06 S40 T5 AWD Minimum Wheel Size
    Results 1 to 12 of 12
      Jul 2015
      Hi there,
      I've found an awesome set of Volvo rims locally! But, they are 16". Will that work on my S40 T5 AWD 6 Speed? From research, they are sold with 17" & I am worried about clearing the front brakes.
      Will they work? They're the stock wheels from an S60 I believe.
      Thanks in advance!
      Jul 2015
      Jul 2015
      https://ibb.co/jkUkOk
      Don't know if the link above worked, so repost.
      May 2013
      Colorado
      16" P1 wheels will work. Not sure if that's true with S60 wheels as well.
      2007 S40 T5 AWD
      Jul 2015
      Awesome! Thank you.
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      If you have the larger T5 320mm front rotors clearance will be very, very close. Like paper thin close.
      '10 s40 m66 awd
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
      Oct 2012
      Lembeek, Belgium
      320mm brakes will work with 16x6,5 ET52 steelies, I use those during the winter.
      Don't know about other wheels tho
      Ice White V50 2.4 D5 Progression Thread:
      https://forums.swedespeed.com/showthr...-4-D5-R-Design
      Titanium Grey V50 2.0D Progression Thread:
      https://forums.swedespeed.com/showthr...ression-Thread
      Member LizardOfBodom's Avatar
      Aug 2016
      Rainy Island (aka Ireland)
      Can confirm I had no issues with steel 16' from Focus for few days when I needed to use them. Hovewer make sure to try-fit any different ones as ET may vary.
      also - if your car is programmed for 17', your speedo wont show accurate readout, just so you know.
      Unless you go for higher profile to compensate.
      Titanium Grey 2005 V50, T5AWD, M66, Stage 1 Hilton tune<-Click me
      E-Focus Torque mount, E-46 bi-xenon retrofit (see the PDF for pictures and full story) , de-nanny mod, Brembo discs+ATE ceramic pads
      Oct 2012
      Lembeek, Belgium
      Quote Originally Posted by LizardOfBodom View Post
      Just make sure you use the proper dimension for the rim diameter
      205/55/16
      205/50/17
      215/45/17
      215/40/18
      225/40/18
      are the tires you can mount without worrying about the speedometer.
      Jul 2015
      Thank you all for the replies! Wheels are bought, at a wicked price because they turned out to be replicas. Condition isn't perfect, but no curb damage. It's ok, I planned on painting them anyway.
      Will sell the tires off & recover the cost of the rims.
      My T5 does have the larger brakes, much to my surprise.
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Have you test-fitted them? You may want to - the 320MM calipers are quite close to the inside of a 16" rim, and the offset to the spokes is also tight. My stock Clavas (16") have some marks from snow/ice/road grit that inevitably gets crammed in there during winter driving. Not all 16's will work.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
      Jul 2015
      Just wanted to report that they appear to have been working well! Not looked at the calipers, but seem to be ok.
      Could really use a bit of love, but at $105 CAD if they do a winter they'll be paid for several times over!
    15. Remove Advertisements
