Cargo Area LEDs Installed
    Results 1 to 6 of 6
      Jan 2017
      Got the LEDs installed in the cargo area. Only had the small bulb from the liftgate to light up that area. Now ......... the cargo area is lit up!! And it's bright!! Tucked 'em up just under the trim. Can't see them unless they're on. And one in the storage area.
      Member partridge's Avatar
      Mar 2005
      Maryland
      Where did you tap into for the right side light?
      Current:
      Linnéa: 2017 Osmium Grey XC90 T8 R-Design Vision/Climate/Conv/Air/B&W/Booster
      Deceased:
      Inga: 2004 Titanium Gray/Gobi S60R - Navigation, ipd tune, hood vent, rear window spoiler
      Astrid: 2015.5 Sapphire Black/Nubuck XC60 T6 AWD R-Design Platinum BLIS Climate Polestar
      Oct 2016
      New York
      Quote Originally Posted by KennyE View Post
      Ok, I give... how did you install those lights? They look sweet!
      Happy Motoring, your mileage may vary.
      SwedeSpeed.com
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      What line did you tap into?
      Sent from my SM-G930F using Tapatalk
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
    7. #5
      Jan 2017
      Well, it was easier to post pictures than to run that wire. I snaked it thru the wire channels from the tailgate light itself. I tried tapping the feed inside the left wheel well that goes to the light, but something was reducing the voltage, causing the LEDs to flicker. Running from the tailgate light fixed that. Not sure why, but it did. The lead comes off the light, runs along the OEM wiring and splits to either side of the cargo area. The one in the boot (?) was actually an after thought - it taps into the wires running to the left wheel well. Honestly, it was a lot of hit and miss, took most of an unseasonable warm day.
      Showed it to a guy at work. His reply: 'Looks nice. You know I do custom lighting in cars. Should have asked. Take me about an hour' .......... Argh!!!
    8. #6
      May 2014
      NYC
      That looks factory and spot on. No pun intended.
      How is the new light mounted?
      In my experience when people say they do stuff, yes it may have taking him a lot less time, but the pride and praise you get from the forum members and the fact that you did it much better then he probably would have is a better reward.
      2019 XC60 R-Design - work in progress
      2015 XC60 R-Design - Totaled
      2016 VW GTI - modified
      2005 G35 -modified
    9. Remove Advertisements
