Project S60 Whelpling - Page 4
    Page 4 of 4 FirstFirst 1 2 3 4
    Results 106 to 120 of 120
    1. #106
      Oct 2018
      Minsk, Belarus
      Boost is not a measure of power. It is important to fill the cylinders with air. Otherwise, the boost grows in the reservoir, but not in the cylinders. Install camshafts with a higher lift and wider phase
      Volvo s60 2,5 AWD 2004, 1/4 mile 12,18 187 km / h
      Jul 2017
      Thailand
      Quote Originally Posted by Laguna1 View Post
      Could you explain for about that? What camshaft? Higher Lifter and Wider phase. Where can I find it?
    4. #108
      Oct 2018
      Minsk, Belarus
      Quote Originally Posted by akeker View Post
      We rework two camshafts costs $ 200. Phases and climb can be seen here.
      https://www.drive2.ru/l/520569003924521383/
      In order not to risk it, I bought R-axial shafts and sent them to Moscow. In response, they sent me something that is not present anywhere (at least I did not find it), namely their characteristics:
      standard shafts
      designation EB425
      9.0 mm
      thermal clearance up to 0.5 mm
      phase with a gap of 0.50 mm 248 degrees
      phase with a gap of 0.25 mm 280 degrees
      phase per 1 mm with a gap of 0.25 mm 208 degrees
      rise in TDC with a gap of 0.25 mm and a collapse of 110 degrees 0.5 mm
      designation IA422
      8.4 mm
      thermal clearance up to 0.4 mm
      phase with a gap of 0.40 mm 236 degrees
      phase with a gap of 0.25 mm 254 degrees
      phase per 1 mm with a gap of 0.25 mm 196 degrees
      rise in TDC with a gap of 0.25 mm and a collapse of 110 degrees 0.3 mm
      cam 32 mm, neck 30 mm, i.e. when resurfacing,
      with a cam diameter of 30.2 mm, a maximum lift of 9.9 and 9.3 mm can be obtained, respectively.
      I decided not to be smart and ordered characteristics close to those that Viva does:
      9.6 / 264 issue
      9.3 / 264 intake
      the profile will have a phase of 264 degrees with a gap of 0.25 mm on vp and vyp
      rise in TDC, with a collapse of 110 degrees will be 0.8 mm, with a gap of 0.25 mm on the VP and vyp.
      https://www.drive2.ru/l/519146510756086520/
      Oct 2018
      Minsk, Belarus
      The car began to move on FWD
    7. #110
      Oct 2018
      Minsk, Belarus
    8. #111
      Jul 2017
      Thailand
      Sound Crazy. How far is the project now? I really like that custom exhaust manifold
      S60T5|Stage 3|E85|Fuel Return System|Anti Lag Tune with Hilton|Snow Performance Meth|Catless|FMIC|Custom 3.5 Inch Down Pipe|3 Inch Exhaust|K24 Hybrid Turbo|18 Inch Heico Wheel|Fuel Surge Tank Nuke Performance|AEM AFR Gauge|2 Walbro 445 in Surge Tank|Aeromotive in tank|Aeromotive Fuel Regulator
    9. #112
      Oct 2018
      Minsk, Belarus
      This is a long project, I hope to finish by the end of summer. On the video, the car without a silencer, so such a good sound)
    10. #113
      Oct 2018
      Minsk, Belarus
      What Volvo could not before: Slipping all 4 wheels
    11. #114
      Oct 2018
      Minsk, Belarus
      Launch control 5000 rpm 0.8 bar, as a result, the rear axle shaft has broken
    12. #115
      Jul 2017
      Thailand
      Oh My Goodness. What kinds of Turbo? What is the next step?
    13. #116
      Oct 2018
      Minsk, Belarus
      The turbine costs the same as you bought. It's just that full torque was transmitted to the rear axle of the car. Haldex coupling 4
    14. #117
      Oct 2018
      Minsk, Belarus
      At 7800 rpm, the thrust bearing flew off the valve
    15. #118
      Jul 2017
      Thailand
      Oh That is suck!!!!!!! Do you unlock rev limier? Actually, It would Rev limit 7200 RPM.
    16. #119
      Oct 2018
      Minsk, Belarus
      The part that breaks from the Volvo, and the part that does not come from the WV. So, minus three axles. It remains to do one more and you can use the launcher control
    17. #120
      Oct 2018
      Minsk, Belarus
      We have been tormenting the car for almost a year, three out of 4 axle shafts are broken, the last one remains, which must be broken. So it was decided to measure 0-100 on the firmware for safe movement and studying the behavior of the motor. The boost was made at 1.8 bar, the fuel runs out at the beginning of the 3rd gear, so nothing but 0-100 will not shine for us yet.
      I wanted to understand the forecasts for the car in terms of potential. Therefore, all starts without lunch shift and setting the boost in gears, the angle is childish - it's a pity for the motor. There is a lot more to do, but the outlines are already visible.
      In general, we managed to make one measurement). On the second, the semiaxis nevertheless receded into another world, but important results were obtained in terms of potential.
      The start is very soft and gentle according to the schedule, but on the second one for all the money.
      Someone did not believe in the axle boxes in 2nd gear on the graph you can see it. Overload in second gear is 3G and awd is stalling.
      50-100 km / h in 1.36 sec
    18. Remove Advertisements
