05- cars with headlight washers. How do you remove the front bumper cover without breaking the washer cover?
    Results 1 to 2 of 2
      Member
      Apr 2006
      Ft Myers Florida
      Please let me know if you know.
      2006 S60 T5A, 1997 850R SOLD, 1997 854 GLT SOLD, 1998 S70 T5A SOLD,1998 SOLD C70 T5M SOLD, 1998 S70 T5M SOLD, 2004 C70 HPT SOLD, 1998 S70 T5M 18T SOLD, 1998 V70 T5A SOLD, 1998 S70 T5M 19T SOLD, 1998 XC70 SOLD, 1995 854 Turbo SOLD 1998 C70 HPT TRADED, 1996 854 Turbo SOLD, 1998 V70 T5M SOLD, 1998 V70 T5 SOLD, 1996 854 SOLD, 1993 244 SOLD, 1991 244 SOLD, 1998 V70 T5M SOLD, 1985 245 Turbo SCRAPPED, 1982 244 Turbo SOLD, 1997 854 GLT SOLD, 1995 854 Turbo SOLD, 1997 855 T5 SOLD, 1996 854 TLA SOLD, 1997 855 NA SOLD, 1992 244 SOLD, 1998 V70 T5M SOLD
      Aug 2010
      Central NJ
      If you pull the washer out by the cover, you can hold the spring loaded arm and remove a small plastic hinge clip that holds the cover onto the arm. Then you'll have no problem removing the bumper. Either a small flat head screwdriver or a needle nose plier will do the job.
      2005 S60 T5 M66 (1 of 72). 4C (for now), Sport Kit, Snabb Short Shifter+Bushings, IPD Track Sways F+R, Bi-Xenon Retrofitted R Headlights - custom fuse box/wiring harness, IPD DP + Oval Tube Exhaust, Forge CBV, Snabb intake pipe, R Brembos F+R, FC04A 17x8+35. coming soon: KW V2, Delrin Subframe Bushings, Do88 Intercooler, Stage 2 Tune. HU-650+Bluetooth Grom+PA300+2xFocal ISS165+ACM-1.300+2x6.5" Dayton Rear Door Subwoofers.
      2005 G55k Family hauler
      2007 Formula SAE Racecar - Custom Tube Frame Chassis, Fox Shocks, Pullrod Suspension, , Wilwood Calipers, Hoosier Slicks, Magnesium 2pc wheels... (full auto-x resto)
      NA1 Supercharged NSX someday.
    4. Remove Advertisements
