Custom Information on your DIM - CFE+ - Page 2
    Page 2 of 12 FirstFirst 1 2 3 4 5 6 ... LastLast
    Results 36 to 70 of 399
    1. #36
      Junior Member Basssteakman's Avatar
      Jun 2016
      Fort Dix, NJ
      Quote Originally Posted by volvotech.eu View Post
      Please vote...
      We're currently working on DIM info for MAF.
      Question now is... how to display!
      kg/h ?
      g/s ?
      Or is there a typical imperial value for this?
      CFM (Cubic feet per minute) is a standard SAE measurement for volumetric airflow.
      06 SR Sonicama GT - Hilton 2.5, Snabb intake, RS4 MAF, Billet compressor wheel, FMIC, Plasma Direct coils, and a custom dual exit exhaust. Accepting donations to have the car repainted, previous owner tailgated like an a**hole ...
      Moderator The Driver's Avatar
      Sep 2009
      Huntington, NY
      Finally the 05+ don't get screwed!
      Looking forward to hearing more about this!
      06R Custom Electric Blue Silver
      07R Magic Blue - Sold
      04 Bonatti Gray Rover Disco HSE
      09 Iridium Silver SLK55 AMG P30 Edition
    4. #38
      Sep 2012
      The Netherlands
      Quote Originally Posted by Lekki View Post
      I've ordered the CFE+ from you guys and already had a CFE full connected to a wiring harness to the rear of my RTI, so that the front OBD port is still usable for diagnostics.
      Is it possible to put the cfe+ into the previous wiring harness?
      No. The CFE Plus requires BOTH Canbusses to be available.
      At the RTI you'll have only 1 canbus available.
      The unit can be pulled out in a second, i guess that's fair enough for diagnostic readings?
      (CFE will switch to OFF anyways if its installed in the car and it sees a Dice with Vida!)
      VolvoTech.EU
      Your resource for Volvo Electronics.
      Only the best for your Volvo!
      Please send any personal technical or sales matter to [email protected].
      Please find knowledge base articles on the CFE Plus here.
      SwedeSpeed.com
      Sep 2012
      The Netherlands
      Quote Originally Posted by Basssteakman View Post
      Thanks, we'll consider displaying both.
      VolvoTech.EU
    7. #40
      Sep 2012
      The Netherlands
      Quote Originally Posted by The Driver View Post
      Its available already.
      Working now on getting more and more DIM Info items available.
      VolvoTech.EU
    8. #41
      Sep 2012
      The Netherlands
      Quote Originally Posted by Volvoete View Post
      Nice! Subscribed, waiting for 04 harness!
      What do I have to look for to see if I have the correct oil level sensor? (or was it just 05+?)
      Check the oil-pan below the engine...
      If there's a sensor inserted (most probably left hand side, front) with wires coming out.. you most probably have a sensor.
      So far/until now; if the sensor is there, we're able to make readings.
      VolvoTech.EU
    9. #42
      Sep 2012
      The Netherlands
      Quote Originally Posted by Body Massage View Post
      So this can be hooked into the RTI? Can you still use it hooked into the RTI, if you're not using the stock head unit?
      No. The RTI computer has only 1 Canbus available, the CFE Plus needs both of them.
      In case your car is pre-2005 (so 2001-2004) you'll have to hookup an additional OBD port.
      We're currently in the process of getting those harnesses available.
      (in production)
      VolvoTech.EU
    10. #43
      Jul 2012
      Europe
      I received my unit today and had to do a bit of research in order to get the drivers installed on my Windows 10 PC.
      I found them here:
      https://www.pololu.com/docs/0J7/all#2
      V70 2.4T5 M66 Summum
      Stage 2+ by contrast
    11. #44
      Sep 2012
      The Netherlands
      Hi Ricardo,
      Allow me to suggest using the chipset-suppliers original Windows driver?
      Please see our Knowledgebase / FAQ for more support articles about the CFE Plus.
      The particular topic about the Windows drivers is found there as well!
      VolvoTech.EU
    12. #45
      Dec 2015
      Got mine yesterday, works great.
      Oil temperature works as it should, reads COLD until 60° C, then shows the temperature. It is not a calculated value, there is a ptc resistor in the sensor.
      Also, I would vote for air mass in kg/h cause that is how it is shown in vida for the me7 engines so that is the most useful.
      The free DHL shipping took 4 days from ordering to my doorstep. Much appreciated.
    13. #46
      Jul 2012
      Europe
      Hi Ricardo,
      Hi. I guess I didn't pay enough attention reading your FAQ's...
      Those drivers worked fine and I managed to program the CFE+. Thanks anyway
    14. #47
      Member HunterBD's Avatar
      Jun 2011
      Auburn
      Ordered mine today. Should be here on Monday. Can't beat the free shipping.
      hbd via Tapatalk
      05 VR GT Titanium Grey/Nordakp, sunroof, Winter Package, Premium sound with Volvo Sub. VST rear brace, Ultra Racing front strut brace. iPD Sways and other little upgrades they have. EST DP with Touring Exhaust.
    15. #48
      Sep 2012
      The Netherlands
      Quote Originally Posted by Bcw727 View Post
      Testing in progress.
      (And got confirmed by looking at the values in the DIM that the MAF in the S60 2.5T testcar indeed is out of order).
      VolvoTech.EU
    16. #49
      Sep 2012
      The Netherlands
      New firmware available for download;
      Version 1.085
      Added : MAF for DIM-info
      Fixed : SUM added for some models in DTC
      Fixed : if value unknown/not readable '---' will appear instead of 0 or LOW. (In such case please create a support ticket with details of the particular DIM info item and your car details).
      Next : IAT, Intake Air Temperature, fixes for known items where possible.
      VolvoTech.EU
      Electronic solutions for Volvo's
      Web : www.VolvoTech.eu
      Mail : [email protected]
      VolvoTech.EU
    17. #50
      Jun 2011
      Auburn
      I came home today and it was on the front porch. Updated the firmware and installed.
      Very nice.
      This out of the box without changing any settings.
      Displays the Auto trans temp
      When i reverse it puts the stereo in a telephone mode. Mutes the stereo.
      Opens and closes all the windows when I lock and unlock the doors with the fob.
      Beautiful.
      05 VR Auto.
      hbd via Tapatalk
    18. #51
      Jun 2011
      Auburn
      . Installed and configured for Haldex and Trans Temp. This really is a nice add on for those who don't have pods.
      hbd via Tapatalk
    19. #52
      Sep 2012
      The Netherlands
      Quote Originally Posted by HunterBD View Post
      hbd via Tapatalk
      Did you try multi-info?
      That might be even better in your case; more info in one view!
      VolvoTech.EU
    20. #53
      Jun 2011
      Auburn
      I noticed that when I was plugging through the settings. I would like to add oil temp to the mix and will try those settings when I get home from work. Thanks for the info. This is a great addition to the R.
      hbd via Tapatalk
    21. #54
      Member Hounddogger's Avatar
      Oct 2014
      Northern Hemisphere
      Cannot wait for the 04 harness to become available...
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
    22. #55
      Quote Originally Posted by Hounddogger View Post
      Also waiting for it, already have the CFE+ but its useless without
      FlashCamaSR
      Instagram
    23. #56
      Sep 2012
      The Netherlands
      We have released firmware version 1.099...
      Please see release notes for details!
      VolvoTech.EU
      Mail : [email protected]VolvoTech.eu
      VolvoTech.EU
    24. #57
      Oct 2016
      Victoria BC Canada
      Can the CFE+ be run with an OBD2 splitter/Y cable? I have a Scangauge that plugs into the port at the moment.
      The cable I was looking at: https://www.amazon.ca/Right-Angle-Sp.../dp/B00EEDOWU8
      | 04 V70R Titanium Grey/Nordkap M66 | Hilton Stage 2 | Mototec DP & Touring Exhaust | ERST Springs | Summer Mode: 18" Fast FC04A | Winter Mode: 18" Pegs |
    25. #58
      Sep 2012
      The Netherlands
      Quote Originally Posted by Enraged View Post
      Splitter : should not be a problem, although generally these splitters have no twisted can-wires, which (if canbus is extended) is formally a requirement.
      Scangauge : we have not tested that specific tool. Generally if it just listens on the canbus, it should be fine.
      If that tool sends bits and bytes on the canbus as well, you might get conflicts which will result in behavior we can't predict.
      I do not expect a permanent damage to either one of the tools if something goes wrong, most expected is a shut-down of the CFE Plus or a confused CEM.
      (which then can be cleared again with the CFE Plus ;-)
      VolvoTech.EU
    26. #59
      Sep 2012
      The Netherlands
      You have a V70 R?
      VolvoTech.EU
    27. #60
      Sep 2012
      The Netherlands
      What model/my is your Volvo?
      VolvoTech.EU
    28. #61
      Jul 2012
      Europe
      Can you please elaborate a bit about the multi-info? I've seen it on the DIM but didn't quite understand it.
      Thanks
    29. #62
      Sep 2012
      The Netherlands
      Quote Originally Posted by [email protected] View Post
      Thanks
      Sure;
      Multi-info pushes more DIM Info elements into 1 line.
      CT = Coolant Temp, HT = Haldex Temp, S = speed
      So a multi-info line could look like:
      CT 140 HT 120 S 100
      OT = Oil Temp
      G = Gear
      B = Boost pressure
      etc.
      Maybe you would like a different configuration of a multi-info line, please let us know, we'll consider.
      (now working on a line where HT = out for example since that only brings data to those who own a AWD).
      VolvoTech.EU
    30. #63
      Jun 2011
      Auburn
      How do I add/remove multi-info? I want Oil, Haldex, Trans, air mass, coolant temp and boost. If I am reading it right in the display I should have 3 entries per line. With two lines I can monitor 6 events. Real nice if possible.
      So how can I do this?
      hbd via Tapatalk
    31. #64
      Sep 2012
      The Netherlands
      hbd via Tapatalk
      Hello Hunter,
      We have to pre-configure sets. Currently it is not possible to add your own.
      We’re near the one you like i guess, please checkout the ones already there.
      It might be impossible to get all of them on 2 lines since we’re bound to a certain amount of characters, keeping in mind the digits of the values and a space here and there.
      I’ve noted your request, will have a look soon!
      VolvoTech.EU
      VolvoTech.EU
    32. #65
      Oct 2016
      Victoria BC Canada
      I have an 04 V70R, no navigation if that makes a difference. The scangauge just reads data as far as I know.
    33. #66
      Jul 2012
      Europe
      Sure;
      CT 140 HT 120 S 100
      OT = Oil Temp
      G = Gear
      B = Boost pressure
      etc.
      Cool. Thanks!
    34. #67
      May 2015
      Could you replace the Haldextemp with IAT (Intake Air Temperature) in the multi-info DIM?
    35. #68
      Sep 2012
      The Netherlands
      Quote Originally Posted by brooklands View Post
      We could add a multi-info line with the most probably. Lets see if it fits!
      VolvoTech.EU
      VolvoTech.EU
    36. #69
      Jun 2011
      Auburn
      It's too bad you can't create a blank line that we can add items
      hbd via Tapatalk
    37. #70
      Sep 2012
      The Netherlands
      hbd via Tapatalk
      Maybe as a future function, please understand it would require quite some programming in the Updater Application...
      Its on the list tough!
      VolvoTech.EU
    38. Remove Advertisements
