Best mod under $500/Best single mod
    Results 1 to 20 of 20
      Jul 2005
      I know this is hard... BUT... If you could only do 1 mod, and you could only spend less than $500, what would it be? If you could only do 1 mod and money wasn't an issue, what would it be? I'm trying to convice the fiancee that the car NEEDS mods.
      Senior Member
      Sep 2004
      Re: Best mod under $500/Best single mod (shotdisc98)
      Someone asked this once before, although their cap was $1000 (better for you, maybe not for the g/f!). That thread is here -- should give you some ideas.
      Senior Member
      Nov 2004
      Either lowering springs or a custom grill
      SwedeSpeed.com
      Senior Member AS40's Avatar
      Jun 2004
      Re: (BigT)
      I think a new grille would be a waste of money if you're on a limited budget. As far as I know, they're running around $300, and in my opinion, the stock eggcrate grille looks great. Some suspension modifications will give you a lot of bang for your buck, as well as chipping it or going with the BSR PPC for a little more money.
    7. #5
      Jul 2005
      Now the hard part... I'm a bit of a novice when it comes to this stuff. I don't really want a shop to do it b/c of cost. Is there an easier/best way to go solution? I have the sport package; is there much more to do with that?
    8. #6
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Quote, originally posted by shotdisc98 »
      Tires. At $500 you have a $125/wheel budget. Some Michelin PS2's maybe.
      Or are you talking about bling.
      Tom.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    9. #7
      Senior Member sierraV50's Avatar
      Jun 2005
      Re: Best mod under $500/Best single mod (tmtalpey)
      I'd like to ask the same Q as the OP.
      For non-bling, I was thinking sway-bars + strut tower brace.
      Thoughts?
      -Chris
    10. #8
      Jun 2004
      Eastern MA
      Re: Best mod under $500/Best single mod (sierraV50)
      Rear bar + strut tower brace is a good one. Front bar is less important (after upping the rear), and a lot harder to install. And, that leaves a couple hundred.
      I still say tires, though...
      Tom.
      2016 XC60 T6 AWD
    11. #9
      Nov 2018
      Minnesota
      iPd anti sway bar elimanted lean on my c70. Bolted in most neatly.
    12. #10
      Sorry, gonna disagree with everyone here - get the most bang for your buck -
      DO88 IC and Silicone coolant hoses.
      Get the best of long term ownership with best gas mileage/power and eliminate the worry of the coolant hose split.
      1996 HD Electra Glide - Big Bertha - 10:1 Wisecos; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
    13. #11
      Under 500???? Meth Injection. Sky’s the limit???? Have the motor built.
    14. #12
      Member evy0311's Avatar
      Aug 2016
      Ohio, USA
      For the 2.4i since performance mods are out of the question, I’d say lighting. Upgrading the low beams to HIDs properly and even adding in better high beam bulbs make a huge difference. Doing the full LED conversion is also awesome and makes the car look and feel more modern, and can be done for well under 500$.
      I also run an led light bar and two led flood lights for backroads driving at night. Huge difference.
      2006 S40 2.4i FWD
    15. #13
      Member beachnut's Avatar
      Jan 2004
      SW Florida
      Holy thread bump batman! lol
      My .02 ... sport pedals, they look cool and they're grippy , wont even cost $500
      2015.5 XC60 T6 Flamenco Red/Sand, Platinum, Tech, Blis - wifemobile
      2010 S80 T6 Silver/Anthracite, Dynaudio/Nav, Climate, Blis - my dd
      2005 S40 T5 Passion Red/Quartz, Dynamic Package, E46 bixenon retro - garage queen
      2005 S60 2.5T Black/Graphite, Premium, Sport, Climate - son
      Previous: '05 S60 T5, '04 S80 2.5T, '98 V70 T5, '96 854 Platinum
    16. #14
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      Tune. Even a stage 1 with no bolt ins gets you some excitement.
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
    17. #15
      Jun 2020
      Denver
      Tune!
    18. #16
      Quote Originally Posted by shotdisc98 View Post
      The car definitely needs mods. Most people go for noticeable power adder mods first because its something you “notice”. If you go the tubing route, go with Hilton. Under $500. Go crazy—-!
    19. #17
      Junior Member Leo Kalme's Avatar
      Jul 2015
      Since this post is 15 years old, I suppose he has gone beyond ownership of this vehicle already.
    20. #18
      Aug 2016
      Ohio, USA
      Quote Originally Posted by Leo Kalme View Post
      Maybe, but regardless it’s still good for other users to see people’s thoughts (new buyers etc).
      2006 S40 2.4i FWD
    21. #19
      Mar 2014
      Valley Of VA
      Single mod under $500
      iPd aluminum tray to protect under the engine. Add the mod of your choice with the rest of your budget; recommend iPd rear sway bar.
      686Sport
      Quote Originally Posted by evy0311 View Post
      2008 V50 T5 awd / 2013 GC Overland / 2009 R1200RT [sold] / 2000 Tacoma TRD
    22. #20
      Quote Originally Posted by 686Sport View Post
      686Sport
      If you use the iPd sway-buy Elevates bushes/brackets because they have grease zerks.
    23. Remove Advertisements
