T6 (not T8) XC90 and S90 "PARKING CLIMATE" and "PRECONDITIONING" now in climate screen
    Results 1 to 22 of 22
      Junior Member Percy311's Avatar
      Oct 2008
      Hi there...
      Has anyone noticed that NON-HYBRID 90 models after the most recent software update have a PARKING CLIMATE screen swipe option on the climate menu?
      Has anyone verified if this system WORKS on these models?
      Thanks!
      Member phillipu's Avatar
      Nov 2016
      United States
      Quote Originally Posted by Percy311 View Post
      Hi there...
      Thanks!
      I don't see how preconditioning is different from remote start except for the timers. Timers wouldn't be advised for a gas engine parked in a garage. So I hope they don't work.
      Parking climate just blows air around from the engine or outside depending on whether it's cold or hot out but would probably drain the 12v pretty quickly.
      2017 XC90 T8 Inscription
      Member
      Mar 2016
      Westchester NY
      Hi there...
      Thanks!
      Pictures of it? Interested to see
      B9 2017 Audi A4 allroad prestige
      2016 Volvo XC90 momentum Osmium grey
      2017 A4 Allroad P+ W/ Cold weather, warm weather, Florret silver on Charcoal. Loaded (AOA BUYBACK- ——> 2018 Prestige Florret silver full body paint, Warm weather, cold weather, DAP, ROW parts
      2018 XC90 Momentum + Convenience, Air suspension, 21 Inch rims, Bright Silver with Charcoal Leather LOADED VCNA buyback ( From 2016 XC90 Osmium Grey)----
      (2018 XC90 totaled by a driver who rear ended us——-> into 2018 Q7 Florret silver Prestige, DAP, Adaptive chassis , cold weather, tow
      2017 F150 XLT- 3.5/10 Speed- BLIS, Sport appearance Lightning blue
      1946 CJ2A Restore
      SwedeSpeed.com
      Oct 2008
      bump? anyone?
    7. #5
      Nov 2016
      I have it in MY17 and set it up one day for the entire week to precondition and didn't work once the whole week. I really tried it just for the hell of it because I dont really see the difference between remote start as it.
      I programmed the times from my app and I did notice that all the times appeared on the sensus screen but i couldn't get it to work any further than that.
      Also, I can start preconditioning even when not set on timer right from the app, but I get an error message with that too. I just figured it wasn't an option for anything other than T8 and it was just there for maybe future update? Not really sure but definitely does not work for me.
    8. #6
      Sep 2016
      I don't see it. Were your software updated recently?
    9. #7
      Global Moderator Paradox's Avatar
      Oct 2014
      Quote Originally Posted by christopher.moor View Post
      bump? anyone?
      As someone else requested, can you share a pic? I don't see it like others mentioned.
      Currently Own:
      2018 Volvo XC60 Inscription — Replaced my 2016 XC90 First Edition
      2018 Cadillac Escalade ESV Platinum — Replaced my 2017 Audi Q7
    10. #8
      Nov 2016
      Quote Originally Posted by Paradox View Post
      bump? anyone?
      Yes, I'll take couple of pics when I get in the car this morning and share...
    11. #9
      Oct 2014
      Quote Originally Posted by Kh0805 View Post
      Thanks, I'm actually in the car now and on the hvac screen I only get the main screen with fan speed, the auto button etc and a swipe left brings up the rear climate screen. I've got nothing else and had the vehicle updated about 2 months ago so this may be quite a new feature added (?).
      Currently Own:
    12. #10
      Nov 2016
      Not sure if you guys have this in the app, but I have an option to precondition, which I've said it doesn't work, and it also shows the temperature inside the vehicle.
      And this is the error image I get every time precondition starts...
      I'm in Boston, Massachusetts
      Edit with sensus pics
    13. #11
      Feb 2016
      Yorkshire, UK
      Don't know where the OP is located but Preconditioning and Parking Climate have always been there on my UK spec car with the D5 engine (also applies to T6 here) and they both work great. Parking Climate uses residual heat from the engine for up to 20 mins or until there is no heat left or the battery becomes low. Pre-conditioning (when it's cold) uses the 5kW auxiliary fuel-fired heater to pre-warm the engine and heat the cabin to ~20C. I believe the aux heater isn't fitted to US cars? When the cabin temperature is high, pre-conditioning blows external air through the car, again for 20 mins or until the battery becomes low.
    14. #12
      Member
      Mar 2016
      Westchester NY
      Do you have a T8 or T6?
    15. #13
      Junior Member PhatboyC's Avatar
      Jan 2015
      Canada/Ontario
      Since in NA we don't have auxiliary fuel-fired heater, blame our archaic laws, it means Preconditioning and Parking Climate for T5 and T6 doesn't work? If so they should just remove the option in this instance.
      2017 XC90 T5 Momentum Plus, Vision, Convenience, Climate, 7 Amber Seats, 20's, Invisihitch, Polestar
    16. #14
      Nov 2016
      MY17 11/16 build T6 Momentum+ vision, climate, etc
    17. #15
      Member
      Mar 2016
      Westchester NY
      So does how would this work? Lol it doesn't make sense.
      1946 CJ2A Restore
    18. #16
      Nov 2016
      It just simply doesn't work. Ever.
      I can program and set timers all I want to no avail.
    19. #17
      Junior Member NorthXC90's Avatar
      Sep 2016
      Ottawa, Ontario
      I don't have that option on my volvo app... unless you need to set it on sensus first?
    20. #18
      Jan 2015
      Canada/Ontario
      If you have a T5 or T6 don't bother.
    21. #19
      Sep 2016
      Ottawa, Ontario
      But they are talking about T6 models here... and I just got the software update. Unless this only applies to MY17? I just don't understand how the pre-conditioning would work for a non-hybrid...
    22. #20
      Oct 2008
      BUMP? Anyone tried this recently in the USA?
    23. #21
      Junior Member Jake08's Avatar
      Oct 2016
      Illinois USA
      Yes, and it works. And after 3 months of trying, I finally got them to make the app work, too (for me, not sure about everyone else)
      Current: '18 XC90 Inscription, Pine Grey
      Formerly: '16 XC90 Inscription, Osmium Grey, Polestar
    24. #22
      Nov 2016
      Yea mine works now after the iOS app 4.0 update.
    25. Remove Advertisements
