40K Service Issues
    Results 1 to 3 of 3
      Feb 2014
      Central Mass.
      Thumbs down 40K Service Issues
      I posted in the S60 section, but this is also relevant to XC60s.
      see:
      https://forums.swedespeed.com/showthr...=1#post6483457
      Bottom line: The dealer wanted over $800 to do the 40K service, but I got it down to under $300 by having them do only the messy parts (oil change and brake fluid flush). Then came the surprise $725 rear brake replacement.
      2015 XC60 DRIVE-E T6, Platinum, Heated F. Seats, Crystal White Met, Xenon, Tech, BLIS
      Custom: Valentine mount/City Safety IR filter, Dog Seat, Superchager ind., REAL dipstick
      2002 Acura RSX Type-S 6 speed
      2020 Tesla Model 3 Performance
      Dec 2017
      I am not let them do more than what we talked before the service starts. They usually call me with some stuff to be changed and always tell them to not do it. At least in UK is not mandatory to change something on your volvo to a volvo dealer to not loose your warranty. As long as the service shop who's doing the change is using the same parts as the dealer everything is ok. In dec 2017 at the service check 30k miles they told me that I have to change the break pads and the EGR cooler. They were asking £1700 for those on top of the regular service fee. I changed the pads elsewhere and after talking with the service manager I got the cooler and the pipes for free. Theee is a 4 years waranty on EGR valve that is cover by the dealer, but a lot of them are not telling you this.
      Sent from my SM-G900F using Tapatalk
      Jan 2018
      Pennsylvania
      Quote Originally Posted by catad View Post
      In the US, you don't even have to use the same parts. Any damage done by aftermarket parts is, of course, not covered by the OEM warranty, but other than that you have an absolute right to use whatever replacement parts you like. And, the burden of proof that an aftermarket part caused a given problem is on the warrantor, not on you. Certain things are excluded from your warranty, but nothing "voids" it.
      2018 XC60 Momentum T5, Denim Blue/Blonde, Convenience/Vision/Advanced/Nav Pro/Heated Seats/Protection Premiere/ 20" wheels.
