SOLD: 1998 v70 glt
    Results 1 to 4 of 4
      Nov 2014
      Augusta, GA
      SOLD: 1998 v70 glt
      SOLD
      1998 Volvo V70 GLT
      I sadly have to sell my V70 as I am not able to take it with me when I move. The car currently has 185,000 miles and it will go up as it is my daily driver. The car is Nautic blue with a beige interior. I have caught the car up on all of the major maintenance and it is currently not in need of anything. The car does have dents and scratches as it is nearly 20 years old but nothing that is major or deep. The tires have roughly 10K miles on them and I have rotated them regularly.
      I am asking $3,000 or best offer and I am located in Augusta GA.
      Work that I have done/ had done while owning the car:
      Replaced upper motor mount with IPD Poly mount
      Replaced rear hatch struts
      Replaced PCV system with OEM Volvo parts
      Replaced front struts, spring seats, strut mounts
      Replaced front sway bar endlinks
      Replaced rear struts
      Replaced front Brake rotors and pads
      Replaced rear brake pads and rotors
      Replaced rear parking brake shoes and hardware
      Replaced radiator with OEM Volvo radiator
      Replaced coolant expansion tank with OEM Volvo tank
      Replaced thermostat with OEM Volvo thermostat
      Replaced timing belt, belt tensioner, and belt idler
      Replaced serpentine belt
      Replaced water pump with OEM Volvo water pump
      Replaced spark plugs, plug wires, and rotor cap with OEM Volvo parts
      Replaced all the vacuum lines
      Replaced cam position sensor
      Replaced crank position sensor
      Replaced driver front axle
      Replaced turbo compressor bypass valve and spring
      Replaced dashboard with dash from 2004 C70
      Replaced ABS module
      Replaced license plate light lenses
      Parts I have changed/added on the car:
      Enabled the trip computer funtion
      IPD Sport springs
      IPD intermittent wiper relay
      2004 C70 clear headlights
      2004 C70 egg crate grille
      C70 subframe brace
      OEM fog lights with Euro foglight mod
      Rear OEM spoiler
      OEM Roof rails
      V70 XC SE steering wheel
      Volvo T5 Perfo wheels
      OEM 15G turbo
      Volvo 'Blue' fuel injectors
      1998 V70 T5 ECU
      Dolby Pro-logic Sound system (Dolby processor, factory amp, and center speaker)
      Volvo SC-901 Radio
      GROM Bluetooth kit for Volvo
      1998 V70 GLT Nautic Blue/Light Taupe 15G, Blues, 98 T5 ECU 180K
      Member
      Apr 2006
      Ft Myers Florida
      Color me interested and I am semi local (Warner Robins GA). PM me your phone number.
      2006 S60 T5A, 1997 850R SOLD, 1997 854 GLT SOLD, 1998 S70 T5A SOLD,1998 SOLD C70 T5M SOLD, 1998 S70 T5M SOLD, 2004 C70 HPT SOLD, 1998 S70 T5M 18T SOLD, 1998 V70 T5A SOLD, 1998 S70 T5M 19T SOLD, 1998 XC70 SOLD, 1995 854 Turbo SOLD 1998 C70 HPT TRADED, 1996 854 Turbo SOLD, 1998 V70 T5M SOLD, 1998 V70 T5 SOLD, 1996 854 SOLD, 1993 244 SOLD, 1991 244 SOLD, 1998 V70 T5M SOLD, 1985 245 Turbo SCRAPPED, 1982 244 Turbo SOLD, 1997 854 GLT SOLD, 1995 854 Turbo SOLD, 1997 855 T5 SOLD, 1996 854 TLA SOLD, 1997 855 NA SOLD, 1992 244 SOLD, 1998 V70 T5M SOLD
      Nov 2014
      Augusta, GA
      PM inbound.
    5. #4
      Nov 2014
      Augusta, GA
      Sold
    6. Remove Advertisements
