It all started with a broken exhaust stud - Page 2
    Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
    Results 36 to 70 of 248
    1. #36
      Member Hounddogger's Avatar
      Oct 2014
      Northern Hemisphere
      Why not melt the stud out of the head? There are chemicals that will eat the iron in the stud and not the aluminum.
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
      Oct 2014
      Los Angeles
      Slowest project ever? Between work and family and my gf sabotaging all my free time ... finally carved out some time for disassembly. Decided to shim it. Need to grab a T60 socket and I'll be able to take the accessory belt off, then timing belt, and goal is to have the head off in time to watch GoT tomorrow.
      Then will measure my sleeve-to-sleeve clearance, order shims from https://www.deeworks.ca/product/volv...iner-shim-kit/, and order whatever else I need. So far thinking new head gasket, new timing belt, maybe new water pump, and new PCV stuff. Already have an 05+ PS reservoir going in. What am I missing?
      Maybe I'm missing something but the farthest left bolt for the intake manifold won't come out until I remove the coolant feed fitting block. That's why the gasket is still sitting there.
      04 V70R, 05 M3, 92 Stealth TT, 94 Stealth TT soon to be single T
    4. #38
      Oct 2014
      Los Angeles
      Rain delay today. I had to stop yesterday at the timing alignment stage since I realized I don't have a 30mm socket. Hopefully the rain clears up in time.
      A comment, working on a California car is soooo much better than working on cars back home in Vermont / the northeast. Knock on wood, but there hasn't been a single rusty bolt.
      Next steps:
      -Line up timing marks
      -Lock cams in place
      -Remove timing belt
      -Remove coolant passage behind head
      -Remove VVT solenoids
      -Remove cam cover
      -Remove head
      SwedeSpeed.com
      Oct 2014
      Los Angeles
      Back after a week on the road for work, timing belt off, in the process discovered timing has been a hair off.
    7. #40
      Oct 2014
      Northern Hemisphere
      Those cam marks are only applicable if you're the last person to touch the timing or its never had a tbelt done... c
      Exponents kill
    8. #41
      Oct 2014
      Los Angeles
      Quote Originally Posted by Hounddogger View Post
      What do you mean?
    9. #42
      Oct 2014
      Los Angeles
      Well, head is off. Cylinders look excellent - crosshatching still there. No cracks in sleeves. Lots of carbon on pistons, but I can clean that off. Cams look good, cam journals look good. Not bad for 230k miles.
      Looks like I have ~35 thou gap in 3 of the sleeve gaps, and ~37.5 thou in the last one. Going to get shims on order.
      My block code is 317XXXX, so I can order the right head gasket now.
      And the bastard up close. Anyone have a good shop to recommend in Los Angeles that can extract this (and maybe clean up the rest of the head)?
    10. #43
      Oct 2014
      Northern Hemisphere
      Quote Originally Posted by lawdogg View Post
      What do you mean?
      Because the cam sprockets are slotted there is no relationship between those marks and the crank unless you’ve crosschecked them against the actual position of the camshafts at the back of the engine. Each time I do the job I just paint new marks on the cam sprockets because it’s not worth the effort to move the sprockets in their slots unless you need like half a tooth of adjustment.
      Exponents kill
    11. #44
      Oct 2014
      Los Angeles
      I see. For whatever it's worth, I had to move mine in their slots. With the timing aligned, I had to move them in the slots in order to get the cam lock tool installed.
    12. #45
      Member
      Jun 2011
      Congo
      wow that head and engine looks really good ...cam gears = you can put back any way you wana as long as they are cocked clockwise...those timing align marks stamp are most likely produced by factory where they landed by volvo corp techs...i like to put my back by the actual marks not the tech ones and the 8mm adjustment bolts centered exactly in the center just in case you're off...never once was i off that i had to readjust.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
      1997 Avalon - gone - son - space-force
    13. #46
      Feb 2014
      outside Boston area
      Quote Originally Posted by dougy View Post
      I have never opened up my engine but did notice something strange in the pictures.
      If you look at the 3'rd picture down which shows the bottom side of the head, in the top of the view around the end combustion chamber it does not look right compared to the other end of the head in the same view.
      Is this normal?
    14. #47
      Member
      Jun 2011
      Congo
      Quote Originally Posted by dcm0123 View Post
      Is this normal?
      you mean the spark plug missing from cyl #1 ?
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    15. #48
      Oct 2014
      Los Angeles
      Thanks dougy
      And yeah plugs 1 and 5 are out because of the head tool (999 5454)
      If anyone spots anything wrong that I missed PLEASE say something!
    16. #49
      Member
      Jun 2011
      Congo
      Thanks dougy
      Use the cam cover press tool on 2...4 cyls.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    17. #50
      Oct 2014
      Northern Hemisphere
      You didn’t have to pull the CVVT hubs from the cams to get the head apart. Engine looks as one would expect. Make sure to do the banjo bolt of doom.
      Exponents kill
    18. #51
      Oct 2014
      Los Angeles
      Haven't heard this term before - is this the PCV banjo bolt into the head on the driver's side (or the PCV banjo bolt into the intake manifold)?
    19. #52
      Member
      Jun 2011
      Congo
      Intake.. houndog is correct ,get an upgraded one.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    20. #53
      Oct 2014
      Los Angeles
      Got it - this one?
      https://youtu.be/oEOzIoVxO4s?t=518
    21. #54
      Oct 2014
      Northern Hemisphere
      Make sure to use the latest banjo bolt PN 31325709
      Exponents kill
    22. #55
      Oct 2014
      Los Angeles
      Thanks
      Anything else I should make sure to do while it's all apart?
      Here's a platform newb question ... all the Volvo hose clamps that came off, replace with Volvo hose clamps, or use generic hose clamps?
    23. #56
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Thanks
      Use oteker clamps. They’re specified for a reason and work perfectly. Worth it to have a pair of crimp pliers for them anyway.
      2003 V70 T5 - Mystic/Graphite - M56LK - 209k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 303k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 245k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    24. #57
      Oct 2014
      Los Angeles
      Quote Originally Posted by ScottishBrick View Post
      Where's the best place to buy them?
    25. #58
      Dec 2014
      Connecticut
      The most validated way is to match the PNs across the engine through Volvo then make a list of what they are. A full box of assorted sizes will run $25 if you’re feeling adventurous.
    26. #59
      Feb 2014
      outside Boston area
      No, on the bottom of the view below the end cylinder there are three water ports
      In the top of the view above the end cylinder instead of three water ports there appears to be a long slot with a section missing in the middle. Not sure about the missing section.
      Edited after posting-
      I saved the picture then blew it up so I could see it better. The missing section may just be crud on the head. Can not really tell from the picture.
    27. #60
      Oct 2014
      Los Angeles
      I'll put up a pic once I clean the gasket material off. I certainly don't think I blew open a new coolant passage ...
    28. #61
      Oct 2014
      Los Angeles
      Just placed an order with FCP for all the misc crap, head gasket, timing belt, gaskets, etc. Decided to shim with HF feeler gauge which I'll buy tomorrow. My clearances between sleeves (according to my junky digital calipers, so take with a grain of salt, no I don't think it's accurate to half a thou) are 0.0335, 0.0335, 0.0335, 0.0365. I fear the widest gap is too big for the thickest feeler gauge (0.035) but hope it'll work.
    29. #62
      Oct 2014
      Los Angeles
      Decided to trust the work to a professional, so I got a machine shop recommendation for a guy who specializes in engine building (and had a variety of heads in his shop) from a local Volvo specialty shop. Dropped the head off there just now and looking forward to getting it back. He mentioned he helped a local build an 840 block to handle some large turbo, and they went through a couple rounds of the build before discovering that shims solved the issues. That's good for my confidence level, as I will be getting the feeler gauges to use for shims soon.
    30. #63
      Oct 2014
      Los Angeles
      Back from the shop. This guy is amazing.
      Then:
      Now:
      Can't wait to get it all back together.
    31. #64
      Now:
      in "LA", would love that machine shop rec. Glad to see you got the stud out.
    32. #65
      Member n23's Avatar
      May 2009
      Tampa, FL
      Wow - how much did he charge?
    33. #66
      Member
      Jun 2011
      Congo
      Quote Originally Posted by tonyc View Post
      nice, once the head is out it is not hard to remove a broken stud ... you should have had them put in ss inserts...once one stud pulls you will be sorry you did not.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    34. #67
      Oct 2014
      Los Angeles
      The guy did it the next day and charged me less than half a tank of gas.
      Dougy - good idea, but I'm not hanging nearly as large a turbo as you are LOL
    35. #68
      Member
      Jun 2011
      Congo
      different dougy, all out of rehab and all stock tune and k24 man.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    36. #69
      Oct 2014
      Los Angeles
    37. #70
      Member
      Jun 2011
      Congo
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    38. Remove Advertisements
    Similar Threads
    1. Started. Stalled. Started. Stalled. Started.
      By peterbrown77 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-18-2020, 04:04 AM
    2. Broken exhaust manifold stud [XC90 2.5t, 2006)
      By martinvh in forum XC90 (2003 - 2014)
      Last Post: 09-02-2017, 12:03 PM
    3. Broken exhaust stud removal idea
      By kjhiggins in forum S40 & V50 (2005-2012)
      Last Post: 07-21-2017, 10:52 AM
    4. Broken exhaust stud
      By NikMA in forum XC90 (2003 - 2014)
      Last Post: 12-07-2015, 08:03 PM
    5. Replies: 25
      Last Post: 10-30-2015, 10:19 PM
