Attention V8 owners who are towing or are planning on towing...
    Results 1 to 5 of 5
      Global Moderator GrecianVolvo's Avatar
      Nov 2001
      Southern California
      I doubt that this has ever been brought up but I would like to make you aware of a special feature that has been programmed into the transmission of the V8 models, so as to not feel something "could" be wrong with your car.
      If you ever install the tow hitch, once the electrical connection is activated (meaning you have plugged your connection from the trailer to the hitch), the acceleration in 1st gear will be slightly reduced. It is a feature that has been specially programmed in the V8 models in order to reduce any accidental wheel spin.
      I would assume that it may come in handy as you are pulling a heavy, and partially submerged, trailer loaded with a boat up a very wet ramp.
      Yannis
      2001 Volvo V70 T5 M SR, Classic Red/Graphite Lthr, TME Stage II ECU, 3" Downpipe w/ Cat-back exhaust MTE, Volvo Roadholding & Lowering Kit w/ Nivomats, 17" PEGASUS, Rear Spoiler, Dolby Surround Sound
      2019 V90 Cross Country Osmium Grey metallic w/ Charcoal Nappa L, Advance, Rear Air Suspension, Bowers & Wilkins, Luxury, RtrbleTow Hitch, Polestar optimization, 20" wheels, Side Scuff Plate
      2020 V90 T6 AWD R-design Crystal White M, Advanced, Heated Seats/Steering, 20" wheels, Polestar optimization
      Junior Member david's Avatar
      May 2004
      Re: Attention V8 owners who are towing or are planning on towing... (GrecianVolvo)
      Thanks for the heads up!
      Junior Member kowalcs's Avatar
      Jun 2004
      I wonder how this would affect trying to get my snowmobile trailer up a steep, snowy/icy driveway? Sometimes, wheel speed helps in situations like that. I guess I could always just unplug the harness and see the difference.
      SwedeSpeed.com
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Re: Attention V8 owners who are towing or are planning on towing... (kowalcs)
      Or you could just turn off DSTC spin control wth the button.
      BTW, doesn't the presence of a trailer change the AWD behavior? The XC90 sales literature for all years/models seems to indicate it biases the rear a little more.
      Tom.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    7. #5
      May 2004
      Quote, originally posted by GrecianVolvo »
      Yannis
      This condition will only occur if you get the software download. The software will also turn off the parktronic when a trailer is plugged in.
      2015.5 XC70 Platinum T6, Polestar, Heico Suspension, IPD Swaybar, IPD Skid plate, BBS SR wheels || 2013 BMW X5M || 2013 F150 Platinum
      Past Volvos: 2003 XC70 || 2004 V70R || 2005 XC90 V8 || 2005 XC70
    8. Remove Advertisements
