2000 V70R Revival - Deer Dancer - Page 2
    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 36 to 70 of 161
    1. #36
      Junior Member kampman's Avatar
      Jan 2013
      Columbus, Ohio
      Yep, but nothing sets me to overthinking stuff like a broken car in the driveway.
      1966 220/dormant project
      1984 245 Turbo/105K
      2006 V50 T5M AWD/151K
      Jan 2013
      Columbus, Ohio
      I bought an alt from Erie expecting a used OEM one and they sent me this Bosch rebuild that can't have more than a few thousand miles on it. Not complaining.
      1984 245 Turbo/105K
    4. #38
      Feb 2017
      Nuenen, Netherlands
      Quote Originally Posted by JaredR View Post
      Skandix has them
      Where exactly?
      Can only find OE version.
      SwedeSpeed.com
      Oct 2017
      Quote Originally Posted by kampman View Post
      Nice man where did u test? Just the battery?
      Verstuurd vanaf mijn SM-G950F met Tapatalk
    7. #40
      Jan 2013
      Columbus, Ohio
      Yeah, that's the voltage at the battery. Before I swapped the alt it wasn't charging at all.
      Since the car can run without draining the battery now I let it idle for a while and tested all of the electrical systems last night. Everything works except the AC, which I haven't hooked back up yet. The tailgate open light stays on with the hatch closed so I guess I'll have to fiddle with the latch. The engine runs really well but the injectors are super noisy - I may need to put a couple pieces of lead tape on the back of the injector cover to make it less resonant since the noise is a lot louder with it installed.
      Still have a lot of odds and ends to deal with but I'm happy with how it's coming along.
      1984 245 Turbo/105K
    8. #41
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Stellar job. Kudos again for saving it, and glad you worked the alternator in, as that would have bummed me out too. JUST get it repaired and then that happens...
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    9. #42
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Greens are obnoxiously loud. Try an aluminum 99 style fuel injector cover
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    10. #43
      Jan 2013
      Columbus, Ohio
      It's already got the aluminum cover. I might try the one from my parts XC and see whether it snaps into place a little better.
      1984 245 Turbo/105K
    11. #44
      Jan 2013
      Columbus, Ohio
      Car popped its first CEL over the weekend, VIDA says ECM-280A (front O2 sensor faulty signal). Hasn't even left the driveway yet. Oh well. ¯\_(ツ)_/¯
      1984 245 Turbo/105K
    12. #45
      Jan 2013
      Columbus, Ohio
      One of the Atlantis got bent a while back and wasn't holding air so I dropped it off at a shop that specializes in repairing and refinishing wheels today. Should have it back tomorrow, hopefully the tire is still good since it sat flat for a bit.
      1984 245 Turbo/105K
    13. #46
      Jan 2013
      Columbus, Ohio
      Got the wheel back, looks round but I guess I'll have to drive the car to be sure.
      Should be able to at least take it around the block tonight - I just need to top up the trans fluid since it lost a little from swapping the rad.
      1984 245 Turbo/105K
    14. #47
      Jan 2013
      Columbus, Ohio
      I didn't get a before pic of the wheel but here's the after, they did a great job getting the bend out but I didn't realize it was going to leave such an obvious mark. Not gonna sweat it since no one's going to see it with the wheel on the car.
      I installed the wheel and took it up and down the block, not gonna drive it further until it's legal but it moves under its own power and it seems to drive OK. It has all the usual P80 squeaks and rattles. The brakes are really rusty from sitting, I'll probably have to freshen them up before I put some real miles on it. Trans seems to shift OK but I couldn't really tell anything conclusive considering the short distance I drove it.
      Horrid pic:
      One other concern I have is with the fuel line that feeds the rail. It looks like someone cut it or broke it and spliced in a section of hose. The hose rubs on the corner of the fuel rail so this probably would have worn through eventually - if this car hadn't met a deer it probably would have become a carbecue at some point. Gonna swap it out for a replacement hard line ASAP, hopefully I don't have to disassemble the entire front of the engine to replace it.
      1984 245 Turbo/105K
    15. #48
      Junior Member 98v70t5man's Avatar
      Jul 2013
      WA
      The 850 and ‘98 uses a short section of rubber elbow hose like this from the factory. Can’t confirm for ‘99-‘04, but speaking to the earlier ones, you can get by with a straight piece of bulk hose cut to size, but it’s not great. Get the OE part....or.....find the HELP(r) brand section in oreilly/checker/kragen stores or online and you’ll find a 90 degree elbow that fits perfectly. Check your hose ID to confirm.
      -Paul
      1998 OSD V70 T5M | M56H | Signal Red(601)/Tan(3960) | IPD susp | ARD Custom Tune | Delrin subframe bushings | Propus
    16. #49
      Dec 2014
      Connecticut
      That should be a hard line all the way to the back of the block. Suspect that someone previously didnt know there was a release and cut it to do the PCV.
    17. #50
      Oct 2017
      Good glad the wheel is ok.
      When do u plan driving it? For my AWD r 98 it's going to be march.
      I need to check the whole airco system. It only works at 15 celcius or below
      Sent from my SM-G950F using Tapatalk
    18. #51
      Jan 2013
      Columbus, Ohio
      Not sure when I'll be driving it yet, I want to replace that fuel line first but I'm not going to have any time until after Thanksgiving.
      I went on vacation for a few days at the end of last week but before I left I got rid of my XC. Kinda bummed about it but it had 250K on it and a ton of problems. I owned it for more than 5 years, it's the longest I've held on to any Volvo. I didn't get much for it from the yard but having the parking space back and one less car on my insurance kind of makes up for it.
      1984 245 Turbo/105K
    19. #52
      Jan 2013
      Columbus, Ohio
      The last few weeks have been pretty crazy but I had some downtime and good weather last weekend so I replaced the front O2 sensor and the spark plugs. The last time I was messing with the car it popped a CEL for a missing/faulty signal from the front sensor and the one that was in there was a no-name parts-store special. It runs noticeably better with the new Bosch I installed. As for the plugs, the old ones weren't in bad shape but I always like having that peace of mind with whiteblocks and the replacements I got (Bosch FR7DPP+) appear to be exactly the same as OE Volvo except for the branding and the price (about $3.50/ea from Rockauto).
      I have the rest of the year off work so I'm going to make some time to take care of the last few things it needs to drive to the inspection station. Hopefully I'll be able to get it inspected in January.
      1984 245 Turbo/105K
    20. #53
      Jan 2013
      Columbus, Ohio
      We're forecast to have temps above freezing next week so I'm planning to address the fuel line if it warms up enough. I wish I was making more progress with this thing but it lives in the carport so I'm at the mercy of the weather. :/
      1984 245 Turbo/105K
    21. #54
      Jan 2013
      Columbus, Ohio
      Finally got a picture of the car in the sun since I had to park it in the street to change the oil in my V50. I need to tweak the front clip a bit to get the panels lined up better but I'm pretty happy with the paint match between the driver's fender and the rest of the body. I received the fuel line from Tasca last Friday and we're supposed to have warm weather this week so hopefully I'll get it swapped. If I feel really ambitious I might try to take the pinstripes off.
      1984 245 Turbo/105K
    22. #55
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Are your stripes stickers or paint?
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    23. #56
      Jan 2013
      Columbus, Ohio
      They're painted. I'm debating whether to try oven cleaner or lacquer thinner to remove them, since those seem to be the most popular/effective options, but I can't say I'm super excited about putting either of them on the paint, haha.
      1984 245 Turbo/105K
    24. #57
      Jan 2013
      Columbus, Ohio
      I dug in to it tonight to come up with a plan of attack for the fuel line (which is gonna be a total PITA) and found out that the engine isn't original, looks like someone swapped in a junkyard(?) B5234T(8?) at some point. Not sure if I want to keep messing with it or just part it, I feel like the franken-car-ness of it is gonna be a turnoff to people if I try to sell it and I don't need another car that badly.
      1984 245 Turbo/105K
    25. #58
      Jan 2014
      Boston, MA
      If the engine is healthy, I don't see that as an issue at all.
    26. #59
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      I agree, you're pretty close to having it roadworthy and if the motor works...
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    27. #60
      Jan 2013
      Columbus, Ohio
      After sleeping on it I'm probably making a bigger deal of it than it is, it runs fine. Just surprised it wasn't mentioned in the receipts I got.
      1984 245 Turbo/105K
    28. #61
      Dec 2014
      Connecticut
      Wouldn't sweat there being a T5 block in the car whatsoever.
    29. #62
      Member andyb5's Avatar
      Sep 2009
      Troy, NY
      I just finished swapping the B5234T8 and M66 from my old 99 R into my 00 R to replace the B5244T that a PO replaced the factory B5244T2 with.
      I say don't sweat the engine code, most people won't care as long as the car runs properly.
      Also, 3M makes a pinstripe removal wheel for your drill that is supposed to work very well.
      1999 V70 R -- gone, but not forgotten.
      2000 V70 R -- 04 B5234T9 w/ 18T, Stevo tune, M66, CX Racing coilovers, 996TT front BBK. Always working on something...
    30. #63
      Jan 2013
      Columbus, Ohio
      I'm going to keep fixing it, I just need to chill out - the car is nearly 20 years old and stuff happens. Seems like a lot of P80Rs have swapped engines at this point so it's not worth bailing over.
      Since I snapped pics here's the rest of the fuel line "repair," it looks like whoever did the work cut the pipe. There's a receipt for this repair in the folder I got with the car and I can see why a shop would do this since replacing the entire hard line would probably lead to a crazy labor bill, but they could have taken a little more care to protect the hose. In any case I have plenty of time so I'll go ahead and do it right. I'm debating whether I want to do the PCV since I have access to everything and the stuff that's there looks original.
      1984 245 Turbo/105K
    31. #64
      Jan 2013
      Columbus, Ohio
      Swapped the fuel line last night since it was in the 40s. To get access to it, all of the accessories and the bracket had to come out along with the passenger side engine mount. All in all it wasn’t a terrible job but I could have saved a lot of labor if I’d done it when I replaced the alternator.
      1984 245 Turbo/105K
    32. #65
      Jan 2013
      Columbus, Ohio
      Couple pics of the fuel line routing I took:
      1984 245 Turbo/105K
    33. #66
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      Make sure you have the check valve in the banjo fitting by the alternator there. The one for the PCV with the 3 tubes. Keeps from pressurizing the block.
      Part number 31325709.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70 2.5T - Ice White - Oak Arena, (almost) bone stock daily driver.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    34. #67
      Jan 2013
      Columbus, Ohio
      I think I bought one for my olive but never got around to installing it - I'll have to go rummage around in my toolbox and see whether I can find it.
      1984 245 Turbo/105K
    35. #68
      Aug 2009
      Car looks great!!!
    36. #69
      Jan 2013
      Columbus, Ohio
      Thanks!
      Ordered PCV system parts tonight since Tasca had a coupon, I figure I might as well replace it since I have the engine apart and the stuff that's in there is original.
      1984 245 Turbo/105K
    37. #70
      Jan 2013
      Columbus, Ohio
      I found the updated banjo bolt/check valve in my parts stash and I got all the hoses and a new breather from Tasca, just waiting on some hose clamps so that I can knock out the PCV job. I received word last week that I might be getting laid off from my job but I won't know whether I'm affected until 3/5. It won't affect the fate of this project one way or the other, most likely, but I'd like to get the mechanical work it needs wrapped up while I still have some money coming in. If nothing else it has me feeling just a little more motivated than usual, lol.
      1984 245 Turbo/105K
    38. Remove Advertisements
