No connection to service - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 54 of 54
    1. #36
      Nov 2019
      Hi,
      I have same issue on my S90
      No way to connect by any means.
      Just got latest software update from dealer but it didn't make any difference.
      Did someone managed to solve it by themselves?
      Member
      Dec 2017
      PNW
      You can press the SOS button in the car and talk to their service people. Just say it is not an emergency and explain the problem. They may be able to look at some logs on your account on server side if there is indeed service related issue. They can at least check if your VOC connection status is active.
      Rolling, Fusion Red - 2018 XC60 - T8
      Running to retire, 2000 V70XC 237344 miles [2020-10-13]
    4. #38
      Nov 2019
      Hi,
      Just in case anyone will read this topic again.
      Just came back from dealer.
      They investigated issue with sweden directly.
      It ended up with IHU reload programing.
      Now it's working without any issue as it should
      Cheers
      Dom
      SwedeSpeed.com
      Sep 2019
      Central, VA
      Thanks Dom
      Quote Originally Posted by domantas1 View Post
      Hi,
      Cheers
      Dom
      Thanks for the info. Am having same issue. In-car apps not working. But car modem working fine. AT&T account good. Can tether laptop to car. But weather, pandora etc. not working. No connection to service. Printed your info to carry to dealer. Maybe save some time. Sounds like you had to go back to the dealer at least twice. Thanks again. Wish me luck!
    7. #40
      Feb 2019
      Long Island NY
      I had the same yesterday. Turns out the Volvo on call had update for the in car app and all was fine after that.
      Did the update over Bluetooth from phone.
    8. #41
      May 2017
      Great White North
      I am having the exact same problem except for me it is the maps I cannot update over the air. What exactly did you do to reset the clock? I am getting the time from the GPS satellites.
    9. #42
      Junior Member zamo's Avatar
      Jul 2006
      Happening to me with TuneIN Radio. I have to open Spotify and then back to TuneIN to make it work.
      '19 Volvo XC90 R-Design, Bursting Blue, AWD, Polestar
      '19 Nissan 370Z, Deep Blue Pearl, Heritage Edition, 6-speed
    10. #43
      May 2017
      Great White North
      Sit rep, it seems the new map update v1311 is what causes the issue. It attempts to start downloading OTA but is corrupt in some way and locks up the connection to the download center. Cancelling the map installation and disabling auto update restores the connection.
    11. #44
      Sep 2020
      Me also had issue with apps. When I started downloading instantly says paused and thats it. No further.
    12. #45
      Cancelling the map download resolved the problem for me. Thanks! Seems like it isnít all maps - the NY map (version 1300), and the Mid-Atlantic map (version 1311) didnít cause a problem, but the New England map (version 1300) paused during download, and I had to cancel that to get the connecting working again. This is with WiFi from my phoneís hotspot, FWIW.
    13. #46
      Junior Member Heimdall's Avatar
      Jan 2018
      On a side note Something fun for you to know
      While installing a map update
      You canít fuel the car.
      Fuel door wonít open.
      Had to find out the hard way and wait about ~30 min in the station to finish the install and to be able to continue my 300 mile drive.
    14. #47
      Sep 2020
      I dont understand that cancelling of the maps. On my is just saying that updates are avalible (maps) and that files are to big to updete with car internet. I did everything but apps install is still always paused and only thing that work is cars hotspot via my bluetooth.
    15. #48
      Sep 2020
      are also having apps installing problems ?
    16. #49
      Member
      Dec 2017
      PNW
      Quote Originally Posted by Heimdall View Post
      ah, god, maybe try update home region only and even nav still works. Updating full map put nav and many functionalities on hold.
    17. #50
      Sep 2020
      what could be the solution? I am freaking out
    18. #51
      Jan 2018
      Quote Originally Posted by FusionRedXC60 View Post
      Is that even possible to select one region.
      I have no clue how.
      Was doing ‘TA and since it was a straight drive I just did the install as Iím driving
    19. #52
      Member
      Dec 2017
      PNW
      I have no clue how.
      Yes, you can click one of the map in the list and update it, also can download one or multiple regions to USB drive at home and install them (slowly).
    20. #53
      Jan 2018
      I know about the home usb option
      Didnít know you can download more than one in OTA
      Thanks for the intel
    21. #54
      Jul 2017
      I finally got tired of being hounded for an app update and then not being able to install anything because it would pause immediately. I visited the dealer and they tried a software update, but it would not install so they had to order a new Vehicle Communications Module (VCM). After that was installed, the software was installed and things are working normally again.
      2018 XC90 Inscription / Air Suspension / B & W / 21" OEM Wheels
    22. Remove Advertisements
