Rear doors gather way too much snow/dirt, design flaw? - Page 6
    Page 6 of 7 FirstFirst ... 2 3 4 5 6 7 LastLast
    Results 176 to 210 of 213
    1. #176
      Nov 2018
      Mississauga, ON Canada
      Quote Originally Posted by robogar View Post
      Has anyone found a place that ships these (the official Volvo ones) to Canada? Would love to have these installed before the snow and slush hits.
      I believe I already mentioned above in a previous post that you can purchase these locally in Toronto from any local Volvo dealer. I just ordered a set yesterday from Mississauga volvo for $37 CAD - they will be here on Tuesday. Normally takes 2 days but Monday is a holiday.
      Hope this helps...
      Aug 2016
      The dealers prices for these are much higher but they have them now. Why they aren't standard on builds yet is a shame..
      2020 xc60 "Polestar Engineered", crystal white.
      2019 xc40 T5-R Bursting Blue Premium & Advanced Packs.
    4. #178
      Nov 2018
      My Volvo guards arrived today and I thought I would post some pics. These are made of a soft nylon as opposed to the Chinese ones which are a hard plastic. The Volvo ones are bigger and have a different shape and are very flexible. Finally the do fit the curvature of the rear door much better than the Chinese ones. There is no gap at the bottom - it has a very consistent gap from top to bottom.
      Now that I have a spare set - if anyone is interested in them you can have them for cheap - send me a pm.
      Junior Member shamusom's Avatar
      Quote Originally Posted by spas1 View Post
      Do you happen to have a link to the part at the Volvo dealership in Canada? I'm located in Ottawa, but could order from Missisauga. I have the chinese ones installed, but the genuine volvo ones look better. Thanks.
    7. #180
      Nov 2018
      I just called the parts department and ordered this part number - 32288517. It arrived in 2 days.
      You can probably do the same at your local Ottawa Volvo dealership...
    8. #181
      Aug 2016
      I'm wondering if this part will fit the 20 Polestar with it's wider wheel well trim. Looking at it it doesn't seem like it will fit right.
    9. #182
      Member BigBang's Avatar
      World
      Quote Originally Posted by xgman View Post
      It doesn't matter which model it is: 18" - 22" with or without a wider wheel trim. This is located on the inside of the rear fender
      2018 XC60 T5 R-Design
    10. #183
      Aug 2016
      Yeah I see that now once the door is open it should work.
    11. #184
      Oct 2019
      Thanks much
      This worked, stumbled on this forum when I was doing research on the issue. Indeed a design flow, interesting that Volvo had the screws in place for the mudguard. They should have added as standard, its just @6 or so, why not Volvo?
      Thanks folks.
    12. #185
      Aug 2016
      My dealer put the new OEM Volvo ones on my 2020 xc60 Polestar Engineered and they do the trick nicely and are mostly unnoticeable.
    13. #186
      UK
      Tried to fit mine over the weekend and aborted half way through. The rear door actually closes ON the plastic near the bottom of the wheel well. It will close but only after making a loud "breaking plastic" noise. It was raining too so I bagged it for a different day.
      Hooligan of Volvo
    14. #187
      Sep 2019
      Dealer fitted mine too, took around 10 minutes for both
    15. #188
      Sep 2019
      I put these on, so thankful to people who found them, it was a real problem last winter. Agree that they are effectively unnoticeable even on our white xc60. Fingers crossed that they do the job when the weather gets rough here.
    16. #189
      Junior Member GreyGhost50's Avatar
      Apr 2019
      Mechanicsburg, Pennsylvania
      Got these parts from Dealer for around $45 including tax. Installation on both sides took 15 mins total. Only had to use torx key on two of 8 fasteners. The other six fasteners used finger tightened plastic nuts. Gap is as shown in earlier pictures, around 1/8 to 3/16Ē. Letís see how they work this winter with slushy roads here in central Pennsylvania.
    17. #190
      Nov 2018
      Quote Originally Posted by n a m View Post
      When you install this, first remove the torque screw and then place the fender in place and start with the middle nut only turned one turn. The fit the top and bottom nuts - again only finger tight. Adjust the fender so there is even clearance around the full door arch. Tighten the nuts evenly. Finally insert the torque screw. This should fit perfectly.
      If you find the door is still hitting the fender remove the torques screw, loosen the lower and middle nuts and then adjust the fender so it clears the door and then retighten accordingly.
      Hope this helps.
    18. #191
      Junior Member Mr Timewise's Avatar
      Apr 2017
      Hawthorn Woods, Illinois USA
      Thanks for the installation suggestions, spas1
      Just ordered a 32288517 set for our 2018 XC60
    19. #192
      UK
      Hope this helps.
      Sorry. I didn't see this. I installed the rear left again the next weekend and it was fine this time around. I had to force more of a bend into the plastic but it has been fine since. Thanks for the suggestions.
      Hooligan of Volvo
    20. #193
      Junior Member rhmorris's Avatar
      Jul 2011
      Twin Cities, MN
      Quote Originally Posted by Dystaxia View Post
      Got mine in, and replaced the Chinese ones. The gap is definitely smaller, but not zero.
      Ordered mine from Tasca: https://www.tascaparts.com/oem-parts...dflap-32288517
      They take a bit longer, but I haven't found anybody that beats their price.
      Ordered mine from Tasca Oct 11, 2019 and have not seen them yet!!
    21. #194
      Sep 2019
      installed it month ago, looks like less dust. it's good.
      But, another issue...
      found some sand/dust on both sides of rear seats, just between seat and doors...
      so next task is to find how it happens...
      seems volvo needs new seals for rear doors.
    22. #195
      Oct 2018
      San Diego, CA.
      A little late to the party, here, but looking at the original pictures in post #1, my first thought is that there's no aerodynamic cause for the stuff wrapping around the door edge. Notice that it's adequately dammed by the weatherstrip. I would first look to the door adjustment, as in there may be a low-pressure air flow drawing the road muck around the edge. Odd, too, that there's a clean area where companion areas are in maybe too close proximity. Is the starboard aft door the same?
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    23. #196
      Mar 2011
      RI
      That's right side rear for non squids
      Sent from my Pixel 3a using Tapatalk
    24. #197
      Dec 2019
      Volvo XC60 rear door dirt
      I have the same rear door problem on my XC60 and have been complaining for two years with no fix. it is disgusting. I cannot believe that they have not fixed this obvious design problem.
    25. #198
      Junior Member stocis's Avatar
      Oct 2019
      Cyprus
      My local Volvo dealer has confirmed to me that they have ordered the mudflaps and will install it for free in my 2020 XC60.
      Current: 2020 Volvo XC60 R-Design, 2018 Volvo XC40 R-Design
      Previous: 2009 Volvo C70, 2006 Volvo XC60, 2003 Saab 9-5, 1999 Mitsubishi FTO, 1998 Land Rover Freelander, 1995 Suzuki Swift Sedan
    26. #199
      May 2014
      NYC
      Just installed the volvo fender liner flaps today. Picked them up from a dealer here in NY for $49. They wanted to charge me $57 but talked them down a few bucks.
      As previously mentioned, install was a breeze. The only issue I have is that my passenger side fitment is spot on however the driver side is not as imprecise. I tried messing with it but the gap isnt consistent.
      Anyone else with volvo part had the same issue ?
      I am going to add additional weather stripping to the inside of the door jam still to see if it will prevent the sand accumulation inside like others have. Hopefully will solve the issue.
      2019 XC60 R-Design - work in progress
      2015 XC60 R-Design - Totaled
      2016 VW GTI - modified
      2005 G35 -modified
    27. #200
      May 2019
      The day in November that I picked my 2020 XC60 Inscription (Osmium Grey) up from the dealer it was raining. I got home and noticed the dirt in the rear doors that is discussed in this thread. Very disappointed! I had the dealer order the part. They couldnít find it in accessories, but they were able to find it using the part # posted in this thread. I had them installed and just drove in the snow yesterday for the first time since they were installed. Worked perfectly! Thanks to all for your role in alerting me to this problem and the fix!
      I was preoccupied with other priorities at the time of ordering and installation and didnít have the energy to take the issue up the dealer chain from the salesperson, parts and service departments to get the dealer to pay. None of them had heard complaints from other customers or knew about the part.
    28. #201
      Apr 2009
      Indiana
      Just installed the mud guards on my new 2019 XC 60 today. Thanks to this thread for the fix. If the plastic rubs on the bottom of the door then just loosen up the Torx bottom screw and slide the plastic in and tighten back down. That way it pulls the edge away from the bottom door edge. The door closing now clears the plastic.
      2006 XC90 2.5T
      2010 S80 3.0 T6
      2011 S60 3.0 T6 Polestar Tune
      2013 XC60 3.0 T6 Polestar Tune
      2013 XC60 3.0 T6 R Design Polestar Tune
      2019 XC60 T6 Polestar Tune
    29. #202
      Dec 2019
      only a redesign will fix this problem. new seals will help to keep the dirt from entering but will do nothing about the disgusting dirt accumulation on the inside of the doors. had I been aware of this issue I would never have bought this car. We have lived with it for 2 years now but have decided to trade in for something else. I just dont want to look at this for another 6 - 8 years.
    30. #203
      Awaiting Approval
      Jan 2020
      "protection pack" ??
      Again, much smaller gap.
      so is this part of the "protection pack" (mudflaps) ..? Or do I need something else as well...?
    31. #204
      Junior Member RootDKJ's Avatar
      Jul 2010
      North Jersey
      Quote Originally Posted by Hamlyn View Post
      Iím pretty sure that the ďprotection packageĒ does not include mudflaps and the inside fender liner to prevent this.
    32. #205
      World
      This part eliminates the design flaw, it's not a protection pack as mudflaps. Mudflaps is something else, it's an extra part that all cars have to offer
      This is a part that was made because of a design glitch, it's just not clear to me that test drivers in Sweden didn't notice the mud and snow in the back door and reported it to their superiors. Obviously they never opened the back door or washed the car themselves
      Mud Flaps:
    33. #206
      Nov 2019
      Has anyone been successful in having this new OEM part installed under warranty?
      2020 XC60 T5 AWD R-Design Osmium Grey | Charcoal
    34. #207
      World
      Quote Originally Posted by tooth32 View Post
      I think that's impossible. There is simply no TSB or anything like that
      Only perhaps a local dealer can do so as an act of goodwill
      Volvo was supposed to do this to all XC60 owners because itís a design flaw, but obviously they donít want to admit it. I don't think it costs them more than 5-6 EUR
    35. #208
      Oct 2019
      Cyprus
      I did. But wasn't under warranty. I just brought the issue with the dealership as soon as I received delivery of my 2020.
      They told me that they were not aware of such issue, at least in Cyprus, but should I do notice this, they will handle it.
      In Cy we don't really have rainy seasons, however after a couple of car washes, the flaw was obvious.
      So I got the part for free. Of course YMMV.
    36. #209
      I have a 2020 and havenít had it in the winter so cannot say whether itís happening to me. However I took these pictures of the rear door and wondered if it looks the same to all of you with pre-2020 cars? Or has Volvo made a change?
      https://www.dropbox.com/s/gaov4brkax...%20PM.jpg?dl=0
      2020 XC60 T5 AWD Inscription with Advanced and Luxury package in Denim Blue with Blond interior
    37. #210
      Jul 2018
      Quote Originally Posted by Blackjackmark View Post
      No change. Looks the same as all of them from 2018-2020
