Blixt Begins! - 1996 Volvo 855 R Restoration - Page 9
    Page 9 of 10 FirstFirst ... 5 6 7 8 9 10 LastLast
    Results 281 to 315 of 317
    1. #281
      Nov 2015
      Quote Originally Posted by CYB3RBYTE View Post
      what did you replace to have it fixed? Blower resistor?
      No, the motor was bad. It was locked up. It wouldnít turn with 12 volts. 18 would but it was quite... labored
      Nov 2015
      Quote Originally Posted by johnwartjr View Post
      The failed ones Iíve changed all look like this.. the copper colored dust is from the bushings breaking down I believe.
    4. #283
      Junior Member CYB3RBYTE's Avatar
      Oct 2016
      Milwaukee, WI
      Does anyone know if itís possible to repair a blower resistor? I read online if it fails you only get speed four but I didnít have any speed work for the fan.
      In the Garage
      Viveka / 1996 850 N/A, Polar White + Oak / 134,6xx /
      Blixt / 1996 850 R, Polar White + Charcoal / 219,6xx /
      SwedeSpeed.com
      Nov 2015
      A resistor isnít really repairable. Itís either the correct value or itís not. I suppose if you know what value it should be, you could open one up and replace the actual resistor. Pretty easy to change the whole unit... and fairly inexpensive at a salvage yard
    7. #285
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      I would just get a JY one.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    8. #286
      Oct 2016
      Milwaukee, WI
      Makes sense. I had seen on a different forums someone had replaced the thermal fuse inside and was able to use their same resistor again. However if mine if just cooked I'll go grab one. What values should I be testing for to see if it's a good one from the JY?
      In the Garage
    9. #287
      Oct 2016
      Milwaukee, WI
      Early Spring 2020 update. Finally got around to procuring my own set of tools, no more bothering dad to borrow his, lol. They're cheap but at least they're mine.
      Spring 2020 R Update by CYB3RBYTE, on Flickr
      Pulled a working power stage from my local yard. Installed it, and still nothing from the blower. I was receiving power from the power stage itself, so I pulled the blower. Oof, it's definitely given up the ghost.
      Cleaning it, lubricating it, and testing it, this blower is gone. It didn't even try to spin connected to the battery, the contacts inside must have failed. New Bosch unit ordered off eBay, hopefully get that in by the end of the week if it gets any colder here.
      Next up, fixing a stupid mistake. Don't try to move mirrors that won't fold in, because then you break it off entirely, lol. Again, junkyard find, with better paint than the old one as well!
      And finally, I noticed the right engine mount was destroyed when replacing the timing belt. Found a good condition slightly used one in my stash, and now my oil thermostat is no longer half an inch from my subframe haha.
      Exhaust is coming soon. What are best practices when removing the turbo exhaust flange?
      In the Garage
    10. #288
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Penetrating oil, ratcheting wrenches, a Dremel if necessary
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    11. #289
      Nov 2015
      Tools are tools.
      Someone will always have nicer. Someone will always have worse.
      Knowing how to use the tools you have will be more important than what tools you decide to buy.
      The majority of my hand tools come from Harbor Freight and Iíve not had a problem doing any of my own maintenance.
      Blower motor failure is a common occurrence on these. A new quality motor will last you a long time. As easy as they are to pull, I usually keep my eyes peeled in the junkyard and grab a newer one when I see it.
      I look forward to updates
    12. #290
      Oct 2016
      Milwaukee, WI
      A taste of what's to come:
      Do I have to use the $8 a piece Volvo 8mm lock nuts for the exhaust manifold and downpipe? Or can I use something else because there's a part of me that's gonna be really sad if I need to buy $60 of only Volvo nuts.
      In the Garage
    13. #291
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      +1. YEARS ago I said I would go without shoes if my choice was red plastic if I wanted brown leather.
      Now, I might take those tools (I'm sure they weren't cheap) and work towards replacement over time to get what I ultimately wanted.
      Truth is just like John says. They're also YOURS and you don't have to borrow. I also have been following and like what I see!
      Tools are tools.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    14. #292
      Aug 2005
      Northern MD
      I know what I would do...
    15. #293
      Dec 2014
      Connecticut
      I would. The other options fall apart or gall during install....my downpipes only coming off with a dremel in the future.
    16. #294
      Dec 2014
      Indy, IN
      Belmetric has plenty of options for cheap. Either in copper plated.
      https://www.belmetric.com/regular-he...ead-p-183.html
      https://www.belmetric.com/conical-co...00-p-9433.html
      That second link for the "stover nuts" is what I bought a bag of 50 a while back, and have had no issues with them. (That listing shows a box of 300 for under $7. Yup 300 nuts for under $7)
      '97 854 T5 & '97 855 GLT(RN LPT swap/16T/ETC) (wife's)
      '78 264 (Future Whiteblock/T5 swap)
    17. #295
      Oct 2016
      Milwaukee, WI
      I bought a bunch of the bolts from the first link you gave me Chuck. Thanks!
      In other good news, the blower motor turned up, and after install everything is working! Reading my ECC codes, I only have two now: 2-3-1 (ventilation damper), and 2-3-3 (floor defrost). I am going to do the motor readjustment procedure because I rebuilt the floor motor, but maybe it's in the wrong position still.
      In the Garage
    18. #296
      Oct 2016
      Milwaukee, WI
      My work has been kind enough to close down during these odd times and pay me throughout the period we are going to be closed. Think Iíll tackle the oil pan seals now. Iíve been hearing things about the ďrevisedĒ pickup, what is it (part number) and is it alright if I donít replace it as I donít have one on hand?
      In the Garage
    19. #297
      Dec 2014
      Connecticut
      Volvo 30650552 is the pickup. You also need 2x water pump bolts (Volvo 985151) and the seal kit (Volvo 30750783).
    20. #298
      Oct 2016
      Milwaukee, WI
      Okay. Iím going to wait on the oil pan job then until later while the pickup is coming.
      Finally got the driverís side knee bolster back in place. The plastic behind the vinyl mounting tabs was destroyed, so I had an idea to cut up a mixing stick and superglue them in place to provide support. Holding so far.
      The exhaust showed up today. While I have plenty of time to install it, I'm quite eager. I can't figure out how the rear tailpipe section is oriented when installed, which way do I setup the hangers? If anyone has a Simons or similar exhaust please post it so my dumb brain can understand.
      When I was removing some of the turbo flange bolts today, I noticed this. Cleaned it up and tightened the hose, but is this anything to be worried about? Such as back-pressure of some sort from headgasket? No oil in the tank, just coolant but it was leaking from the overflow.
      In the Garage
    21. #299
      Dec 2014
      Connecticut
      The rear hanger goes on with the captive nut facing the ground. Two hangers are provided, one for stock exhaust tip one for the included cannon.
    22. #300
      Oct 2016
      Milwaukee, WI
      Got to work yesterday on the removal of the old, terrible exhaust.
      Great. Now I won't feel bad after trying to do a pull and stinking up the road.
      New to me angle flange housing and downpipe installed. Got a little late in the evening to disturb the neighbors when people are all home these days, haha. Going to be working on getting the new system in today.
      In the Garage
    23. #301
      Dec 2014
      Connecticut
      Just alerting you to the fact that your turbo to downpipe nuts are on backwards.
    24. #302
      Aug 2005
      Northern MD
      That new exhaust is pretty. Kudos to your workplace paying you. Make sure you thank them!
    25. #303
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by ZZZZZZZ View Post
      Iíve been lucky to speak with many of my managers directly on the subject. Because of the generosity on their part (and granted they were one of the first companies to pay their workers throughout this), I volunteered to work the skeleton shifts while we were shutting down. Thereís a weird feeling seeing everything being taken down around you.
      Anyways, got to work lining up the new exhaust this morning. I am 5 inches short, so I have to find some way to bridge this gap. My thought is some sort of pipe in halves that can be clamped together if people sell those.
      Another issue, the heat shield on the side of the gas tank fell off. The mounts disintegrated. Will I be able to get by until I get some heat wrap or something?
      Doesnít look too bad. End pipe is a little large for my tastes but maybe Iíll get used to it.
      In the Garage
    26. #304
      Jan 2014
      Boston, MA
      You can put the stock tip back on.
      Also rather low....need to massage the connections a bit to get it in the right place.
    27. #305
      Oct 2016
      Milwaukee, WI
      Unfortunately I never got the stock tip. From my previous photos that was all that was under the car. Iíll try to get it to go higher.
      In the Garage
    28. #306
      Jan 2014
      Boston, MA
      Oh. Nevermind then.
      I think this is what you want:
    29. #307
      Oct 2016
      Milwaukee, WI
      Wish I had one of those. Got the install finished with a temporary joiner. I need to find someone who can weld to get it connected permanently.
      Car started leaking oil as soon as I started it, couple drops every 30 seconds, I'm guessing it was either something to do with the turbo oil banjo bolt or the turbo drain return tube. I snugged the bolt down pretty good so we'll hope it's not the banjo bolt. Got it back to storage and grabbed the daily for now.
      In the Garage
    30. #308
      Oct 2016
      Milwaukee, WI
      Since the Governor decided to lock down the state, I figured I better go back and grab the project in case there are things I can do on it.
      Got a cheap O2 sensor in the exhaust for the moment, going to an OEM sensor once I pass emissions. Think the old one was destroyed?
      Remounted the tailpipe as well, using the stock bracket. It's not touching, but its gonna get burned if I leave it like this. Gonna try to bend the bracket a little lower.
      So now when I start the car I have a pretty good oil leak. Methinks it's the oil line as pictured, and the rear motor mount below is covered in oil as well as the back of the front subframe and oil pan. Any thoughts?
      It's the only thing I messed with during the exhaust install so that has to be it. I have a whole bunch of gaskets arriving on Thursday.
      When it rains it pours... coolant that is. Found this on the passenger side. Stock Volvo radiator for replacement?
      In the Garage
    31. #309
      Nov 2015
      I have Nissens in both my 850Rs. I have an all aluminum DO88 I bought and later found out are often unreliable, so Iím torn as to whether I am willing to have the DO88 pressure tested and use it, or just not risk it.
      Throwing away a $400 radiator is cheaper than doing a head job I suppose if it fails....
      But a lot of people go OE. You probably should look at the heater core, firewall junction and all 8 coolant hoses at the same time.
    32. #310
      Jan 2014
      Boston, MA
      The revised oil pickup is not compatible with the N pan
    33. #311
      Oct 2016
      Milwaukee, WI
      Thanks for the info, Jared. Seems I've ordered the wrong metal gasket for an angle flange downpipes, it was far too small. Does anyone have the PN for it?
      Decided to do the rear brakes before the weekend. This is probably the most I've been ashamed of my ignorance in fixing cars, I should've checked this earlier. Parking brakes need some love still, waiting on the parts.
      Because that gas tank heat shield fell off, and I don't feel like being the human torch before halloween this year, I did what I could with heat wrap. After a short drive I checked the temp in that area and it seemed nominal.
      This weekend finally came, however the rest of the repairs were put off by the family P1 car, my brother's C70, needing a brake job. Easiest I've done in a while, except for the fact that everyone sells three different size of rotors and nowhere knows which were specific to the C70 or model year.
      Got to the turbo gaskets today, and now that I have some ratcheting wrenches it's much easier to get at those manifold to housing bolts. Got everything apart in about an hour, and back together in about two, with cleaning of the tube a little as well as the other surfaces on the block. It got oil EVERYWHERE.
      Again, ordered the wrong gasket for the drain line. It fix the holes perfectly, but I didn't want the little tail on it. Cut it down, I thought I did pretty good.
      As you can see, the old bottom drain gasket was destroyed, but I think it was the top and bottom causing the leak as the top was full of oil too.
      I put all the bolts back on the correct way this time, just for ScottishBrick lol.
      Forgot to mention, the turbo feels really nice and tight from the rear, no play that I could see. However that may just be from how it's mounted, or idk. Either way it's getting a new CHRA eventually.
      With all this pandemonium, I've been pretty anxious lately. This has been a welcome getaway from that, even if I never left the house.
      In the Garage
    34. #312
      Aug 2005
      Northern MD
      Whatís under the cover on the left?
    35. #313
      Dec 2014
      Connecticut
      Turbo to DP Gasket PN 8642449
      The "tail" on the return drain upper gasket is so you can slide it in with the drain tube in its proper position.
    36. #314
      Oct 2016
      Milwaukee, WI
      That's the next project, which I may get to this week. 1977 Triumph Spitfire 1500. Needs the water pump housing replaced.
      In the Garage
    37. #315
      Oct 2016
      Milwaukee, WI
      Quote Originally Posted by ScottishBrick View Post
      Ah, well, the more you know. It looked really similar to the oil pan gaskets, albeit thinner of course.
      In the Garage
    38. Remove Advertisements
    Similar Threads
    1. My Atacama seat restoration (before & after) + trim restoration
      By itsmeee in forum R Forum (2004-2007)
      Last Post: 12-16-2014, 12:52 AM
    2. 1996 Volvo 855 TurboWagon
      By mrsharp in forum FWD & AWD Cars For Sale
      Last Post: 06-02-2013, 10:59 AM
    3. feeler- will sale if there is intrest- 1996 volvo 855 GLT
      By robdeselich in forum FWD & AWD Cars For Sale
      Last Post: 05-25-2007, 03:32 PM
    4. My 1996 Volvo 855 on ebay!
      By 1999_V70 in forum FWD & AWD Cars For Sale
      Last Post: 05-10-2005, 09:49 PM
