Manual Swapping a XC70 - Axles Q and A
    Results 1 to 11 of 11
      Senior Member Chilled Man's Avatar
      Jan 2007
      Backyard of TMI
      So been getting a bunch of DM regarding axles and such.
      So to give you a short back-round on me if your new here ....
      This was Manual swap FWD M56 back in 2008/2009
      So axle Q and A.
      Q: For M66 AWD Swaps what axles do you need ?
      A: You need the stock axles from your XC and either Axles from a 98 V70 AWD ( XC or R ) or from a 04R+ that your M66 Came from.
      Now you will need to combine these since the XC your manual swapping has longer control arms ( 2" Longer ) then your P2R
      FWD / R LCA Left - XC LCA Right
      So now you have two types of axles ends. The Smooth ones which are normally 01+ IIRC and the odd shaped ones which seems to be 00 and older ( not 100% on this so someone correct me if I am wrong )
      Both of these are from a Manual FWD Volvo, Id assume 98 V70 M56 and 01 S60T5M ( Since those are cars I parted out at this time )
      You dont want any of these here since these are FWD and pretty usless to you.
      What you want is this ...
      This is from a 2001 V70XC Auto , the part you want to throw away.
      /2006 S60 T5 /K24/R Calipers/Pegs/Koni/Eibach/JVC/SNABB/IPD Endlinks/
      /2004 V70 R/M66 /05+ Tails/ 05+ Console/Evolve Intake/IPD Sways/OZ/Kenwood/PHUZZ/IPD CatBack/Coilovers/EvolveDP/
      /2005 V70XC -/Pegs/HID/LED Tailights/Kenwood/Tintz yo/No R bumper/
      Unquestionable faith is the Epitome of Ignorance. - me
      Quote Originally Posted by Chicago_Wagon View Post
      (Sh!t, did I just agree with Chilled Man?) .
      Jan 2007
      Backyard of TMI
      What you see is here is the different ends on FWD Auto VS Manual Axle ends.
      Auto on Top , Manual on the bottom
      Jan 2007
      Backyard of TMI
      This should help show you what you need to do.
      Also shows you the difference between XC and NON XC axles on P2
      Also why you can use your P2R axles most of the time due to the differences in center joins.
      Now remember you need to do this to both axles, granted the driver side you can use any auto axleend from 98 and older.
      Or from any Manual FWD car also of any year. 92-08
      This is exaclty what your AWD M66 XC axle should look like when finished.
      XC Axle combined with a 98 AWD axle.
      Attached photo shows you the axle set up for a m56 swap on a p2xc
      SwedeSpeed.com
      Jan 2007
      Backyard of TMI
    7. #5
      Junior Member neilv's Avatar
      Feb 2014
      Burlington,ON,CA
      I'm actually collecting some parts to M66W my P2 V70 (FWD) but this information may be of use:
      P2 Drivers M56, M66 FWD and M66 AWD axles are all the same (8252034)
      P2 Passenger M56 and M66 FWD axles are the same (8252049)
      P80 AW50-42LE to M56/M66 swaps can use the auto axles as long as you use the auto output seals(different I.D.)
      What I'm trying to figure out is if that applies to the P2/AW50-50/51 as well.
      09 BMW E90 335i M sport 6mt/Rwd- Dinan I/E, 2.75" DP's, JB4, Wavetrack lsd, M3 sway/arms, MMP Inlet/outlets, meth
      93 Mazda Miata- Turbo "street legal" track car
      07 BMW E61 530xit 6mt- winter wagon
      Others: 1990 Mazda Miata, 1990 Mazda Miata, 07 E90 335i Sport 6mt/rwd, 02 Infiniti G20 Sport 5spd, 04 E83 X3 Sport
      GONE
      02 Volvo V70 T5 Auto - 3" DP, 316/308 XC90 Brakes, IPD hoses, Poly/R mounts, ABL Xenons, Sport steering wheel, S80 Exec gauges, Premium audio, Wang
      02 C70 T5M Coupe(written off)-K24/Greens/R Mani/ 3" turboback/3" intake, IPD/Koni, IPD 25/28 sways, P1 320 front/XC90 308 rear brakes
    8. #6
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by neilv View Post
      Nope. Cant mix aw55 axle inners with manual boxes because of the spline and sealing surface difference.
      2003 V70 T5 - Mystic/Graphite - M56LK - 209k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 303k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 245k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    9. #7
      Jan 2007
      Backyard of TMI
      Quote Originally Posted by ScottishBrick View Post
      Correct.
      I think 98 was the last year auto / manual axles worked in both.
    10. #8
      Dec 2014
      Connecticut
      Quote Originally Posted by Chilled Man View Post
      Correct.
      Almost. Anything p80 4 speed auto and 5 speed manual can swap axles. All DS axles are interchangeable under that compatibility and all fwd passenger axles are as well, if you respect the year break.
      Basically:
      1998 - Auto/Manual fwd fully interchangeable drivers & passenger. Auto/manual swappable awd drivers. Auto manual swappable aw42 awd and m58.
      -98 and 99+ non cross compatible.
      99-00 Auto/Manual fwd fully interchangeable drivers & passenger not including SE naturally aspirated 5 speed auto and R 5 speed auto. 00 c70 keeps the 4 speed auto as does glt and t5.
      99+ m56 axles fit and work in all 99-00 aw42 fwd transmissions. Ive done this upgrade to my 99 t5a after blowing up a few too many aw42 axles. 99+ drivers manual axles works in 99-00 aw42 awd (99 R and 99-00 xc)
      Yes the manual axles work in the p80 xc the 1" lift is within allowable angles just as lowering a p80 1.5" doesnt kill the axles.
      AWD specifics:
      98, 99 & 00 aw42 awd use different angle gear thicknesses each year. 00 angle gear works in aw42 and aw55 awd cars. if your m58/m66 swapping your 00 R you use a aw42 passenger axle that matches your angle gear year.
    11. #9
      Jul 2010
      Ontario, Canada
      Will p2 m58 right side axle inner fit a m66? Will the p2 xc aw55 center shaft and outer joint fit a m58 inner? Hard to find much info fit the m58 axles.
      2006 S40 2.4 and 2005 XC70 2.5T AWD
    12. #10
      Dec 2014
      Connecticut
      Quote Originally Posted by turbosundance View Post
      M58 is just awd manual. M58/M66 axles are interchangeable.
    13. #11
      Jul 2010
      Ontario, Canada
      Thank you for the response. I figured that was the case but I wanted to get a second opinion before I bought up a couple stock m58 passenger side axles.
    14. Remove Advertisements
