Trailer module wiring
    Results 1 to 15 of 15
      Junior Member tunedxc60's Avatar
      Oct 2016
      USA
      Hi guys! I just bought the trailer module and 7 pin wiring from the dealer and expected to simply hook this up and code the module with VIDA. Issue is I am not finding the factory wiring that goes from the vehicle harness to the trailer module. I expected it to be laying in the drivers side cargo fuse box area. Can anyone shed some light on this - pictures, details? This is on a 2016 XC60 so I expected the car to already be pre-wired... Hmmm...
      2018 XC90 T6 Inscription - Polestar tune + Racechip GTS, and Stealth Hitch
      2011 C30 (Ex K-Pax Racing)
      SOLD: 2016 XC60 T6 AWD Platinum/Inscription - Full bolt ons (Snabb air intake & turbo pipe, Do88 Intercooler, Viva Hybrid Turbo, Ferrita downpipe, IPD exhaust catback, H&R Springs), Stage 3 Hilton Tune: Dual JL Audio 10" stealth subs & 750Watt amp
      Jan 2011
      Arizona
      Driver side cargo fuse box area is correct. Normally, the connector would be wrapped in a grey, foam type material in that vicinity.
      2007 S40 T5
      Oct 2016
      USA
      Quote Originally Posted by qaz996 View Post
      Thank you! Found it. I now have the full Volvo factory wiring hooked up.
      Here's the instructions:
      http://accessories.volvocars.com/en-.../2016/3.0%20T6
      Here's the parts I bought for my 2016 XC60:
      1. Trailer module: Part # 31407107 Cost: $137.93
      2. Trailer wiring (between module and trailer - 4/7 Pin) - Part # 31346065 Cost: $91.35
      3. Software to enable the trailer module and turn on vehicle's trailer stability assist (through VIDA): 4/7 Pin Application USA Part # 31350004 Cost: 28.68
      4. 3-Day Subscription to VIDA (online version): $72.00
      Notes:
      Physical installation was a breeze once I got the tip on where to find the wiring (it was all taped up), be sure to hook up the ground included with the trailer wiring because the module uses it as a ground to power itself up.
      Programming the module with VIDA was definitely more difficult than it should have been. When you read out the vehicle VIDA won't find the module. It will display as grayed out - don't worry it doesn't mean it isn't hooked up. You have to go into the parts section of VIDA and order the 31350004 application and load it on the vehicle. Once you load it, and re-read the vehicle the module will display green. Don't do what I did by accident and order the TRM reload software since it was like $68, and not necessary. You just need to get the 4/7 application and it will code the entire module.
      I haven't actually installed the hitch yet, but I have a draw-tite/hidden hitch from e-trailer sitting in my garage waiting for me to get time to install it. My plan is to use the hitch for my Yakima dual bike rack. My wife and I were considering buying a lightweight travel trailer, but due to the difficulty in finding a quality model that meets our wants, we will likely buy a bigger 1/2 ton truck or larger SUV to handle that task. Knowing I have the wiring ready to go, though, is good peace of mind should I ever want to occasionally pull a utility trailer that requires the 7 pin connector for trailer brakes. This is something that the usual kits with the 4 way flat connector won't do. I also bought the Prodigy RF brake controller and anti-sway/equalizer weight distribution hitch that I'll need to decide whether to use or sell.
      Here are some pictures:
      These are the two wires that were taped up in foam within the drivers side cargo fuse box area.
      The 2nd photo is after I untaped the bundle from the harness.
      I missed them originally since they were taped tightly to the wiring harness that goes to the fuse box:
      Here's where the included 40 amp fuse goes:
      Here's the installation of the module before I hooked up the final trailer cable. You'll have the cut the foam to separate the two cables. When this is installed, the cables are a pretty tight fit, so be careful not to allow too much stress on the wires.
      Nov 2002
      Russell Twp, OH
      Wow, thanks for posting. I may be starting this project as well as we are starting to look for a lightweight trailer. I already installed the hitch last year for the bike rack. I need to make sure I have the right kind of hitch.
      If you don't mind my asking, which trailers did you look at?
      Oct 2016
      USA
      Quote Originally Posted by Wayne T5 View Post
      We were really focusing on staying under 3500 lbs and 350 of tongue weight. It was tough to do this but we did find a few... We found the Forest River R-Pod 180, Kz Escape, Kz Spree 200s, Coachman Apex Nano, Lance 1575, Sonic Light 167 VMS.
      Hope this might help!
      Junior Member BellevilleV70's Avatar
      Mar 2006
      Belleville,Ontario
      Great post! So you were able to get a 3 day sub. and flash it with a clone dice?
      2002 V70 2.4T - EST exhaust/Elbrus 18x8s/Conti DW/Eibach/Koni FSD/Polk Audio/Boston Acoustics/Infinity -beater duty now
      2013 XC60 T6R-design- IPD exhaust- Ice White
      2015.5 V60 Polestar- Black- do88/TDI/GFB/APATuned DownPipe/AirBox Mods/Elevate rear bar [email protected] mph
      Mopar Tech
      Oct 2016
      USA
      Quote Originally Posted by BellevilleV70 View Post
      Yes.
      Mar 2006
      Belleville,Ontario
      Interesting.....thats nice to know!
      Mopar Tech
      Feb 2018
      When you purchased the new module in VIDA, were you able to do it directly with the 3 day subscription? Or did you have to also contact a dealer? I've reached out to a couple local dealers and they haven't been receptive to helping me install new software.
      Oct 2016
      USA
      Did it myself, no dealer necessary. It would be good though to be fairly tech savvy and have some patience. At the end of the day if that is intimidating and likely to test out your patience it would be easier to go to the dealer.
      Feb 2018
      Awesome, thanks for the info. I'm more comfortable with computers than I am with cars, so I'm going to give it a shot!
      Hello tunedxc60,
      Have a question, please: I've installed the Volvo OEM trailer wiring and module to my 2016 XC90 T8 and am surprised to find trailer brake and turn signal lights don't work. I thought those lights would work even without the VIDA software update 31350004 application that you write about above as that update I assumed was only to integrate the electronic trailer brake and stability functions. So, apparently, I need to install 31350004 application to get basic turn signals and brake lights working and so I've been trying to learn my way around the VIDA.
      I can't seem to find where 31350004 application is listed in VIDA to purchase. Does one first need to purchase the 3 day subscription and then when that subscription is activated I would be able to find a pull down menu item allowing one to purchase the 31350004 application?
      I'd rather not purchase and activate the 3 day subscription until I know how to go about buying the 31350004 application.
      Your advice is appreciated as your write up above on VIDA on this topic is the best I've found on the web.
      BTW, I would like to connect a wired trailer brake controller. Do you know if the XC90 has a connector for a wired trailer brake controller in under the dash somewhere? I asked a Stealth Hitch person but he didn't know.
      Cheers
      Craig
      Oct 2016
      USA
      The previous model p3 platform based XC60 is a completely different animal than the newer SPA based XC90 and XC60.
      Even though they both use VIDA for diagnostics and programming I was not successful and had to have the dealer load the software for the XC90. I believe I highlighted that in another thread where I thought I could do it as easily as in the XC60 p3 thread.
      With that being said for the newer XC90 I would do the install yourself and pay the dealer the $125-150 to do the programming. I spent multiple days trying to do it myself using 3 day vida subscriptions and was able to purchase the trailer module software but could not get the software to load correctly on the vehicle. By the time you pay for the 3 day subscription (about $75$) and software (believe it was like $40) you’re almost spending the same. And this assumes you’re using a DICE unit that you already have and paid for.
      Also the XC90 or any Volvo as far as I know has no wiring for a trailer brake controller. If you wanted one I’d go with a Tekonsha Prodigy wireless controller.
      Link:
      Tekonsha 90250 Prodigy RF Electronic Brake Control https://www.amazon.com/dp/B001P0ZA86..._LdqxCbA8DQ6YT
      One thing I learned also is the DICE unit is not really the preferred method to use on SPA based cars anyway. If you’re going deep into this you’d want the custom Volvo (or OEM) Ethernet to OBD2 port interface instead. The amount of data being transferred on the newer car platforms is by far greater than precious generations and the speed of the interface is almost a must have.
      Good luck.
      Mar 2017
      I'm getting ready to add the trailer wiring to my 2015 XC60. What version of VIDA did you use, 2014?
      Thanks,
      Chad
      Oct 2016
      USA
      The online version. Requires a 3 day subscription.
    18. Remove Advertisements
