Audio and Equalizer Settings (B&W)
    Results 1 to 8 of 8
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      I created a new thread (without the poll) to encourage all of us to enter and share your audio and equalizer settings for your new SPA vehicle.
      Just click on the Data Entry Form, enter your user name (and Car Model and version, all optional), then enter the prompted data. The objective is to have a centralized location where this data can be stored and retrieved. After entering your data, you should be able to see an updated graph.
      Data Entry Form
      https://docs.google.com/forms/d/e/1F...xde3Q/viewform
      Data Form Summary Sheet
      https://docs.google.com/spreadsheets...95&single=true
      Equalizer Settings
      https://docs.google.com/spreadsheets...at=interactive
      Tone Settings Details
      Balance and Fader Settings Details
      Note: If this works, thanks goes to PhillipU for his technical prowess. If it doesn't work, blame me as I am a novice at this. Once I figure this out, I will replace the links with an interactive image that should update after users have entered and saved their data. If you were one of the original participants, I can delete your original data in case you which to enter and maintain your own data.
      Last edited by Gary-16-Xc90; 05-12-2018 at 08:59 PM. Reason: Fixed links; Added Data Summary link
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 10 Sept. 2020 | 47K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
      New Jersey
      Bad links. Get errors.
      May 2015
      Twin Cities, MN
      Quote Originally Posted by glenmick View Post
      The above links are fixed now. Also, Data Form Entry link fixed and Data Form Summary
      May 2015
      Twin Cities, MN
      @Putertech. Thanks! By way of explanation, I made the mistake of using copy/paste from Swedespeed post in the view mode. I should have used the Edit mode which I have done now. Would you mind deleting the quoted links in your above post so that the bad links are not used? Thanks!
      Mar 2011
      RI
      Done, thanks for putting this together
      Junior Member kospa60's Avatar
      Feb 2003
      Thumbs up
      Exactly what I had in mind!
      It would be interesting to also have some comments from each user, like what type of music they usually hear.
      May 2015
      Twin Cities, MN
      If you click on the data summary (second from top) link, you can scroll or drag from right to left to see music tastes, et al. Let us know if it does not work.
      Junior Member Eldorado's Avatar
      Anne Arundel Co., Maryland
      I went yesterday and did some measurements on my car. My settings turns out completely different to anyone else's. How are calibrating your systems? By the way, the hole on the midrange frequencies is now gone.
      2018 Fusion Red/Amber Nappa Leather XC60 Inscription T6 Polestar® B&W Premium Sound, Convenience, Vision, Advance and Luxury Packages, with stainless steel bumper cover.
    11. Remove Advertisements
