Sensus-Playing files from USB
    Results 1 to 4 of 4
      Oct 2017
      OK,i think we all know that sensus can't play the songs we have in a usb inside files.
      That is until you create a playlist.
      One of the many programms to create playlists,one i used,is Playlist Creator.
      Download it in your pc.
      Assuming you have 3 files in your usb root ie.CD01,CD02,CD03 and in there you have songs.
      Open the prog-press "add folder" and add the folder directly from your usb ie.CD01
      You will then see all your songs in the prog.
      Press SETTINGS and go to Playlist Details.Under "Saving playlist entries" make sure to check "Relative"
      Under "Miscellaneous" check the 3 boxes.
      In Save Location,select the CD01 file(meaning you want to save the playlist in your CD01 file)
      In "Name and Type":name the playlist CD01 and type: .m3u
      Then press create playlist and you will see the created playlist file in the CD01 File.
      Now connect your usb in the car and when selecting Library,you see after songs,albums etc...the Playlists.
      Select it and then you will see CD01.Select it and you start playing your songs from this file.
      and so on and so forth...for the other files.
      Hope this is of some help.
      ps
      i had a bit of trouble doing it because i selected "Absolute" under "Saving playlist entries"
      Junior Member Torsen's Avatar
      Paris, France
      Nice one!
      Sorting out ID3 tags helps a great deal- easiest done using MP3Tag app: https://www.mp3tag.de/en/
      Arrow Playlist creation doesn't work or show in music library screen
      Quote Originally Posted by Chris60 View Post
      ps
      I created playlist with list of album with '.m3u' extension. But it is not displaying in Music Library on 2018 Volvo xc90 T5. Please let me know the playlist format and a free downloadable playlist creator for Mac OS.
    5. #4
      Awaiting Approval
      Jun 2019
      ITunes playlists exports to USB (Windows) [Fixed] [Working]
      After much playing, I can now export my iTunes playlists to a USB stick.
      It is attached; simply format a USB stick as FAT32 and name it either "Volvo Music" or "Car Music" [This stops you accidentally overwriting another USB Drive]
      And run the attached VBS script - the "status" window is a little Clunky" in VBS but seems to work fine.
      If you need to have UNIX separators rather than DOS then you can start it with the switch UNIX. i.e. iTunesPlaylistExportToVolvo5.vbs UNIX
      It also works for my wife's Ford Sync3.
      Hope it helps someone!
      Cut here and save to a file called iTunesPlaylistExportToVolvo.vbs
      === cut here ===== cut here ==== cut here ===== cut here ==== cut here ==== cut here============
      ' iTunesPlaylistExportToVolvo.vbs [UNIX]
      ' For UNIX create a Windows shortcut that looks like "D:\Playlist Development\iTunesPlaylistExportToVolvo5.vbs" UNIX
      ' THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
      ' IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
      ' FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
      ' THE AUTHOR OR ANY OTHER CONTRIBUTOR BE LIABLE FOR ANY CLAIM, DAMAGES
      ' OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
      ' ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
      ' DEALINGS IN THE SOFTWARE.
      ' (c) Paul Simmonds, 2019; www.simmonds.org.uk
      ' Some iTunes export code from an original work by
      ' (C) Dirk Hedderich, 2009; www.verheddert.de/itunes Version 1.0, 2009-02-01
      ' Status box code adapted from (Meticulix) by combining formulas taught by Denis St-Pierre's '"Progress Message" and SimplyCoded's "Part 24: Replace Lines" Tutorial
      Option Explicit
      ' Makes the object a Public object (Critical!)
      Dim objProgressMsg
      Dim strWindowTitle : strWindowTitle = "iTunes Playlist to USB - STATUS (Do NOT Close]"
      'On Error Resume Next
      Dim driveLetter
      Dim driveName
      Dim iTunes
      Dim targetDrive
      Dim CONST_FilePrefix
      Dim CONST_Silent
      Dim BtnCode
      Dim WshShell
      Dim track
      Dim myItem
      Dim objFSO
      Dim Drives
      Dim strMessage
      Dim textFile
      Dim colDrives
      Dim colSources
      Dim colPlaylists
      Dim objDrive
      Dim objSource
      Dim objPlaylist
      Dim trackLocation
      Dim itemLocation
      Dim result
      Dim skipIfExist
      Dim unixFileLocation
      Dim destinationFile
      Dim destinationFolder
      Dim destinationFolderArray
      Dim strDirBuild
      Dim i
      Dim copyResult
      Dim fsUnix: fsUnix = False
      Set objFSO = CreateObject("Scripting.FileSystemObject")
      Set colDrives = objFSO.Drives
      Set WshShell = WScript.CreateObject("WScript.Shell")
      ProgressMsg "Now starting iTunes to look for Playlists, please wait . . . ", strWindowTitle
      Set iTunes = CreateObject ("iTunes.Application")
      Set colSources = iTunes.Sources
      'Check the first argument
      If Wscript.Arguments.Count > 0 Then
      If Wscript.Arguments(0) = "UNIX" Then
      fsUnix = True
      ProgressMsg "UNIX file seperators set, please wait . . . ", strWindowTitle
      MsgBox("m3U will be written in UNIX format - with / file seperators")
      End if
      End If
      ' Give the user an initial progress
      ProgressMsg "Looking for a suitable USB Drive, Please wait.", strWindowTitle
      For Each objDrive in colDrives
      ProgressMsg "Checking drive " & objDrive & " . . . Please wait!", strWindowTitle
      if (objDrive.DriveType = 1) AND (objDrive.IsReady = TRUE) Then
      if ((InStr(1, objDrive.VolumeName,"VOLVO MUSIC",1) > 0) OR (InStr(1, objDrive.VolumeName,"CAR MUSIC",1)) > 0) Then
      driveLetter = objDrive.DriveLetter
      driveName = objDrive.VolumeName
      end if
      end if
      Next
      On Error Goto 0 ' Normal Error Handling
      if driveLetter <> "" Then
      ProgressMsg driveName & " found in Drive: " & driveLetter & ":", strWindowTitle
      result = MsgBox (driveName & " found in Drive: " & driveLetter & ":" & vbCrLf & "Proceed using this drive?", vbYesNo, "Write music & playlists")
      Select Case result
      Case vbYes
      result = MsgBox ("If the file already exists, do you want to" & vbCrLf & "skip writing the track to the USB?", vbYesNo, "Skip writing")
      Select Case result
      Case vbYes
      skipIfExist = True
      Case vbNo
      skipIfExist = False
      End Select
      targetDrive = driveLetter & ":"
      For Each objSource in colSources
      'Wscript.Echo objSource.Name
      Set colPlaylists = objSource.Playlists
      For Each objPlaylist in colPlaylists
      If objPlaylist.Kind=2 then
      If objPlaylist.SpecialKind=0 then
      If objPlaylist.Smart=False then
      'Start of individual Playlist loop
      result = MsgBox ("The Playlist '" & objPlaylist.Name & "' will be written to " & targetDrive & objPlaylist.Name & ".m3u" & vbCrLf & "Do you want to write this playlist?", vbYesNo, "Write music & playlists")
      if result = vbYes Then
      if objPlaylist.Tracks.Count < 1000 Then
      Set textFile = objFSO.CreateTextFile(targetDrive + objPlaylist.Name + ".m3u", true, false) ' Options set to: "Over-write" and "Save as ASCII"
      'Write the Header
      textFile.WriteLine("#EXTM3U")
      ' Loop over all Tracks of this Playlist
      for track = 1 to objPlaylist.Tracks.Count
      On Error Resume Next ' Catch errors using iTunes items
      ' Get item attributes
      do
      itemRead = True
      Err.Clear
      Set myItem = objPlaylist.Tracks.Item(track)
      If Err.Number = 0 Then itemLocation = myItem.Location End If
      'to get file path without drive letter, assuming drive letters are c:, d:, etc
      trackLocation = Split(itemLocation,":")
      'Format should mirror the iTunes location, but in DOS format, without the leading slash = _A\AC-DC\AC-DC_-_Spellbound.mp3
      If fsUnix = True Then
      unixFileLocation = Replace(trackLocation(1), "", "/")
      Else
      unixFileLocation = trackLocation(1)
      End if
      unixFileLocation = Mid(unixFileLocation,2)
      'unixFileLocation = track & " " & unixFileLocation
      'We are going to move this down and make it conditional on a sucessful copy (or file is already there)
      'textFile.WriteLine(unixFileLocation)
      If Err.Number <> 0 Then
      'textFile.WriteLine("Error accessing iTunes! - " & myItem.Name)
      itemRead = False
      BtnCode = WshShell.Popup("Error accessing iTunes! (" + myItem.Name + ")" + vbCrLf + "Please close all iTunes dialogues." + vbCrLf + vbCrLf + "Try again? Press Cancel to leave program.", 0, "iTunes Export Playlist to Folder", 5 + 16)
      If BtnCode = 2 then
      'textFile.WriteLine("Program aborted.")
      WScript.Quit()
      End If
      End If
      'here is where we copy the file
      destinationFile = driveLetter & ":" & trackLocation(1)
      'Check to see if the file already exists in the destination folder OR we want to overwrite anyway
      If (objFSO.FileExists(destinationFile) = False) OR (skipIfExist = False) Then
      'Check to see if the file is read-only
      If objFSO.GetFile(destinationFile).Attributes And 1 Then
      'The file exists and is read-only.
      'Remove the read-only attribute
      objFSO.GetFile(destinationFile).Attributes = objFSO.GetFile(destinationFile).Attributes - 1
      End If
      destinationFolder = Left(destinationFile, InStrRev(destinationFile, ""))
      If Not objFSO.FolderExists(destinationFolder) Then
      destinationFolderArray = split(destinationFolder, "")
      strDirBuild = destinationFolderArray(0)
      ' Check each (sub)folder and create it if it doesn't exist
      For i = 1 to UBound(destinationFolderArray)
      strDirBuild = strDirBuild & "" & destinationFolderArray(i)
      'MsgBox(strDirBuild & " : " & destinationFolderArray(i) & " : " & i & " of " & UBound(destinationFolderArray))
      If Not objFSO.FolderExists( strDirBuild ) Then
      objFSO.CreateFolder strDirBuild
      'MsgBox("Make Directory: " & destinationFolderArray(i))
      End if
      Next
      End If
      'MsgBox("Actual PC Location = " & itemLocation & vbCrLf &"Destination = " & destinationFile & vbCrLf &"Desination Folder = " & destinationFolder & vbCrLf & "m3u text location = " & unixFileLocation)
      'It is safe to copy file to this folder.
      ProgressMsg "Track " & track & " of " & objPlaylist.Tracks.Count & " - " & objPlaylist.Name & ".m3u [Copy file to USB]", strWindowTitle
      copyResult = objFSO.CopyFile(itemLocation, destinationFile, True)
      'If the file sucessfully copied then it's safe to write the file
      ProgressMsg "Track " & track & " of " & objPlaylist.Tracks.Count & " - " & objPlaylist.Name & ".m3u [Write track to m3u]", strWindowTitle
      if (copyResult = 0) Then textFile.WriteLine(unixFileLocation)
      Else
      'If the file already exists and we skipped then it's safe to write the file
      End If
      Loop Until itemRead = True
      ' Read all item attributes, now do something ;-)
      Next
      Else
      MsgBox ("This playlist has more than 1000 tracks and will not work in the vehicle")
      End if
      End If
      End If
      End If
      End If
      Next
      Next
      textFile.Close()
      ProgressMsg "Done", "iTunes Playlist to USB - STATUS"
      WScript.Echo "Click [OK] to close program!"
      'WScript.Quit
      Case vbNo
      MsgBox("User aborted the utility")
      End Select
      Else
      Wscript.echo "No USB called 'VOLVO MUSIC' or 'CAR MUSIC' found"
      End If
      'final Clean up
      Set objFSO = Nothing
      'Set wshMsgShell = Nothing
      'Set objMsgFSO = Nothing
      WScript.Quit
      Function ProgressMsg(strMessage, strWindowTitle )
      ' Written by Denis St-Pierre
      ' Displays a progress message box that the originating script can kill in both 2k and XP
      ' If StrMessage is blank, take down previous progress message box
      ' Using 4096 in Msgbox below makes the progress message float on top of things
      ' CAVEAT: You must have Dim ObjProgressMsg at the top of your script for this to work as described
      Dim strTEMP
      Dim strTempVBS
      Dim objTempMessage
      Dim wshMsgShell
      Dim objMsgFSO
      Set wshMsgShell = CreateObject( "WScript.Shell" )
      strTEMP = WshMsgShell.ExpandEnvironmentStrings( "%TEMP%" )
      If strMessage = "" Then
      ' Disable Error Checking in case objProgressMsg doesn't exists yet
      ' Kill ProgressMsg
      objProgressMsg.Terminate( )
      ' Re-enable Error Checking
      On Error Goto 0
      Exit Function
      End If
      Set objMsgFSO = CreateObject("Scripting.FileSystemObject")
      strTempVBS = strTEMP + "" & "Message.vbs" 'Control File for reboot
      ' Create Message.vbs, True=overwrite
      Set objTempMessage = objMsgFSO.CreateTextFile( strTempVBS, True )
      objTempMessage.WriteLine( "MsgBox""" & strMessage & """, 4096, """ & strWindowTitle & """" )
      objTempMessage.Close
      ' Kills the Previous ProgressMsg
      On Error Goto 0
      ' Trigger objProgressMsg and keep an object on it
      Set objProgressMsg = WshShell.Exec( "%windir%\system32\wscript.exe " & strTempVBS )
      End Function
    6. Remove Advertisements
