Project S60 Whelpling
    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 35 of 120
      Oct 2018
      Minsk, Belarus
      Hi мy name is Oleg, I am from Belarus. Spec sheet of my car:
      - K24 turbo
      - Siemens Deka fuel injectors 630 cc
      - front mount IC
      - 76 mm downpipe
      - 56/63 mm intake w/ K&N filter
      - Aeromotive fuel pump 320 l/hr, fuel pressure regulator in loop with intake air pressure, fuel pressure is 3 BAR relative (have no clue what that means)
      - M66AWD gearbox (swapped, was AW55) with heavy duty clutch
      - MAF AUDI S4
      Google translator, does not translate very well, so if something is not clear, I apologize in advance.
      The plans were to leave 13 sec 1/4 mile, but the plug in the box broke, so next year I will do it). If interested ask questions I will answer.
      К24 Turbo
      M66AWD custom grip (UP 600+ Nm)
      76 mm
      Volvo s60 2,5 AWD 2004, 1/4 mile 12,18 187 km / h
      Oct 2018
      Minsk, Belarus
      Customized the car from Robert Hilton tuning. The setting turned out great. Motor drain B5254T2. The results I posted in this thread https://forums.swedespeed.com/showth...-or-vids/page2 1/4 miles 13,09 seconds.
      As you can see from the video at my start, the engine cushion cable tears and the upper cushion bracket is oppressed.
      Start and slip when shifting gear 1-2
      Nov 2017
      Welcome! Nice build so far!
      Sent from my ZTE A2017U using Tapatalk
      SwedeSpeed.com
      Oct 2018
      Minsk, Belarus
      I trained to quickly change gears in order to reduce the switching time from 0.4 seconds to 0.3 seconds and due to this I reduced the time 1/4 of a mile to 13.09 seconds. But then the fork broke in the M66 box and the 1st and 2nd gears were gone.
      If it were not for this breakdown, I would drive less than 13 seconds. And it is on gasoline. And then I was planning to buy the E85 program and it would be even faster))
    7. #5
      Oct 2018
      Minsk, Belarus
      In order to make the course of the scenes shorter, we extend the lower part. And the upper part is shortened by 1 cm (photo did not). As a result, we get more pleasant and short switching. These actions allow us to reduce the switching time by 1/4 mile by almost 0.1 seconds, without increasing the engine power.
    8. #6
      Oct 2018
      Minsk, Belarus
      Hi, today took off the turbine and found a crack there. Therefore, I want to put a more reliable turbine.
      1. BorgWarner EFR 7064 https://www.full-race.com/store/gara...-7064-turbo-2/
      2. BorgWarner EFR 7670 https://www.full-race.com/store/borg...-7670-turbo-2/
      It is interesting to know your opinion.
    9. #7
      Oct 2018
      Minsk, Belarus
      fix the engine
      hang M66
      Omit
      That is the reason for the absence of 1 and 2 gear
    10. #8
      Oct 2018
      Minsk, Belarus
      Clutch traveled 15 thousand km. There were a lot of starts from 5000-7000 rev / min. Excellent condition.
      For rigidity used glass sealant.
    11. #9
      Oct 2018
      Minsk, Belarus
      Hot part +5 mm
      The cold part 11-0 71 mm
    12. #10
      Oct 2018
      Minsk, Belarus
      Anyone who can not start in the summer on asphalt))
    13. #11
      Oct 2018
      Minsk, Belarus
      Need to remove dirt
      264/110/9.6/0.8 Camshafts -200$
      insert
      I will continue to collect motor 450+ hp
    14. #12
      Member T501's Avatar
      Mar 2005
      Florida
      Awesome build!
      David - '01 S60 T5 GT 207K+ miles OWNED SINCE DAY ONE - Bilstein Sport + TME, ipd sway bar + endlinks, UR chassis braces (upper F+R), Powerslot /Akebono pads, Snabb Intake, iMIV Original engine, transmission replaced at 78k miles
      Wife -'13 C30 T5 R-Design 73k+ miles Dad - '98 S70 T5 210k + miles, Bilstein TCs, IPD HD rear springs, SAS delete Mom -'10 S80 V8 Executive Sis - '02 S80 T6 Backup car -'13 S60 T5 (Not as fun as my '01)
      Past
      '95 850 '92 960
    15. #13
      Oct 2018
      Minsk, Belarus
      Quote Originally Posted by T501 View Post
      Awesome build!
      Thank you!
    16. #14
      Oct 2018
      Minsk, Belarus
      Put rods bought https://www.ebay.com/itm/CXRacing-H-...1%26algo%3DREC .SEED% 26ao% 3D1% 26asc% 3D20140107095009% 26meid% 3D5bfaa3e79f7240e79b5fcfbdca22f2e9% 26pid% 3D100040% 26rk% 3Ds2% 26rkt% 3D2% 26sd% 3D181218054073% 26it, i'm working for you, i'm working
      c100040.m2060
      And they were a little more
    17. #15
      Oct 2018
      Minsk, Belarus
      As it turned out, the seller sold me 147 mm connecting rods, as I ordered, relying on information from VIDA and https://www.vivaperformance.com/forg...ng-rods-147mm/. But this information is erroneous, the connecting rod on the B5354T2 motor has a length of 145 mm, I disassembled one more motor and checked this information, and also traveled to break down the machines.
      To reduce the thermal load on the motor, I put the old thermostat case and the thermostat itself at 82 degrees.
      The temperature sensor had to be taken with a chip on the wires in order to properly wear the nipple.
      All the ventilation pipes of the PCV crankcase gases were removed, and plugs were installed instead. From the PCV tank, release to the atmosphere was carried out with a 18 mm diameter hose
      Camshafts I polished off the S60R and most likely that is why I have an ECM-644A error, and the air flow at idle speed is 20 kg / hour.
    18. #16
      Oct 2018
      Minsk, Belarus
      The problem with errors is solved.
    19. #17
      Junior Member Verheichyk's Avatar
      Aug 2017
      Russia, Nizhny Novgorod
      Гонка
      Отправлено с моего iPhone используя Tapatalk
    20. #18
      Oct 2018
      Minsk, Belarus
    21. #19
      Member
      Jun 2011
      Congo
      Quote Originally Posted by Laguna1 View Post
      just so you know this is normal and ok to run...well , normal for volvo k24. lol
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
      1997 Avalon - gone - son - space-force
    22. #20
      Member
      Jun 2011
      Congo
      who's the tuner?
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    23. #21
      Oct 2018
      Minsk, Belarus
      Quote Originally Posted by dougy View Post
      who's the tuner?
      I have not set up the program yet. Just put the water meter and decided to set the threshold for its inclusion.
      After that I wanted to tune with Robert. Here I am guilty, I spun up the engine to 4000-4500 rpm
    24. #22
      Member
      Jun 2011
      Congo
      ahh i see...use Gustav/ aka contrast here on ss... he pays waaay more attention to detail than hilton...https://urbastuning.wordpress.com/
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    25. #23
      Oct 2018
      Minsk, Belarus
      Ок. Robert suits me.
    26. #24
      Oct 2018
      Minsk, Belarus
      Bought a motor from Japan with 60k km mileage
      Parse and look at the state
    27. #25
      Oct 2018
      Minsk, Belarus
      High performance hybrid and was the cause of death of the motor). Although the usual hybrid, he had to withstand one race, even at the old setting
    28. #26
      Aug 2018
      Minsk, Belarus
      Hello from Minsk)))
    29. #27
      Member
      Jun 2011
      Congo
      still waiting on these impressive results ..
      https://www.youtube.com/watch?v=DilByCunXjw
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    30. #28
      Oct 2017
      UK, EMSWORTH HAMPSHIRE
      Hi what was the boost set to in the ECU Tune,
      Dave
    31. #29
      Aug 2018
      Minsk, Belarus
      Oleg's engine was failed due to cranked liners on piston rods.
    32. #30
      Oct 2018
      Minsk, Belarus
      I havenít written for a long time, there were problems with the motor, but now we have continued tuning. This is an interim boost result of 1.4 bar. Setup will continue
    33. #31
      Oct 2018
      Minsk, Belarus
      Quote Originally Posted by davebb View Post
      Dave
      While 1.4 bars then we will raise. Hilton tuning
    34. #32
      Oct 2018
      Minsk, Belarus
      Не устал ещё?))
    35. #33
      Oct 2018
      Minsk, Belarus
      Fuel 94 (100 Euro) gasoline and water methanol. Setup continues
    36. #34
      Oct 2018
      Minsk, Belarus
      Performing hard starts, he broke the corner gear. Now we need to strengthen it so that it can keep the torque at the start.
    37. #35
      Oct 2018
      Minsk, Belarus
      Iíve almost finished setting up with Robert, but because of the cool weather I canít catch the road, there is a strong slipping. But still, the car turned out to be faster than the Volvo S60R)
    38. Remove Advertisements
