Blixt Begins! - 1996 Volvo 855 R Restoration - Page 2
    Page 2 of 9 FirstFirst 1 2 3 4 5 6 ... LastLast
    Results 36 to 70 of 282
    1. #36
      Junior Member CYB3RBYTE's Avatar
      Oct 2016
      Milwaukee, WI
      So I've had some time to monkey around a bit today, here are my results:
      - The PCV is for sure in need of replacement. Hoses are rock hard, and this also seems to be the spot of an oil leak on top of the engine going all the way down the transmission. Hopefully thats all it is, and not a RMS.
      Brixt Begins, Part 2 by Charles Conto, on Flickr
      - Oil in the intake / intercooling tubes for the turbo, which have all been replaced with this SAMCO brand tubing. I did research which told me that this is normal except I'm not sure it is.
      - Accidentally lost the bolt for the turbo tube that runs over the spark plug cover... if anyone has an extra let me know!
      - Needs a new throttle cable, this one is disintegrating inside the casing and was pulling away from the firewall.
      - Took the cowl off to clean it from the 8 billion pine needles and soil calling it home. Much better. However to my surprise this car doesn't have a air pollen filter on it. Was this an option, even for R's?
      - Proceeded to vacuum the interior to "acceptable" levels. The back was the worst under the seats. Also I'm missing a few back interior pieces so if someone has a lead on those let me know. There is only one 850 wagon at the JY I visit.
      - I couldn't even begin to read the timing belt cover, so that's getting done ASAP.
      - The previous owner wired in a fan switch for some reason, and it ends in the cabin with a toggle switch. I need to find out how to reverse this, because to my knowledge their is no reason the fan shouldn't be coming on...
      That's all I can do for now. EXAM TIME!
      In the Garage
      Xena / 2006 XC90 V8 AWD, Onyx + Oak / 170,6xx /
      Viveka / 1996 850 N/A, Polar White + Oak / 128,5xx /
      Blixt / 1996 850 R, Polar White + Charcoal / 219,2xx /
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      I have a couple cabin filter housings. Yours free just pay shipping.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    4. #38
      Member sventastic's Avatar
      Nov 2013
      British Columbia
      Next time you have a chance, pull off the distributor cap - I would bet that oil has made its way in and fouled the contacts which is causing your stumbling issue. Worth checking the plugs as well. Oil in the intercooler piping is normal to an extent, yours don't look too bad
      I lost that same intercooler pipe bracing bolt, I replaced which some metric bolt but don't recall the type...
      My R also didn't have a cabin air filter
      Good luck on exams!
      1996 854R | M56H | 16T | 264k
      SwedeSpeed.com
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by sventastic View Post
      Good luck on exams!
      Funny you say that, I checked the plugs. Cheap autolite, can't wait to get some real volvo plugs in there!
      In the Garage
    7. #40
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      I probably have an extra turbo airbox
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 136k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    8. #41
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      Plug seems to show no major problems with the motor but I would definitely replace them with Volvo plugs.
      I did see that toggle switch in an earlier pic and forgot to ask about it. Maybe whatever switch that is supposed to turn the fan on is broken.
      Oil in the intercooler piping looks normal to me, especially on a 20+ year old car with some miles. Folks love the silicone hoses so I would hold on to them.
      Agree with sventastic on taking a look at that distributor - maybe there's a seal behind there that is leaking or one of the cam seals. These are all a lot easier to address than a RMS.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    9. #42
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Great fun to watch all of this. Great fun indeed.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    10. #43
      Member Koyen's Avatar
      May 2013
      Madison, Wisconsin
      Good stuff! This is going to be a cool project.
      -TJ
      '10 Cadillac CTS Sportwagon AWD :: 3.6L Grocery-Getter
      '97 855 :: Project Boxy Lady (SOLD)
      '07 S60R MT :: 452//Nordkap (SOLD)
    11. #44
      Oct 2016
      Milwaukee, WI
      I'm for sure going to be doing a complete stage 0, on this, and when I tackle the distributor I'll be checking the seal as well. Looks easy enough to replace.
      In the Garage
    12. #45
      Mar 2011
      Laguna Hills, CA
      Congrats on the new R! You have got a good list going along w/ some great suggestions. I would look into flushing the oil - using a conditioner/cleaner to help it get rid of any sludge that may be present. You most likely don't know what kind of oil and at what frequency it was changed from the PO. You don't want to change straight to synthetic if regular oil has been used. Dropping the pan and cleaning it out, swapping the seals will help and you probably won't have to do that again once you've done it right.
      So cleaning the engine up (inside & out) will go a long way to getting rid of that lifter tick. Make sure you aren't burning any oil too. Then you can start using the synthetic oil.
      On another note, your exhaust may be straight piped - thus the strong odor and loudness. You probably should do some type of hybrid over going completely stock, as the stock downpipe sucks. You'll likely need a catalytic converter and a resonator added.
    13. #46
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by DrewsT5 View Post
      My plan is to do a few changes of Castrol GTX High Mileage 10W-30 half-synthetic, but I have no idea what cleanser to run through it. Some people have said diesel oil, but I'm open to more suggestions. After that the seals are getting done for sure.
      The exhaust may be straight pipped... but it more sounds like there is a large hole somewhere and I'm getting a code for an O2 sensor. I believe I have a straight flange, and I've been thinking about the stainless steel system that Swedish Car Parts in illinois sells since I believe it has a cat included in it, and I don't have a lift to install a new exhaust whereas they do
      In the Garage
    14. #47
      Feb 2016
      Denver USA
      Fun Name
      Quote Originally Posted by CYB3RBYTE View Post
      I named it Brixt, which is the Swedish translation of lightning.
      The Swedish word for lightning is "blixt," though I'm guessing you know that and went for "brixt" anyway in order to incorporate a delicious brick pun? Very nice.
      Anyway, if you like the ring to it, you could add an –en suffix (a Swedish equivalent of the English article "The") to give it proper noun treatment: Blixten (or Brixten).
      Congrats on the sweet new project!!
    15. #48
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by hisingen View Post
      The Swedish word for lighting is "blixt," though I'm guessing you know that and went for "brixt" anyway in order to incorporate a delicious brick pun? Very nice.
      Damnit I knew I was getting some letter wrong. In my defense it's exams week at my school and I'm pretty burnt out brain wise :P. Changing it's name to Blixt! Don't think I can change the thread's name.
      In the Garage
    16. #49
      Jan 2014
      Boston, MA
      the mods can change it
      if you're spending $ on exhaust convert to angle flange
    17. #50
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by JaredR View Post
      What are the advantages of angle flange vs straight flange? Breathes better?
      In the Garage
    18. #51
      Mar 2011
      Laguna Hills, CA
      Better flow characteristics with the angle flange. Even better if you can find a 7 CM over a 6 CM angle flange. Here's a good picture highlighting the differences from good, very good, even better, best.
    19. #52
      Oct 2016
      Milwaukee, WI
      Would I have to change turbos out to do this or just the flange and exhaust?
      In the Garage
    20. #53
      Mar 2011
      Laguna Hills, CA
      Turbo stays the same. Your downpipe would need to change with the flange. The flange goes in between the turbo and exhaust downpipe.
    21. #54
      Oct 2016
      Milwaukee, WI
      Okay. Any advice on exhaust system? I was thinking of going with an iPD but I know a lot of people have negative opinions on them...
      In the Garage
    22. #55
      Mar 2011
      Laguna Hills, CA
      I think it boils down to your personal preference. Quality wise, IPD would be a better choice over OBX, but either of those still may not be to your liking for sound. You may want it even quieter, I'm not sure if that's the case with you though. Mototec Touring Edition seems to have a quieter sound closer to stock, but with better flow than stock.
      You'll have to start looking up clips on YouTube to see what you like.
    23. #56
      Jan 2014
      Boston, MA
      The IPD downpipe is great but the exhaust is loud.
      Do you have to pass emissions? If not just grab a OBX downpipe and attach to a catback of your choice. Or even get a stock angle flange DP and it will flow way better.
    24. #57
      Oct 2016
      Milwaukee, WI
      I don't mind loud, but if it has the partial blessing I may go with iPD. However I have heard that TME is a good choice as well.
      In the Garage
    25. #58
      Jan 2014
      Boston, MA
      My T-5R came with a TME. Sounds great at WOT. Drones pretty bad a 55-60 though. Get something else if you ever plan on taking a road trip.
    26. #59
      Oct 2016
      Milwaukee, WI
      Okay my thoughts are to find a angle flange housing and get an iPD angle flange sport exhaust. How hard is it to convert from angle flange and are the angle flanges still available for 15Gs? I would like to not have to change my turbo if it's a good one for now.
      In the Garage
    27. #60
      Jan 2014
      Boston, MA
      You can use an angle flange housing on a 15g. 100% chance your turbo needs to be rebuilt.
    28. #61
      Oct 2016
      Milwaukee, WI
      I'm going to agree with those chances, do you know how expensive and how hard it is to rebuild a turbo?
      In the Garage
    29. #62
      Dec 2014
      Connecticut
      $400 to have someone else do it or $45 and cleaning yourself plus balancing. Or just put a 16t on it and enjoy.
    30. #63
      Oct 2016
      Milwaukee, WI
      So where could I find a good rebuild kit with quality parts? I’ve heard of people buying eBay kits but I don’t want to risk it being the wrong stuff...
      In the Garage
    31. #64
      Mar 2011
      Laguna Hills, CA
      Quote Originally Posted by ScottishBrick View Post
      This is exactly what I did with mine. Bought a used 16T that was in good shape since my 15G was toast, blowing smoke everywhere. The 16T came with a straight flange, so we removed it and put on the conical flange to reattach it to my stock downpipe. Now I can either rebuild the 15G, upgrade it or sell it for cheap to a rebuilder, and I have a straight flange to use when it comes time for the exhaust system to be upgraded.
      If you are looking to rebuild it yourself check out this site: http://www.ardideas.com/Turbocharger...ets_c_579.html
      Plus he has a video to walk you through the steps: https://www.youtube.com/watch?v=DB8_IfzAL0M
    32. #65
      Mar 2011
      Laguna Hills, CA
      Thanks for the info Wayne and Jared. I’m down by my house today so I’m gonna try and trace the oil leak before my big round of final exams starting tomorrow.
      Does anyone have an R ECU or a cover for the top of the air filter? I’m not happy with this K&N cone filter and I’d like to go back to stock. I just don’t have access to a turbo air box....
      Just stumbled across this: https://www.matthewsvolvosite.com/fo...hp?f=7&t=85248
    33. #66
      Dec 2014
      Connecticut
      You actually want this kit
      https://m.ebay.com/itm/Upgraded-TDO4...pid=1783646981
    34. #67
      I can build you a nice billet 16t if you would like. 11 blade billet wheel with a 9 blade turbine wheel with all the internal upgrades. Or I have a 16t I pulled off of a car I could get rid of
    35. #68
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by volbro850 View Post
      Is the 16T you pulled of a car angle flange or straight? Also wouldn't I need a tune to take advantage of it? And injectors? I don't want to get too far ahead of myself before I get it to stage 0.
      In the Garage
    36. #69
      Mar 2011
      Laguna Hills, CA
      If you can, take some pic of your exhaust and post em up - starting at your downpipe at the turbo. We can tell you what you currently have just by looking at them. If you have an exhaust that's loud, perhaps you already have an aftermarket downpipe. We can also see what kind of flange you have too. If you have a stock exhaust and stock tune, you won't need to get your car tuned if swap your 15G to a 16T. They're pretty much the same. If you change your injectors to larger ones (like the green ones) you'll need a tune to compensate for that change.
    37. #70
      Oct 2016
      Milwaukee, WI
      Finally done with exams, and got a picture of the exhaust. Also recieved some essentials from iPD, a new key and a tailgate rebuild kit.
      In the Garage
    38. Remove Advertisements
    Similar Threads
    1. My Atacama seat restoration (before & after) + trim restoration
      By itsmeee in forum R Forum (2004-2007)
      Last Post: 12-16-2014, 01:52 AM
    2. 1996 Volvo 855 TurboWagon
      By mrsharp in forum FWD & AWD Cars For Sale
      Last Post: 06-02-2013, 11:59 AM
    3. feeler- will sale if there is intrest- 1996 volvo 855 GLT
      By robdeselich in forum FWD & AWD Cars For Sale
      Last Post: 05-25-2007, 04:32 PM
    4. My 1996 Volvo 855 on ebay!
      By 1999_V70 in forum FWD & AWD Cars For Sale
      Last Post: 05-10-2005, 10:49 PM
