V70R Aftermarket subwoofer install in factory subwoofer location
    Results 1 to 23 of 23
      Member
      May 2016
      Fairfax, VA
      Problem:
      -Wanted a bit more bass
      -Didn't want a box eating up cargo space
      -Not looking for spl numbers
      Solution:
      Subwoofer: Dayton Audio 12" low profile 4ohm DVC
      Amp: Sound Ordinance M350-1
      Install kit: Audtek Electronics AWK8
      Total Cost:
      I was only going to use one sub, so I went with the 12". However, I THINK you can fit two 10" subs in that space and keep the cargo tray (tray needed to act like a box).
      Keep in mind that I KEPT the stock cargo tray. however, I may need to fab something up so it seals the subwoofer better, as the air passing around the sides is hurting performance. I'll likely end up just using weatherstripping around the entire edge of the cargo tray.
      UPDATE: Used some rubber foam weatherstripping to "seal" the tray to the underside of the cargo cover. Cover still sits flush with the floor, so that's good. Also, the Lloyd carpet may I had on top of it was sealing the face of the sub a bit too much, which was causing this flutter/rattling sound that ended up being the mat itself. Removed the may from covering the sub and everything is perfect now. AutoEQ on my Pioneer head unit will automatically adjust the EQ settings for all the speakers as well as the sub, set crossover points, and time delays. The biggest thing is setting the EQ and time delays. System sounds amazing now!
      The sub box packaging can be used as a nice template to figure out where you want to cut your hole.
      Once a good location was found, I used another piece of cardboard to center the hole I was going to drill for my circle cutter tool. (Hint: the Black & Decker RTX is more powerful than the dremel, and has a threaded collar so it'll fit in all the dremel accessories).
      Not the best cut, but the best I could do w/o *real* tools. Sanded the inner edges smoother. Nobody will see this anyways, since I'll have a carpeted mat on top of it.
      Perfect fitment!
      Pic of where I mounted the amp. Everything fits with the cargo tray (see below).
      Amp power wiring. I used less than 2' of each cable, and the fuse tucks nicely under the battery holder bar.
      Had to trim the factory box slightly in order to make clearance for the cables. Turn-on and RCAs were also routed through this same hole, which I ahd to cut even deeper to fit the extra wires.
      Sounds good so far, but I can't really turn it up too much yet. Need to seal that cargo tray better or else all the air moving past it causes all sorts of flutter/vibration sounds. Running infinite baffle (tray removed) doesn't work too well either, as these subs aren't really made for that.
      '06 V70R TiKap
      VMR V801 18x8.5
      Member Body Massage's Avatar
      Aug 2008
      Bellingham, MA
      Ooooh, you did a way better job than I
      2005 V70R
      2010 C30 R-Design
      Dec 2015
      Where the pictures at
      SwedeSpeed.com
      Junior Member ari951's Avatar
      Nov 2010
      Florence Kentucky
      2004 S60R MT | Black Sapphire/ Gobi | factory aero body kit | painted grill | painted headlight bezels | custom R badge front grill | 18" two tone metallic grey/black pegs | smoked tail light lenses | 20% tint | USA spec ipod interface | integrated subwoofer system | EBD delete | DEM heatsheild |http://picasaweb.google.com/10580646...NevjZSB6N72mgE
    7. #5
      Member
      May 2016
      Fairfax, VA
      Quote Originally Posted by Zanteiro View Post
      They load fine for me... hosted on imgur.
      '06 V70R TiKap
      VMR V801 18x8.5
    8. #6
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by aznatama View Post
      Problem:
      Solution:
      Total Cost:
      Perfect fitment!
      Donít forget about mid-bass.... a couple of JL 6W3v3-4 subs in the doors do an awesome job handing the 50Hz - 500Hz void!
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
    9. #7
      Member
      May 2016
      Fairfax, VA
      Quote Originally Posted by Austin V70R View Post
      I'll see what happens after I do a bit of tuning when I have the time. Not sure what the stock system effectively goes down to though. Also not looking to do too much more to my active sound setup...
      '06 V70R TiKap
      VMR V801 18x8.5
    10. #8
      Jan 2012
      Santa Cruz, Ca
      Does your thread have photos? I donít see them if so
    11. #9
      Jan 2012
      Santa Cruz, Ca
      Are you running a stock deck and amp?
    12. #10
      Member
      May 2016
      Fairfax, VA
      Yes, hosted on Imgur. Let me check the settings, but seems like BodyMassage can see them?
      Aftermarket HU (Pioneer 4200NEX) and factory amp.
      '06 V70R TiKap
      VMR V801 18x8.5
    13. #11
      Jan 2012
      Santa Cruz, Ca
      Good setup.
    14. #12
      Member CKAVolvo's Avatar
      Dec 2009
      Healdsburg
      Great install but please add more detail of how you handled the crossover points, and how you interfaced with the factory system. What would be interesting is to add a second speaker 180 deg out of phase to do a bit of noise canceling with out adding tomuch weight ?
      2006 V70R Black GT 377 awhp TME Exhaust, Girodisc 2 piece rotors IPD Sway bars, HD end links, Strut Brace, Poly engine mounts EST CAI, Silicone hose kits, SNABB intake, IPD HO coils,Enem Y21, CamsRaceS60R FMIC,Majestic Hybrid Turbo, HFS-4 water meth ElectronicsSPA digital Boost/EGT, ScanGauge II, Bel STiR ,Laser Interceptor HD front jammer, Mobileye collision avoidance system , LED interior lighting, ImiV, 2 USB, AARP member,
    15. #13
      Member
      May 2016
      Fairfax, VA
      Quote Originally Posted by CKAVolvo View Post
      I have a pioneer 4200nex, not factory hu. But you can easily splice RCAs to the factory harness at the amp and run the turn-on and rcas from there.
      Crossovers can usually be adjusted on the amp itself, as most sub amps will have a built in adjustable lpf. I can also adjust the crossovers on my hu.
      Why would you cancel out your own speaker output? O.o I'm not sure I understand.
      Sent from my F8332 using Tapatalk
      '06 V70R TiKap
      VMR V801 18x8.5
    16. #14
      Jan 2012
      Santa Cruz, Ca
      Now youíre getting interesting Ron... you need two sub channel speakers operating at approximate the same cut-off point to effectively noise cancel. Unfortunately this requires two sub channel amplifiers and multiple speakers.
      My setup is mildly complicated (not sophisticated) and will partially accomplish noise canceling. I have a JL 700W, 5 channel amp (100W for four main channels + 300W dedicated sub channel), and a 600W dedicated sub amp.
      Ignore the four main channels, the 300W channel is driving two JL 6.5Ē subs in the rear doors (barely fit) with a 50Hz high pass and 300Hz low pass, while the 600W is driving a 10Ē Alpine R-Type with a 30Hz high pass and 100Hz low pass.
      These are 180 degrees out of phase controlled by the Pioneer deck.... itís bot perfect, but out of phase operation definitely eliminates some unwanted cabin noise.
    17. #15
      Member
      May 2016
      Fairfax, VA
      Oh really? How does that cancel out cabin noise? Guess I'll need to do some research now...
      But first, I need to figure out the volume of my cargo tray... And also shove some poly filling in there.
      '06 V70R TiKap
      VMR V801 18x8.5
    18. #16
      Jan 2012
      Santa Cruz, Ca
      The noise canceling concept is simply to enjoy the low end frequency response without addition of noise the muddies the sound stage.
    19. #17
      Jan 2012
      Santa Cruz, Ca
      It doesnít cancel cabin noise, but thatís also a very cool idea.
      https://m.youtube.com/watch?v=UyN1TACCbHE
    20. #18
      Feb 2017
      LOL
      But why raping the panel with a hole?
      Subwoofers don't need that
    21. #19
      Member
      May 2016
      Fairfax, VA
      Quote Originally Posted by Vasquez View Post
      LOL
      Because sealing a sub in a box doesn't do anything. I'm using the tray as a box, and the panel is part of that box. A sub still needs an enclosure.
      Besides, it's just a piece of plywood. I wanted to get some mdf to replace it, but the curved shape would've been too difficult to match.
      '06 V70R TiKap
      VMR V801 18x8.5
    22. #20
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Agreed. A sub needs to breathe. This looks interesting, so I may grab a floor piece from the yard and try something like it.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    23. #21
      Member
      May 2016
      Fairfax, VA
      This particular sub supposedly acts like a 10", and works well in a 0.8~1.3 cu. ft. sealed box. Perfect for the tray-box. Lol.
      I still need to seal it though.
      I'm thinking that I could use the stock door speaker frames and fit some dayton 8ohm reference speakers in those, and everything I'll work with the stock wiring. =D. But that's a rather large project. =/
      '06 V70R TiKap
      VMR V801 18x8.5
    24. #22
      Jan 2012
      Santa Cruz, Ca
      These fit perfectly in the stock door holes.
      http://www.jlaudio.com/6w3v3-4-car-a...-drivers-92145
    25. #23
      Member
      May 2016
      Fairfax, VA
      I'll look into these, but they seem pricey. Will it work with stock amp though? Seems like stock amp might be a bit underpowered for these. Really looking for plug and play on the car - side. I gave a set of speakers that I can mod first before tearing apart the car.
      '06 V70R TiKap
      VMR V801 18x8.5
    26. Remove Advertisements
