About a week back, I was browsing the facebook marketplace (which is the only real thing I use facebook for anyways) and spotted a 1996 R estate for sale outside of chicago. I contacted the poster, and eventually spoke to the owner, who told me that I could have it this week for $400. Now, I don't know about you, but $400 between me and my dream car? Done. So I went to go pick it up and drove it back in the worst rainstorm I've seen in a decade. Because of all the lightning going on around us, I named it Brixt, which is the Swedish translation of lightning.
So, background information:
Blixt is a genuine 850 R with 157,xxx on the currently broken odometer. IF ANYONE KNOWS HOW TO PULL ACTUAL MILEAGE OFF A OBD II 850 PLEASE LET ME KNOW! He has some minor surface rust on two doors and the tailgate, probably a 6/10. His charcoal interior is in good condition, maybe a 7/10. As you can all see, at some point in his life he developed cleft-bumper, so my plan is to mount a GLT bumper on him for the time being. He has numerous mechanical boo-boos, but he runs and drives at the moment. I will admit that I have never dealt with one of these turbo cars so I am a bit frightened but willing to learn. He has a lifter tick, so any advice on that is also appreciated.
Here is all of the things I plan to do to him as the months go by. He will not be my daily driver, and I will be keeping him unregistered and uninsured until I fix him back to good mechanical condition, and he'll also get to live in my grandma's out garage during winter.
Things to be done:
- Brakes, check and replace all four sides pad and rotor wise, pulling slightly to left
- Timing Belt, and all accessories
- Full stage 0, and removal of that dumb K&N filter. If anyone has a top to a turbo airbox please let me know.
- throttle cable and clean throttle body with upgrade to N/A throttlebody
- Oil pan flush and re-gasket / seal
- check turbo and replace all vacuum hoses, I will definitely need some help with basic turbo maintenance here
- oxygen sensor, currently check engine light for it
- exhaust, very loud and smelly right now, considering an IPD solution or stock which ever is better.
- there's a dead spot in the steering, could use adjustment. Also steering wheel is out of alignment
- Oil leak on back side of engine near transmission I noticed the day after buying, any idea? cam seals? rear main seal (gulp)?
- climate control is blinking multiple times when car is first started, diagnose using vol-FCR
- Identify and solve lifter tick, possibly change out lifters if necessary
But hey, the suspension is fine!
I know that's a lot, but this is my big fixer upper. This car has potential and I'm determined to see it through.
Here he is in his current, albeit fading, glory:
Brixt begins by Charles Conto, on Flickr
Video of the lifter tick:
Things to be done:
