Exocet's 2007 V70 2.5T Build Thread - Page 2
    Page 2 of 13 FirstFirst 1 2 3 4 5 6 12 ... LastLast
    Results 36 to 70 of 421
    1. #36
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      The date of manufacture is the 47th week of 2016. That's a little disappointing. So, already 2 years old.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Nov 2017
      Southern Tier NY
      A goodie box from TRS arrived today! Initial quality impressions are very good.
    4. #38
      Apr 2014
      Quote Originally Posted by Exocet View Post
      Mine were the same. Slightly disappointed too. Simple tire?
      SwedeSpeed.com
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by cbblunk View Post
      Yes. Granted, Nokians probably don't turn over real fast. Not worried. I'll still hit 30k-32k before they are 6 years old.
    7. #40
      Nov 2017
      Southern Tier NY
      Starting to tear open the headlights for the projector retrofit. Not easy. The 05+ plastic lenses apparently don't use butyl rubber sealant. Being 12 years old and dried out doesn't help. 30 min @ 150 deg, nothing. Another 30 @ 175, nothing. Now at 15 min @ 225. Starting to chip away at it. A sharp utility knife around the perimeter seems to help break the seal. Need to get that first corner out.
      After 2+ hours, got the first one apart. Still need to figure out how to get the reflectors out. No obvious screws any where. A lot of hardened sealant to remove. The housing is slightly distorted where I had to pry on it. I'll work it back with the heat gun.
    8. #41
      Nov 2017
      Southern Tier NY
      Okay. No need to pull the reflectors, as the Mini H1 7.0 fits without any cutting. Unfortunately, I can't say the same about the Mini Turbine shrouds. They need to loose about 1/8" top and bottom. The 100mm halos will still fit. Not sure if I'm going to trim the shrouds, or look for a different style.
    9. #42
      Nov 2017
      Southern Tier NY
      After looking for shrouds under 105mm, and only finding one (that I didn't care for), I decided to trim the shrouds I have.
      Not too bad!
    10. #43
      Nov 2017
      Southern Tier NY
      The 2nd light only took about an hour to get apart. 15 min @ 230, then carefully pry around with a screwdriver to "crack" the sealant. Then, cut the sealant with a utility knife. Then, back in the oven for 15 minutes. Starting with the outside corner seems to be the best. Pry with a screwdriver around the perimeter until you can get your fingers on it enough to start pulling it apart. Note, the black plastic for the housing will deform fairly easily at this temperature. You'll have to take a heat gun to it to work it back into shape.
      Don't know if I'd go much higher than 230 deg. The polycarbonate in the lens is supposedly good to 265.
    11. #44
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Nice work.
      Sent from my ZTE B2017G using Tapatalk
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    12. #45
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by Antherzoll View Post
      Nice work.
      Thanks. Still probably a couple of weeks away from being done.
    13. #46
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Those look mean. Hopefully they’re like aircraft bright. F all the new cars. We can do that too.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    14. #47
      Jul 2017
      Oh man I was planning on using the turbines when I do mine but they look awesome! Can't wait to see the outcome. Good work!
      Sent from my Pixel 2 XL using Tapatalk
    15. #48
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by bmassy View Post
      Turbo engine, turbine shrouds!
    16. #49
      Aug 2005
      Northern MD
      Fingers crossed. The ones I installed in December of 2018 were 50th week of 2016. Maybe I’ll be lucky.
    17. #50
      Member
      Dec 2013
      …now Birmingham, AL
      Headlights are looking awesome, man! Kudos for tackling the polycarbonate lenses! What are you going to put back in? Will the lenses you have clean up enough?
      Current: 2003 V70 T5 M56 // Mystic Silver/Charcoal // 162K miles // Koni FSD + Eibachs // Snabb intake + IPD silicone turbo hoses // Copper R Brembos // 18" Pegs // OEM bi-xenons // '05 side mirrors // 18/35 tint // jewel tails // black anodized S80 DIM // R steering wheel // '05 console w/ T5M spaceball // mesh grill with custom ironmark badge 2004 XC70 bone stock for now…
      Previous: 2001 V70 T5M (Nautic/Charcoal) // 1999 V70 NA M56 (Blue-Green Metallic/Charcoal) // 2004 V70R M66 (Titanium/Nordkap) // 1992 244 M47 (Silver/Navy…and the newest, nicest car I'll ever own. Sold on BaT. )
    18. #51
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by Sigg View Post
      Sand the crap out of them, then coat with SEM Solaray, which is a UV cured headlight coating. Supposed to be comparable to OEM UV treatments. At $50 a can, it better be good!
    19. #52
      Aug 2005
      Northern MD
      Is there a vid or a thread on this? I'd love to do the ones on the s60.
    20. #53
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by ZZZZZZZ View Post
      I might have a newer set of some aftermarket lights available after I get these done.
    21. #54
      Nov 2017
      Southern Tier NY
      I think there might be a YT video for SEM Solaray.
    22. #55
      Aug 2005
      Northern MD
      At least one of the new ones is week 16 of 2017! Desperately need to wash the car now, the tire install stuff is all over the wheels, and it was 830 by the time I got home, and 40 degrees.
      I watched them like a hawk because I didn't take them loose, and asked the guy to back into the parking space when he was done so I wouldn't have the same sonic panic I saw a few weeks ago here on line with Fred's VR.
      I'm sure they hate having a magnet, but hey - I waited a long time to get this car and I'm super careful with it.
    23. #56
      Nov 2017
      Southern Tier NY
      Spent a couple of hours cleaning the remaining sealer out of one of the headlights.
    24. #57
      Member
      Dec 2013
      …now Birmingham, AL
      That does NOT sound like a fun couple of hours...
    25. #58
      Nov 2017
      Southern Tier NY
      Nope. But, if I want the new sealant to work well, it needs to be done.
    26. #59
      Member
      Dec 2013
      …now Birmingham, AL
      Absolutely! Worth every minute, I'm sure. But just the kind of mind-dulling tedium that will drive you a little crazy. Haha.
    27. #60
      Nov 2017
      Southern Tier NY
      Wheels are painted. Went with hypersilver over black. Need to wait 30 days before I can mount the tires.
    28. #61
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      That looks reallllll good. What paint kit did you use? I'm thinking of refreshing my Talos
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 306k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    29. #62
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by ScottishBrick View Post
      I had them professionally done. Came to me and took care of everything. The tech did some test sprays of different base and color combos. Originally thought they might be too dark. But, turned out great.
    30. #63
      Aug 2005
      Northern MD
      A dream...sigh...
    31. #64
      Dec 2014
      Connecticut
      Wow. That's awesome. A lot better than the wheel shop we've used that sends wheels back different colors and with the sand blast media still on the wheel. They even powder coated over a wheel weight.
    32. #65
      Aug 2005
      Northern MD
      Wait for it....it's the full spelling this time (Derek & Skywolf)...
      Oh.
      My.
      Damn.
    33. #66
      Dec 2014
      Connecticut
      Oh.
      My.
      Damn.
      Witness the f*ckery.
      Now, back to regularly scheduled programming.
    34. #67
      Member Chicago_Wagon's Avatar
      Jan 2016
      Chicago, IL
      Oh.
      My.
      Damn.
      Hmm... must be an East Coast thing.
      Current - 2000 V70R 445/3876 | Past - 1998 V70 XC 421/3980 | RIP - 1986 RX-7 GXL WU/FD2
    35. #68
      Nov 2017
      Southern Tier NY
      Following Brian's lead, here's my list of things to do before Carlisle:
      Projector headlights
      ZLines on newly painted wheels
      Premium audio install
      Black carpet swap
      Sound matting
      Leather center armrest
      Exterior, interior, and underhood detail
      Misc badging
    36. #69
      Aug 2005
      Northern MD
      You suck.
      It rained last weekend, it’s gonna rain THIS weekend. I do something to a car I’ve gotta be outside.
      Black carpet swap
      Sound matting
      Misc badging
    37. #70
      Nov 2017
      Southern Tier NY
      You suck.
      Out of town last weekend. Rain this weekend. Heading to CA Sunday. I have 2 four day weekends and the week before Carlisle to do all that. Not to mention spring yard work. Probably of success is low.
    38. Remove Advertisements
