JaredR's 2007 S60 T5 M66 - Page 10
    Page 10 of 11 FirstFirst ... 6 7 8 9 10 11 LastLast
    Results 316 to 350 of 372
    1. #316
      Dec 2016
      Hamilton
      I've got one but don't use it because the foam insert died and gets dusty crap all over my sunglasses. Is there a replacement part? What else could I use?
      Try using the window/door sill edging sticky foam. Few strips could fix it. Iíve had one since 2005 and havenít had an issue with foam. I have two of those in my car, one side each.
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Interesting mirror surgery. Like the idea and it looks like it was successful, but I'll leave mine alone..
      I am hyped to drive this car with usable visibility. I hated driving this thing on the highway because of that mirror. Haven't driven it yet though still need to bleed the brakes lol. Hopefully todaay.
      I will fill the hole with something eventually. Not a priority at the moment. Original idea was to sand it down but it started melting. Inside has to be trimmed away more since it is closer to he mirror and therefore a worse obstruction. Basically it is a mess no mater what but oh my the improvement is stark.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 138k.
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    4. #318
      Aug 2005
      Northern MD
      Maybe wet sand I guess to avoid melting? What a mess that would be.
      I guess I have added visibility because...wagon. Peripheral is also key with that. The S does have massive visibility issues with that massive C pillar and sloped roof.
      Apr 2015
      So Cal / Inland Empire
      Quote Originally Posted by Oliovlov View Post
      Mastic tape (not masking tape) comes to mind as well, that stuff would be great for that I think. I've used some for things on my S60 such as lining the center console cup holders with it.
      Sent from my Huawei Mate 9 using Tapatalk
      2004 S60 2.5T - Stock for now...
    7. #320
      Jan 2014
      Boston, MA
      I don't think that's the issue. The issue is that whoever designed this mirror housing apparently never read the SAE mirror guidelines so, if you adjust your mirrors to the SAE guidelines, half of the convex part is completely useless.
      Quote Originally Posted by Phixion View Post
      Interesting idea. I'm also thinking of just filling it with something and painting. That would probably look best. Doesn't have to be strong just has to stay there.
    8. #321
      Aug 2005
      Northern MD
      Iím going to have to look up mastic tape, but i think he meant for the sunglasses holder?
    9. #322
      Apr 2015
      Yes yes. But it could work for eons of things.
    10. #323
      Jan 2014
      Boston, MA
      oh. LOL. Dangers of surfing SS on my phone.
    11. #324
      Apr 2015
      Pittsburgh, PA
      Is it because the US never got the convex mirrors so it was never an issue?
      2006 & 2007 XC70
      Previous: 2006 S60R, 1999 F250 Powerstroke, 2005 TSX, 1997 Bonneville, 1998 Concorde
    12. #325
      Jan 2014
      Boston, MA
      Quote Originally Posted by R-Pow3R3d View Post
      It makes the issue more noticeable. DOT mirror has the same issue but the portion of the mirror that is blocked doesn't do much, unlike the ECE mirror. I'll be able to see things off my B pillar now. Before I was doing good to see things off the aft corner. With a DOT mirror, I would have crashed by now lol.
    13. #326
      Apr 2015
      Pittsburgh, PA
      If that would have made you crash, you might want to pay more attention. lol
      2006 & 2007 XC70
    14. #327
      Jan 2014
      Boston, MA
      Lol the issue is I got spoiled growing up in P80s with ECE mirrors. Visibility is so good. There are no blind spots; I never have to turn my head around to change lanes/merge/etc. Then you get to a P2 and there are blind spots.....
    15. #328
      Apr 2015
      Pittsburgh, PA
      That's fair. I'm so far down the P2 rabbit hole, I'm not even sure which way is up. LOL
      (Speaking of, I need to update my signature...)
      2006 & 2007 XC70
    16. #329
      Aug 2005
      Northern MD
      Blind WALLS.
    17. #330
      Letís put a euro mirror on the 740. Itíll change your perception of reality. Literally.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    18. #331
      Apr 2015
      Pittsburgh, PA
      I mean...I'm driving it almost daily ATM (well, as often as I drive...which is barely twice a week). I'd be happy to make that upgrade.
      2006 & 2007 XC70
    19. #332
      Do it. Aka want me to get one?
    20. #333
      Apr 2015
      Pittsburgh, PA
      What do they run and is it an easy swap?
      Actually need to do my 04VR, as well, and wanting to get Volvo Euro glass for it.
      2006 & 2007 XC70
    21. #334
      Member Exocet's Avatar
      Southern Tier NY
      I've never had any issues with the P2 mirrors, either DOT or the Euro spec. I've had vehicles with worse. From where I sit, I have no side visibility issues. I might lose the outer 5% of the field of view with the convex mirrors. Not enough to cause issues for me.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    22. #335
      Iíll check $ wise. Pretty cheap usually. Super easy install on the p2, possibly involved in the 740 depending on type of mirror base.
    23. #336
      Jan 2014
      Boston, MA
      Lighting proof of concept. I'll spare you from the grizzly pics of the housing carnage. They look bad. But the results are excellent. Now to enjoy for the weekend and then find a way to cleanly execute. I have some ideas.
      All photos shot on my Nikon D700, 50mm 1.4 AF-D at 1/100 sec, f/4, ISO 2500. Car did not move between photos. I just did these across the padays and forgot where I stood the first time lol.
      Original ABL Low
      D2S 5.0 Low
      Original ABL High
      D2S 5.0 High + LED real high beam (I used ECE ABL for this which have a real high beam instead of a DRL)
      Original ABL High + Driving Lights
      I think I am gonna need to step up my driving light game, but my neighbor came home and parked in front of the fence before I got the bumper back on so we will have to wait and see.
    24. #337
      Southern Tier NY
      Wow. No comparison.
    25. #338
      Aug 2005
      Northern MD
      Thatís probably an increase of 60-70%. Looks fantastic!
      Quote Originally Posted by Exocet View Post
      Wow. No comparison.
    26. #339
      Well hereís ABL compared to D2S5 in the highly scientific volvo lighting laboratory....
    27. #340
      Aug 2005
      Northern MD
      Yeah, I remember those pictures too. Killer.
    28. #341
      Jan 2014
      Boston, MA
      Not what I wanted to see 30 minutes into the trip lol
      Luckily was a bogus code. Cleared and carried on.
      T5M party
      Went to warranty some stuff at FCP. SondcBlueR randomly rolled in while we were there too lol.
      Solid parking place at destination #1....
    29. #342
      Apr 2015
      Pittsburgh, PA
      Oh, that's not a bogus code...that's your throttle body wearing out... You've got some time if it's the first time you're seeing it, but it will need replaced.
      https://forums.swedespeed.com/showth...Signal-Too-Low
      2006 & 2007 XC70
    30. #343
      Jan 2014
      Boston, MA
      Well that's good to know. Good thing I have a 50k mile ETA at home.
    31. #344
      Apr 2015
      Pittsburgh, PA
      Just to confirm. These P2's are the later throttle body, not ETM. This is what you need (or the Bosch equivalent):
      Volvo 30711554
      https://www.fcpeuro.com/products/vol...-body-30711554
      2006 & 2007 XC70
    32. #345
      Jan 2014
      Boston, MA
      Volvo 30711554
      Yes that's the one I have on hand. Came with my B5234T9
    33. #346
      Jan 2014
      Boston, MA
      137k.
      Uh oh here we go again.
      Hmmm wonder if it's maybe just pissed about the voltage. Cleared and we shall see if it comes back on the way home.
      Well one of lights is pointed at the street but I think one D2S 5 is putting out more than I was getting from the ABL.
      And OMG it's insane with everything on. Even with one of them pointed at the street.
      When you're visiting your history major friend who's making 3x as much as a bartender than you are as an engineer
      Snagged the last driveway spot nobody else dared attempt to use lol.
      Back to lighting again.....adjuster pulled out.
      I wanted to find a clothes hanger to fix it but apparently there are no metal clothes hangers in Charleston. So I used a twig and some e tape I had been using to patch a hole I had to cut in the back of the housing.
      Looks good. Let's see how long that twig stays there lol.
    34. #347
      Nov 2002
      Russell Twp, OH
      I used to beg my folks to stop and see Pedro at SoB. After a half dozen or so trips down that way my folks finally said "yes" and I have to say the best part was that sign from the highway, lol.
      Have a nice trip and happy motoring!
    35. #348
      Jun 2012
      Tidewater, VA
      Lol, I had no idea you were headed down to SC - think I parked next to you Friday afternoon at the rest stop south of Fayetteville, NC (in the Oyster Gray XC90 V8). Saw the T5, MA tags and thought, ďHmm what are the odds thatís Jared? Nah, he wouldnít be this far south.Ē
      We were in Charleston yesterday, Hilton Head now until the morning then head back home.
      BD
      Current Fleet:
      1998 S70 Base (New project), 2006 S40 T5 M66 FWD, 2008 C70 Premium Plus M66, 2011 XC90 V8, 2013 C70 Platinum P*
      RIP:
      1994 854T FWD, 2004 XC90 2.5T AWD, 2005 S60 2.5T FWD
    36. #349
      Jan 2014
      Boston, MA
      Quote Originally Posted by 88domer View Post
      BD
      Yes you did! I remember that XC! But hey what is a road trip without randomly encountering another SSer. Would have been fun to meet you but you never know where I might turn up next haha. I'll be heading back in the morning, too....
    37. #350
      Member Chicago_Wagon's Avatar
      Jan 2016
      Chicago, IL
      Okay, that's just nuts. Last time it was Will in Florida. Now you guys. What are the odds, indeed.
      Current - 2000 V70R Venetian Red Pearl
      Past - 1998 V70 XC Emerald Green Metallic
      RIP - 1987 Mazda RX-7 White/Red (first car, many speeding tickets, blown rotary engine)
