Cold Air Under Driver Seat
    Results 1 to 16 of 16
      Sep 2018
      Maine, USA
      I have a 2017 XC90 Inscription. I've noticed that there is cold outside air coming in underneath the seat somewhere that is keeping the footwell very cold. Unless I have the heat blasting it's quite noticeable. Anyone else have this issue? Not sure exactly where it's coming from, but I can feel it when I put my hand down there while driving, and the metal seat frame is always freezing.
      Sep 2018
      Maine, USA
      Thought I'd bump my own post since this is still happening and I thought maybe a tech here could chime in. It's gotten cold out again, and once again there is cold air coming in somewhere under both the front driver and passenger seats. This is not air from the ventilation system, this is frigid outside air seeping in around where the carpet holes are under both seats. When it's 25F out I am having to blast the footwell heat just to keep it warm enough not to be annoying. Had plenty of luxuryish cars, this is the first one I've owned that's actively leaked outside air. Anoyone else have this issue? I asked Volvo Portland where I live to look at it and they said they couldn't find the cause, but my car can't be the only one out there.
      Any ideas?
      Member Papa_Kirlo's Avatar
      Feb 2003
      Boston
      I'm pretty much sure this is not the case but still gonna ask - when you try to heat up the car, is your AC button in On or Off position? I recently realized that I had AC on and putting heat to 75 didn't make a thing to me..
      06 V70R Sonicap
      surf/skate/snow/smile-mobile
      16 XC90 fam-mobile
      SwedeSpeed.com
      Sep 2018
      Maine, USA
      Quote Originally Posted by Papa_Kirlo View Post
      Nope, I've tried it both AC on and off. Strange that you weren't getting heat with AC on and heat turned up, I can fry an egg when I turn it up, but it's an icebox under the seat. I guess I'll ask them to check again at my 40k mile service in a few weeks.
    7. #5
      Feb 2003
      Boston
      Perhaps I didn't crank up the heat high enough and AC was still overpowering..
      Another suggestion would be to check underneath the car to see if any rubber plugs are missing...
      06 V70R Sonicap
      16 XC90 fam-mobile
    8. #6
      Apr 2019
      I just posted this and noticed similar post:
      since the temperature are getting to sub freezing. I am noticing some cold spots near the driver door where my knee and lower leg rest on the door.
      I am getting heat from the bottom vents, but I can notice some cold spots. Anyone else notice that on the XC90?
    9. #7
      Quote Originally Posted by orcking View Post
      Weather stripping issue? Why not take to dealer for a look about since your vehicle is still under warranty.
    10. #8
      Apr 2019
      Most likely the dealer wont know what to do. I am asking since the users of the car would know if this would be a known issue.
      Quote Originally Posted by MyVolvoS60 View Post
    11. #9
      Sep 2018
      Maine, USA
      I asked about this quite awhile ago, and again just a few days ago. Apparently it's not a common problem. I took mine to the dealer, they said they had no idea. I'm going to ask them to look again when I take it back in a few weeks, if they suddenly come up with anything I'll post back.
    12. #10
      Sep 2018
      Maine, USA
      Quote Originally Posted by fvultee View Post
      Just got my car back tonight, they could not duplicate the problem again. Probably because they didn't drive it over 3mph given it's in the 20s today. Argh.
    13. #11
      Mar 2019
      DId you consider to use IR camera to try to see the flow/origin of the cold air ?
      2019 XC90 T8 Inscription, Denim Blue, ~everything sans B&W
    14. #12
      Dec 2019
      New owner of a 2016 here as of this week, I was just commenting to my wife of the same issue, very cold on legs on drivers side with heat on, feels almost drafty. To the point that I was going to have the dealer look at it.
    15. #13
      Sep 2018
      Maine, USA
      Quote Originally Posted by hitch_hiker View Post
      Nope, I don't own an IR camera. It's coming from the cutout area directly below the driver seat when it's really cold out and the car is in motion. As videian said, almost drafty. So strange. They insist it must have something to do with the ventilation system however it happens with the system is completely off as well. I basically blast the heat in the footwell to counteract the cold. Videian, if they find anything please let me know, 2 trys at my dealer and still nothing.
    16. #14
      Dec 2019
      I just did my 30k service, did not know about it before then (just got vehicle last week). I'll poke around there myself and see if I can surmise anything.
    17. #15
      Nov 2016
      I feel a little draft around the door handle. It’s actually annoying if you have your arm resting on the armrest. You can feel the draft hitting your hand.
    18. #16
      Sep 2018
      Maine, USA
      I've got the drafty door handle as well. Figured out that I 'think' the freezing front footwell is actually coming from the bottom of the rear passenger door seal. It looks completely intact and new, but when I put my hand down there when I'm driving there is freezing air blasting in from that area. Definitely the draftiest car I've ever owned so far.
    19. Remove Advertisements
    Similar Threads
    1. Cold Air Leak - Driver's Side Footwell - 2005 XC90 V8
      By kartman01 in forum XC90 (2003 - 2014)
      Last Post: 12-10-2017, 07:18 AM
    2. A/C problem, hot air on passenger, cold air on driver
      By chthom in forum S40 & V50 (2005-2012)
      Last Post: 07-08-2014, 08:09 PM
    3. Replies: 4
      Last Post: 07-31-2012, 05:20 AM
    4. Air Conditioning blows cold air then warm air?
      By c70c70c70 in forum C70 (1998-2004)
      Last Post: 05-22-2009, 10:16 AM
    5. "Cold oil flogging" how cold is too cold?
      By Britspeed in forum R Forum (2004-2007)
      Last Post: 12-24-2004, 09:31 AM
