absolutely does support 64-bit.
      I am running the latest macOS Catalina. I have had used my MacBook Pro (mid-2012) to download and install roadmaps for at least the last three months.
    13. #361
      Sep 2004
      You're using "Sensus Update SPA North America version 2.0.0.0" for the downloads? If so, thank you.
      RNB
      Present autos:
    14. #362
      May 2015
      Twin Cities, MN
      Thanks.
      RNB
      Yes, the Mac version of the downloader on Volvo’s roadmap webpage absolutely does support 64-bit and runs on Catalina for SPA MY16+.
    15. #363
      May 2015
      Twin Cities, MN
      RNB
      The reference to “version 2.0.0.0” is not something that I see. (edited) The link for download of the installer works and the latest road maps download on Catalina like it should.
      http://sensusupdate.volvocars.com/sp...th_America.dmg
      Last edited by Gary-16-Xc90; 05-06-2020 at 07:29 AM. Reason: Removed ref. to red herring now that I understand
    16. #364
      Junior Member chmax's Avatar
      Aug 2015
      The reference to “version 2.0.0.0” is not something that I see. I think it is a red herring as the link for download of the installer works and the latest road maps download on Catalina like it should.
      @Gary: If you do a "get info" on the program, the version reported is v2.0.0.0 dated january 17 (or something close to it). @rnb: yes, it works on Catalina as already mentioned by Gary and others above.
      current Dec 2019/MY20 XC90 T6 Inscription black with p*
      Past
      - July 2015/MY16 XC90 D5 Inscription amber black with p*
      - MY10 XC60 D5 AWD
    17. #365
      May 2015
      Twin Cities, MN
      Quote Originally Posted by chmax View Post
      Ah, thanks. I had not noticed that.
    18. #366
      Sep 2004
      Thanks to all.
      RNB
      Present autos:
    19. #367
      Junior Member VAVAV's Avatar
      Jan 2019
      Australia
      Did anyone notice any new features with the recent update? I am unable to see any - Australian region.
    20. #368
      Junior Member InvincibleInDN's Avatar
      Aug 2019
      Sydney, Australia
      Quote Originally Posted by VAVAV View Post
      Most of the updates are undermood changes and very less UI changes. There is a Recall fix in it.
      XC90 MY20 Onyx Black T6 Incription * Nappa Leather Perforated Maroon Brown
      Polestar Optimized * Premium Pack * Versatility Pack * Sport Steering Wheel * 21'' 8-Multi Spoke Black Diamond-cut Alloy Wheel *
    21. Remove Advertisements
