bmassy's 2007 XC70 Build Thread
    Page 1 of 9 1 2 3 4 5 ... LastLast
    Results 1 to 35 of 286
      Jul 2017
      I have always been into the car audio scene. My previous vehicles have had a car audio build (speakers, head unit, amps, sub, batteries etc). I'm looking to start doing the big 3 upgrade on my Volvo and wondering if anyone knows best place to feed my alternator 0/1 gauge wire (I will be ordering soon) and engine block 0/1 gauge ground wire to my battery in the trunk? I have 2 xs power batteries that I will be installing (d3400 and d5100R, hope it fits or I'll make it fit).
      My audio plan:
      - I currently have Focal PS165F components in the front doors
      - plan to buy Focal PC165 coax for rear doors
      - disconnect C pillar speakers (or is it D pillar for where the hatch is?)
      - I have a Dayton Audio DSP-408
      - I have a CT Sounds 75.4 channel amp (may run front speakers active and see how it sounds first)
      - I have a CT Sounds AT1400.1 monoblock
      - I have a Sundown X-15v1
      - I need to buy some fusing
      - I plan on using Audioquest Golden Gate 2' RCA-RCA for all my amps to my DSP
      - plan on using Audioquest wire from amp to factory wiring harness behind radio
      - I will be doing a grayish laminate hardwood floor in the trunk
      - build a new sub enclosure for the X15 and possibly use wood veneer to look fancy
      - Build an amp rack out of same material used for flooring
      - need to get sound deadener for doors
      My ultimate goal is: extremely clear and detailed sound with a lot of low end extension. Like a sound quality loud build. I do plan on strapping 2 CT AT1400.1 amps together and running 2 Sundown X-15s on about 3000wrms (down the road)
      Sent from my Pixel 2 XL using Tapatalk
      Senior Member JRL's Avatar
      Apr 2003
      Devon PA
      You're going to need a LOT of sound deadener, Volvos are not known to have any and I mean any. Lightly tap on any side panel or the roof! No THUD, it's a PING!
      Thin, tinny doors and you will need to pull the rear side panels and do in there as as they sit, it's a drum in there!
      Email: jrl1194 ( at ) AOL (dot) com
      2007 V70 2.5T White/Oak/Tan/Arena, 117K miles. My DD with no plans to sell it anytime soon
      2000 V70R, Wife's, she won't sell. Now she hit 158,000 miles and still near perfect!
      Jul 2017
      Quote Originally Posted by JRL View Post
      Yeah I could tell. Dealt with the same thing in my accord, did the front doors and rear deck (both sides) and doubled up on the whole trunk lol.
      SwedeSpeed.com
      somebody grabbed a bunch of deadening from an s80 or some such. I forget who's build it was.
      anyway, they had bunches, and things fit apparently.
    7. #5
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by nsjames View Post
      Prolix did in his p2 xc70 build
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    8. #6
      Jul 2017
      So, my plan to get Focal PC165 changed and I got a deal on a pair of open box Focal PC130 which are the 5/5.25" on the way to me. Figured since I will have a sub, these speaker will be crossed at 80hz and I should have decent amount of mid bass with properly deadened doors.
      I think I am changing my mind and getting a pioneer avh-2330 NEX since it's got android auto and I'll wire up a back up camera to replace my park sensors..
      For doors I might try out some dynaliner by dynomat or maybe luxury liner pro in the front and the dynaliner in the rears for comparison? I can get a discount on the dynaliner through work so I will deff be putting down deadener all over the trunk prior to installing my sub.
      Slowly but surely this will be getting put together and I'll just update this as my audio build log.
    9. #7
      Jul 2017
      Just got these suckers in today (Focal PC130) . Gonna be a lil before I can put them in. Need to gather up some CLD tiles (prob going to go with Sound Deadener Showdown) and also plan on using dynamat dyna liner between door cards for the front and luxury liner pro for the rear, or vice versa. I have a feeling these 5.25" will have some good mid bass in a properly sealed door. Very well built speakers for sure!
    10. #8
      Jan 2017
      Berkeley, CA
      Nice. Let us know how the sound deadening goes!
    11. #9
      Junior Member Amneme1's Avatar
      Aug 2013
      Grosse Pointe Farms Mi
      What about putting a baffle with a port cut in for behind those drivers? In the past I gained a bunch of bass with a baffle and a 2” hole cut in it pointing down.
    12. #10
      Jul 2017
      It's an idea, I've never really heard of doing that though. I will have a sub that will play all my low end up to 80hz too so. May not be necessary?
    13. #11
      I put a pioneer in ours. It's a good deck for the money.
      You'll have to cut up the factory double din adapter and make your own ISO mounting holes.
      not a big deal.
    14. #12
      Jul 2017
      not a big deal.
      I was gonna get the Metra dash kit, did you reususe the stock bezel with the pocket then?
    15. #13
      volvo makes a double din adapter. it matches the factory plastics.
      unfortunately no pocket.
      my wife misses it, but matching the plastics keeps it looking OE. I'm positive it's a much better fit than anything metra I've ever used.
    16. #14
      Jul 2017
      Got some stuff in today.
      - Stinger roadkill fast rings
      - boom mat speaker baffles (usually use these to protect the speakers from water and I cutout the bottom to let the speaker breathe)
      - Pioneer AVH-2330NEX
      - Pioneer backup cam
      - CT Sounds AT60. 4 (for front tweets and mids)
      - CT 75.4 for rear doors and rear D pillars (already purchased before)
      - CT AT1400.1 for my Sundown X-15v1 (both already purchased before)
      I ordered:
      - SMD XL ANL Fuse holder with built in Volt meter
      - Sky High Car Audio 1/0 OFC power and ground (25' each)
      - Fuses
      - SHCA 14 awg OFC speaker wire (100')
      - SHCA 16awg remote wire
      - 3x 16.4' Audioquest Golden Gate RCA
      - 4x 2 meter AudioQuest Golden Gate RCA
      Still need to buy
      - sound deadener
      - laminate flooring
      - plywood/Birch
      I'm sure I'm missing some stuff. I have a lot of left over stuff from my previous builds.
    17. #15
      Jul 2017
      Got another shipment of stuff in from SHCA.
      - 10' of 4 awg OFC SHCA
      - 50' 16 awg remote turn on wire (pink) SHCA
      - bunch of 1/0 awg copper lugs
      - bunch of 4 awg copper lugs
      - 4 awg and 0 awg input terminals for my amps
      - SMD XL ANL Fuse holder w/ built in VM-1 (should look pretty sweet on my amp rack)
      I have began installing my back up camera. It's mounted, wire is ran 80% of the way. I didn't feel like moving my other car out of the garage to work on the volvo inside lol. I ended up getting cold and was losing daylight so I called it a day. I didn't get pictures of it yet but my cars interior is pulled apart so next time I work on it I can take pics. Was pretty easy to install though.
    18. #16
      Oct 2014
      Boston
      Only for 01-04, I think.
    19. #17
      funny thing, the 04 one is actually different than the 01-3 and the 05-7
      because single year plastic color.
      Took me three tries before I got the right colored one. All the parts places just assume that since the dash is the same 01-04 that they're interchangeable. Tasca finally got it right.
      https://www.fcpeuro.com/products/vol...Lw_wcB#fitment
      FCP lists 01-07 (-09 for S60s) for the adapter. I'm not familiar enough with the 05-07 dash to say myself.
    20. #18
      Sep 2017
      Colorado
      Trim around the console is a little different pre and post facelift. Post facelift added a trim ring around the whole center console. The 01-04 adapter will not fit in an 05-07, and vice versa without modification. See below for an '06 center console, note the silver trim ring (which comes in a few colors) which is not present in pre-facelift vehicles.
      2001 V70 Silver - 200k miles
      2006 XC70 Ocean Race - 96K miles
      (Past: '94 944 turbo, sold at ~220k miles)
    21. #19
      Jul 2017
      Made some speaker cables for my doors.used tech flex and heat shrink to give it a nice look. The red cable has 2 pairs of SHCA 14AWG OFC wire that will allow me to run active crossovers for my tweeter and woofer for the front stage. The blue cable is just 1 pair per side for my rear doors.
    22. #20
      Member LloydDobler's Avatar
      Aug 2007
      PDX
      Yeah the FCP listing is wrong, your info is right. I ordered from it for my 06 from FCP and they sent me the 01-03 version. I returned it and told them about the error and they still haven't fixed it.
      I bought the metra kit from Amazon and it matches color and texture very well, has a few small fit issues that don't bother me but would probably bother others. It flexes the aluminum trim on the top, just off center. Nothing a little file and dremel action wouldn't fix though.
      https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70 2.5T - Ice White - Oak Arena, (almost) bone stock daily driver.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    23. #21
      Sep 2017
      Colorado
      Quote Originally Posted by LloydDobler View Post
      Same kit that the PO put in my XC and is pictured above. You can see the fit isn't perfect, but its not bad, and the color match is good.
    24. #22
      Jul 2017
      Finally got my RCA's in. 3 from HU to DSP, then 4 for: highs, mids, rear doors, rear D pillar (plan on attempting to fit 3 inch speakers in there with custom bracket just for some more rear fill) and sub. I plan on using RCA pass thru on my amp for the D pillar speakers.
    25. #23
      Jul 2017
      So in the first 2 pictures, that is the camera wiring going to my radio, the pink wire is going to be the reverse trigger wire by using a busman add a fuse for the reverse light fuse.
      Third picture: all plastic trim pieces for door trim and rear trunk trim lol
      4th pic: my door how it sits until I'm done making a speaker bracket, figured I'd get a head start and pull it off.
      5th picture: ran my rca under the carpet along the factory wiring then crossed under the carpet in the passenger seat to go up to the center console then toward the radio. I forgot to get more pics. I did remove my seat to get access to the inner frame and under the carpet to run the wires. DISCONNECT BATTERY WHEN YOU REMOVE SEATS.
      6th picture: when I pulled my seat 90% out and realized there was a T50 TORX bit that holds the seat belt onto rail of seat.. Luckily I had someone to run and grab me a t50 from home depot cause I was not trying to reassembly that and waste more time. There is also a plug for a seat belt sensor that you will have to disconnect to remove the seat belt holster from seat.
      SEAT REMOVAL:
      1. Front of seat there are 2 CROSSHAIR looking things and a plastic cover at the front of each rail. PRESS the crosshair in and slide plastic cover toward front of car to gain access to 2x 13MM bolts
      2. For the rear covers towards the rear of the seat you will need a pry tool and pry where it looks like there is a tab connected the cover to the rail and slide back.
      3. Undo all 4x 13mm bolts
      4. There is a plug at the front of the seat with a bolt on it that holds the plug together. Turn counterclockwise until you can freely pull the plug off of the seat and now the seats electronics are 90% disconnected.
      5. Pull the seat forward a little and follow where the seat belt bolts into the rail of the seat. Held in by a T50 Torx.
      6. Remove the wire guides for the seat belt sensor (that you just unbolted) and follow the wire to a grey plug and disconnect it.
      7. Now you can freely remove the seat, be cautious for sharp edges. I nicked a piece of my leather near the window switched and I had to glue the little piece back down.
      Hope this helps someone else who ever has to remove a seat. But remember to DISCONNECT THE BATTERY, unless you want an airbag light and a trip to your dealer.
    26. #24
      Jul 2017
      Oh here's a pic from earlier as well lol. If anyone would like to follow my build and me, my snapchat is @b_massy
    27. #25
      Jul 2017
      My XS Power D3400 is a direct fit for the OEM Volvo battery. Also installed my Pioneer AVH-2330NEX. My ASWC-1 did not work, it made all my dash lights go out and threw me "SRS-Airbag Service Urgent" warning . Anyone know if this clearable with Vida? I had installed everything with the battery disconnected (negative removed first of course). I'm going to check with Metra on their suggestion to get the ASWC-1 to work properly. Radio fitment looks good, slightly more recessed than the climate controls but whatever. Color looks like a match to me.
    28. #26
      vida will clear the SRS error.
      it's probably a CAN communication error.
    29. #27
      Jul 2017
      That's what I'm thinking..
    30. #28
      Jul 2017
      Got sidetracked and replaced my lower passenger motor mount. 166k on the OEM one, almost nothing left lol. I guess this thread might turn into my build thread. But I can't change the title? Or at least can't on Tapatalk?
    31. #29
      I think that after a certain time you can't edit the title.
    32. #30
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      PM a moderator and ask nicely
      Sent from my ZTE B2017G using Tapatalk
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    33. #31
      Jul 2017
      Quote Originally Posted by Antherzoll View Post
      Ahh not sure whom I'd be looking for since I'm still new here
    34. #32
      Feb 2015
      I put a 1000w Hertz Mille Legend system in my 06 V70 (Pioneer DEH80PRS Deck) and love it. Your system looks awesome.
      In other news, Costco does free hearing tests.....
      I had a prob with my deck working with the steering wheel controls and found a good place for the adapter if you need help on that.
    35. #33
      Jul 2017
      Quote Originally Posted by Clayton View Post
      Thanks man! Waiting for temps to warm up a lil more and I should be working on this more often haha
    36. #34
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by bmassy View Post
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body - Replica 18" Pegs - Handbrake Mod
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R, 2004 V70R MT 68k
    37. #35
      Jul 2017
      Quote Originally Posted by R-Pow3R3d View Post
      Thanks bud!
    38. Remove Advertisements
    Similar Threads
    1. Exocet's 2007 V70 2.5T Build Thread
      By Exocet in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 10-08-2020, 08:21 PM
    2. Wernerj18 build thread (question/help :) ) thread
      By wernerj18 in forum S40 & V50 (2005-2012)
      Last Post: 11-28-2016, 10:56 PM
    3. 2006 XC70 Build and Questions Thread - tomedkaz
      By tomedkaz in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 10-11-2015, 06:05 PM
    4. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    5. 2007 S60 AWD- Build Thread
      By stealthS60AWD in forum S60 (2001-2010)
      Last Post: 05-19-2010, 01:37 PM
