Just wondering if anyone knows anything about turbocharging a 960 inline 6. I don't know much about the engine how it's built what it's potential is of the engine.
Well Volvo did a turbo variant of the 6 cylinder whiteblock. Usually when people make T6 rwd the engine is sourced from an early s80. 600 hp can reasonably be expected with a properly sized turbo.
The cylinder walls are a bit weak on the teh 3ltr. I'm going to start a turbo to mine. If/when that lets go I will build something stronger but on low boost it should last a while
The first gen t6 use the 81mm bore that all high pressure turbo whiteblocks had used previously not the 83mm bore that came with gen2 of the t6 in the later s80 and xc90.
If you were to build with a B6284T, would this be a direct bolt up onto a 900 series? Also what would be the manual trans options for this setup?
157K members
