Power tap for radar detector at the rear view mirror area?
15K views 16 replies 12 participants last post by  aspexil828
I'm planning to hardwire my new Uniden R3 radar detector. I see old threads about running the hardwire across the headliner, down the a-pillar, and over to the passengers side of the center console. This seems pretty cumbersome. Has anyone tapped into any of the wiring under the rearview mirror/sunroof/courtesy light/intellisafe panel?
Sent from my Galaxy S9 using Tapatalk
Search is yo friend.
I did search and all I found was running the wiring down to the center console. What search terms are you using? I searched for "hardwire radar detector XC90".
Cool. What wire(s) did you tap into? I don't have a wiring diagram available. I'd guess maybe the courtesy lighting and sunroof are driven off a control module rather than straight 12v power?
Blendmount sells a hardware mirror tapping kit specifically for different radar detectors.
I don't think hardwiring to the centre console makes any sense when the fuse box is available. That's what did: I just hardwired my V1 to the fuse box with an add-a-circuit fuse connector.
#14 ·
I installed my radar detector in my NSX rather than the Volvo XC90. I had the same concerns about running the wire all the way to the fuse box. I did not want to deal with the airbag so connecting with the upper console or mirror seemed the best way to go. I purchased the splicing wire kit via Amazon. That allowed me to splice into a wire that becomes hot when the car starts. So I avoided having to pull all sorts of components to gain power. I purchased this mount for $35: https://www.amazon.com/gp/product/B0063N7HZE/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 and the splice was $17: https://www.amazon.com/gp/product/B082V1245P/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
Keep in mind that the mount was radar unit specific. So check to insure that your unit will work. Same goes with the electrical hookup. I wanted a splice that was a bit longer than was offered by others. The system is rock solid thus far. I used to transfer the radar unit from car to car but now just keep in the NSX which draws a lot of attention. If I add another I will do the same with the XC90. Keep in mind the radar detector can draw a bit of current.
