Question re: upgrading to 2014+ shifter and paddles
    Results 1 to 11 of 11
      Junior Member marvinmartian's Avatar
      Jun 2017
      Northern VA, USA
      Here's this great thread where Pietila shows an install.
      https://forums.swedespeed.com/showthr...=1#post6301073
      My question is what is the cutoff year for the upgrade parts? IE., I have a MY11 and would like to use the wheel+paddles, GSM and gear shift assembly from a 2016. Is that possible? I seem to recall something about a significant change in how the trans is controlled but I forget the MY for that. Do I need to get something from MY2014?
      Caspian Blue Metallic 2011 S60 T6 AWD
      Member
      Jun 2012
      Pittsburgh, PA
      I ordered a shifter assembly off of eBay. Once I get it I'll see if my Heicco knob can be attached. If so I will do the swap.
      We shall see.
      2012 S60 T5 Savile Gray/Beachwood
      Mar 2010
      You can take it for 2014-2016. You might want to take the gear speed module (GSM) from such a car where there was a paddle shift. For example, a wreck car. Then the gear speed module is ready for programming.
      SwedeSpeed.com
      Jun 2017
      Northern VA, USA
      Ok, great. Excellent. Thanks.
      Now I just need to troll eBay and a few other sites to get all the stuff! :-)
    7. #5
      Member
      Jun 2012
      Pittsburgh, PA
      Quote Originally Posted by marvinmartian View Post
      Speaking of trolling sites, I talked to someone from LKQOnline.com yesterday to ask how come I see a certain part in the pictures of the donor car but when I search for it it doesn't come up?
      She said they take these pics when the car first comes in then they take all the parts out. So even if you see the part you want it doesn't mean they still have it.
      Trolling is the way to go
    8. #6
      Jun 2017
      Northern VA, USA
      Quote Originally Posted by Almaz View Post
      Yeah, I haven't found anything on their site (for the paddle shifter upgrade) the last couple of days. :-(
    9. #7
      Mar 2010
      If your car is newer than +2014, this mod does not have to be done. There are wires ready from SWM (Steering Wheel module) to GSM (Gear speed module)
      You can check it if your GSM comes with all 6 wires.
      1. BU-GY
      2. BN-VT
      3. GN-OG
      4. GY paddle shift
      5. GN-VT paddles shift
      6. BK-GN
      And your SWM will leave all 10 wires.
      1. GY paddle shift
      2. BK
      3. Canbus -
      4. Canbus +
      5. GN-VT paddle shift
      6. GN-OG
      7. GN-BK
      8. GN-WH
      9. BU (This may not be the case if there is no heated steering wheel)
      10. BU-WH
      +2014 SWM is different and it's all done.
      But for the 2010-2013 cars this gets this modification. Remember to investigate your own car's connections, there may be differences. This is my 2011 S60 T6 AWD!
      A few confused images if you could help understand how this works.
      This is GSM (Gear Speed Module)
      If someone does this modification, then they could do better instructions. I do not have pictures of all phases. My language skills are bad.
    10. #8
      Junior Member m337jkb's Avatar
      May 2014
      Bucharest, Romania
      @Pietila, your instructions are really well written and explained. Unfortunately, I'm way too scared to do this mod as it'll end up with the car burning up or something due to my lack of handiness.
      '13 S60 D5 AWD, RD, Polestar optimized, visually enhanced.
      ex: '12 C30, D3, RD, stock.
    11. #9
      Administrator chris@swedespeed's Avatar
      Dec 2000
      DC Metro
      It sounds like a 2014-2018 non-paddle car can just add a steering wheel with paddles, no other changes?
      2016 V60CC Platinum
      2016 S60CC Platinum
      2017 XC90 Momentum Plus (family)
      Previous:
      2017 S90 Inscription T6 AWD, 2019 XC40 R-Design T5 AWD, 2017 V90 Cross Country T6 AWD , 2018 V60 Polestar #103/1500, 2016 XC90 R-Design, 2013 C30 Polestar #141/250,2015.5 V60 R-Design,1998 V70 T5M, 1999 S70 GLT, 2000 V70R, 2004 V70R, 2006 V70R Sonic Blue, 2006 V70R Electric Silver, 2007 V70R Passion Red, 2003 XC90 2.5T, 2007 XC90 V8 Sport Electric Silver, 2007 XC90 Sport V8, Passion Red
    12. #10
      Junior Member TnoV60's Avatar
      Feb 2017
      Seattle, WA
      Quote Originally Posted by [email protected] View Post
      this is great question. I am looking at buying only the shifters but cannot find the whole assembly. So I am confused if I need the full assembly (steering wheel with shifter) or just shifter assembly (I would be happy to have the ref part)
      2016 V60 T5 2.0 FWD Premier Onyx Black Metallic: : BLIS | ERST Intake | IPD Rear Sway Bar | IPD F&R End Links | Powerflex "Race" Torque Rod | RD Suspension | IPD Skid Plate | Volvo Cap Mirror Satin Presentation
      Sold 2008 S40 2.4 FWD - Grey Metallic | K&N Filter | B4 & Koni Suspension
      Monthly Seattle, WA: Meet and Greet Topic: HERE
    13. #11
      Dec 2000
      DC Metro
      here are some steering wheel with paddle part numbers on the accessories page: 2014+ may also be able to add a heated, paddle steering wheel.
      https://accessories.volvocars.com/en...CC-499504/2015
      2016 V60CC Platinum
      2016 S60CC Platinum
      Previous:
    14. Remove Advertisements
