SPA XC90 DIY Oil Change with pics - Page 4
    Page 4 of 4 FirstFirst 1 2 3 4
    Results 106 to 121 of 121
    1. #106
      Nov 2019
      Prosper, TX
      Quote Originally Posted by stick_shift View Post
      Same here. Wifey's XC90 is due for the final (free) dealer oil change, after that I'm installing a Fumoto.
      With the shape of the oil pan, I’m guessing we’re going to need the extension piece.
      2017 XC90 T6 AWD Inscription with Polestar optimization
      Oct 2017
      Quote Originally Posted by theclutch View Post
      Completed the messiest oil change ever. Again, note that the oil shoots out "vs pour out" of the oil pan. More oil comes out of the oil cartridge housing.
      Special thanks to stick_shift for doing this thread with pics.
      Very sarcastic thanks to the past 3 free oil change dealer techs (could be the same dealer techs) who seemingly used an impact wrench to over tighten the oil filter cartridge housing vs doing the 25 Nm that is written on the freakin cannister! And also a very special thanks for not putting these 2 clips back which cost over $4 EACH. You have once again reconfirmed why I should never go to the dealer to get any of my cars worked on. I.e. - If you can't even do an oil change properly, how can I trust you for anything else?
      ha, did first oil change on my own at 40K and couldn't even tell the clips were supposed to be there - already gone along with 1 of the 10 screws! true, remaining 9 hold the cover just fine, but still this is some shoddy dealership work. also could barely get the filter canister out, over tightened for sure!
      I posted my oil analysis results in another thread, but will post it here too. Excessive fuel dilution could be a common issue for all unsuspecting T8 owners:
      any thoughts/tips on this issue are much appreciated!
      Poverty-spec 2016 XC90 T8 Momentum
      Zero options, $52K out the door brand new
    4. #108
      Aug 2016
      Hmm... the last time I had a "bad" oil report (I get all 8 of our cars analyzed), I ended up dumping the car. This would fit that category for me. I would take a sampling at 5k to see if it would improve. But I've never run a hybrid. Even so, I wouldn't think this was normal. I would run the car hard and hot (to burn any fuel in the oil) before taking another sample. But if the oil level keeps getting higher, time to trade it in...
      SwedeSpeed.com
      Aug 2016
      I was thinking about this Fumoto thing... But since the effective drain hole is smaller than that of the drain plug, I would assume that the oil would STILL shoot out like a water gun... Don't you think?
    7. #110
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      You can buy a Fumoto with a nipple that let's you attach a hose to direct flow.
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body - Replica 18" Pegs - Handbrake Mod
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R, 2004 V70R MT 68k
    8. #111
      Aug 2016
      Quote Originally Posted by R-Pow3R3d View Post
      OMG! Ok, I had to look it up! Sold! Here's a link!
      http://www.fumotousa.com/results.php...d=XC90+2.0L+L4
    9. #112
      Oct 2017
      yeah, I'll do another change just before the warranty runs out later this year and see if results improve. Hard and hot is the way to go for sure, as I think driving a plug-in hybrid essentially amounts to excessive start and stop usage pattern, which is the primary suspect for oil dilution. Fuel is not burning off completely and is seeping through piston rings into the oil I guess? Would asking for a cylinder compression test at the dealership be of any use?
      Also a more frequent oil change schedule wouldn't hurt, since diluted oil loses its viscosity quicker. And I'll add some Liqui Moly Cera Tec next time around for just that reason too.
    10. #113
      Junior Member Ultrarunner511's Avatar
      Jul 2017
      Arizona
      I had a loaner T8 recently, and I was surprised at how often the ICE/battery start/stop was activating. Especially when the air temperatures were 110+ degrees, and 170+ degrees on the asphalt. This did not settle well with me whatsoever.
    11. #114
      Sep 2016
      Austin, TX
      Our 'free' oil changes are over so I took the opportunity to install a Fumoto valve F-104
      Turns out... it doesn't fit despite being the part brought up by both Fumoto and Amazon! There is interference with the engine when threading it in.
      You also need this extension piece:
      https://www.amazon.com/Fumoto-ADP-10.../dp/B0043QQVIC
      2018 Onyx Black T6 Momentum: Amber, 20" wheels
      DIY Oil Change:
      https://forums.swedespeed.com/showth...ange-with-pics
      DIY Brake Pads:
      https://forums.swedespeed.com/showth...ment-with-pics
    12. #115
      Aug 2016
      Thanks... but ummm... how about some pics? Pics or it didn't happen!
    13. #116
      Sep 2016
      Austin, TX
      The extension piece will bridge the gap
      DIY Oil Change:
      DIY Brake Pads:
    14. #117
      Sep 2019
      Hi, thank you for the very helpful post - I am a little confused about the amount of engine oil - you mentioned 6.2 quarts. I have a 2019 XC90 T6 engine, according to Volvo's website, it calls for 5.6 liters or 5.92 quarts. Can you let me know where you got the 6.2 from? Probably not going to make a huge difference either way. Thanks again.
    15. #118
      Sep 2016
      Austin, TX
      Quote Originally Posted by mrclemson View Post
      I don't remember. Just googled it again, one of the first results says 6.2qt, including the filter capacity
      https://www.amsoil.com/lookup/auto-a...04t28-8-turbo/
      DIY Oil Change:
      DIY Brake Pads:
    16. #119
      Member
      Aug 2017
      United States
      Use the volume in the owner's manual. 2018 is 5.9 quarts. 2017 is 6.2.
    17. #120
      Sep 2016
      Austin, TX
      Quote Originally Posted by Tech View Post
      Weird. Same engine, right? It's almost like Volvo had a typo in the manual for the first couple years. They say 6.2qt/5.9L, then later change the spec to 5.9 qt. I changed the original post accordingly so as not to mislead anyone.
      For my own work I'll just split the difference and call it "6 bottles." Easier to remember.
      DIY Oil Change:
      DIY Brake Pads:
    18. #121
      Member
      Aug 2017
      United States
      Not sure what the change is. 2016 has two different oil pans for the B4204T23. 2018 has one, with a different part number than the two for 2016.
    19. Remove Advertisements
