It all started with a broken exhaust stud - Page 3
    Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 71 to 105 of 248
    1. #71
      Oct 2014
      Los Angeles
      Call me Doctor because I been scrubbing all day
      Looooook at this carbon buildup
      Scrub scrub
      Scrub scrub scrub scrub scrub scrub scrub scrub scrub scrub
      Edit: Holding off on the shims until the roloc disc gets here and I clean off the gasket surface
      04 V70R, 05 M3, 92 Stealth TT, 94 Stealth TT soon to be single T
      Oct 2014
      Los Angeles
      QUESTIONS
      1. What's the Volvo procedure for prepping the deck / sleeve tops for a new head gasket? I've got the old gasket material off w/ brakleen and a razor blade. Does Volvo suggest any sanding or other prep?
      2. Shims w/ feeler gauges. The largest feeler gauge (35 thou) is a snug fit, but I can get it in there by hand. Is this snug enough? Or does it need to be such a tight fit I would need to hammer them in?
    4. #73
      Oct 2014
      Los Angeles
      Any help guys?
      SwedeSpeed.com
      Member
      Jun 2011
      Congo
      1. i prep the head as you did.... and... also if it is pretty bad use brake clean with 3m scrub cloth lightly by hand.
      2. i like them snug ...if you need .036 ...example ...and dont have one in your set i put .017 and .019 together.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
      1997 Avalon - gone - son - space-force
    7. #75
      Oct 2014
      Los Angeles
      Quote Originally Posted by dougy View Post
      Beautiful thanks Dougy
    8. #76
      Oct 2014
      Los Angeles
      Realized I forgot to order new head bolts in last order ... d'oh ... order placed along with S/S brake lines which I've been meaning to do forever.
    9. #77
      Member
      Jun 2011
      Congo
      Quote Originally Posted by lawdogg View Post
      should have put studs on it.
      https://forums.swedespeed.com/showth...-head-stud-kit
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    10. #78
      Oct 2014
      Los Angeles
      Would've if I planned to go nuts with this thing (I have A1 studs in my big build Stealth). Even spent a bit of time looking at some disco potatoes (and read your posts on the topic) but decided against it. Resisting the urge to change the DD into another big build.
    11. #79
      Member
      Jun 2011
      Congo
      not for those reasons ... eliminating torque to yield process , zero chance to fuuck up and if you ever have to pop it off again , again , worth every penny.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    12. #80
      Oct 2014
      Los Angeles
      At $20 per head bolt set, I'd need to pop it off 6 times to break even
    13. #81
      Member
      Jun 2011
      Congo
      when you hear that last torque spec click from your torque wrench on every one of those studs and it's your caR and the extensive work your doing...worth every penny ... when you're doing your torque to yield and your forehead perspiring with all kinds of cheap replacements head bolts outs there , think at that moment what i said.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    14. #82
      Oct 2014
      Los Angeles
      Ok Dougy one more point of clarification - don't want to belabor the point, but, 0.035 will require hammertime to go in. The 0.032 slide in snugly but they do slide in. Combining 0.016 + 0.017 to make 0.033 slides some of the way in, using 0.016 + 0.018 to make 0.034 less of the way in.
      Which do you think is the best choice? (0.032 is sitting there in the pics so you can see the #, but it would slide down all the way if I pushed it.)
    15. #83
      Member
      Jun 2011
      Congo
      i like mine tight/snug, not just pushing in my hand tight...look at the pics how i get them in.
      https://forums.swedespeed.com/showth...ming-T-5-block
      this is the newest style i do now...
      https://forums.swedespeed.com/showthread.php?238406-Shimming-T-5-block/page3
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    16. #84
      Member
      Jun 2011
      Congo
      i like this shim style also ... letting coolant pass /upper deck ... although on my 690awhp they were locked in all the way across.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    17. #85
      Oct 2014
      Los Angeles
      Thanks - I like the bend idea, will try it.
    18. #86
      Member Hounddogger's Avatar
      Oct 2014
      Northern Hemisphere
      If you ever have to take the head off again the block is cracked...
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
    19. #87
      Member
      Jun 2011
      Congo
      Quote Originally Posted by Hounddogger View Post
      negative....bend rods back on 850's and torque to yield bolts.
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    20. #88
      Oct 2014
      Northern Hemisphere
      Freeze them... and maybe they'll fit... Freezer is 0F, outside air is 60-80F... that's a nice delta-T... Can also use computer duster or CO2 to get it down way way lower.
      Exponents kill
    21. #89
      Oct 2014
      Los Angeles
      Yeah alternatively I could torch the sleeves. I'll try gentle hammertime and see what happens.
    22. #90
      Oct 2014
      Northern Hemisphere
      Torching the sleeves will close the gap...
      Exponents kill
    23. #91
      Oct 2014
      Los Angeles
      Man, there you go thinking with logic and stuff
    24. #92
      Oct 2014
      Los Angeles
      Shims are in.
      Ugh, another thing I forgot to order. Someone tell me what else I will discover I also forgot, so I can order that now too.
      Potential issue - possibly not. I don't think this is cause for a head re-surfacing, but LMK if anyone knows better on these heads.
      Sooo much carbon. What do we think - should I hit it with a brass brush to try to clean it off, or just leave it as-is?
    25. #93
      Member
      Jun 2011
      Congo
      i would
      2000 Toyota Tacoma
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    26. #94
      Clean that crap off. Maybe pool some Berrymans chem dip, Seafoam, or other chemicals to break that stuff down. While you have it off, make sure your valve seats are clean too. Also, get a straight edge and feeler gauge and make sure your head is flat.
      Not sure if the myth is true, but supposedly in some P2's they burn valves because of excessive carbon on the exhaust valves, which eventually lead to them not being able to close completely.
    27. #95
      Oct 2014
      Los Angeles
      In a dumb move, I assumed that my local dealership could supply those o-rings so I could get them today.
      Dealer price on 5 o-rings ... $50! LOL! It was Culver City Volvo in LA ... nice enough to offer me them at "MSRP" ... $25.
      Plan B, finding the right size o-ring at a parts store / harbor freight / whatever ...
    28. #96
      Those are the spark plug channel o rings, right? You can get those sometimes at O Reilly’s
    29. #97
      Feb 2014
      outside Boston area
      Be careful because there are many different materials O-rings can be made from and also different hardness's. If you do not have the right one you could have serious problems. McMaster Carr has many sizes and some of the materials. Suggest you make sure you know what material and hardness and size to buy before you go this route.
      Could be a very expensive lesson.
    30. #98
      Oct 2014
      Los Angeles
      Yeah just the spark plug channel seal, should be common, any material that can be exposed to oil and operate at temp will be fine. I probably could just RTV it and be OK. Trust me I'm an engineer.
    31. #99
      Oct 2014
      Los Angeles
      Didn't feel like spending more time driving around, bought 10 of em off FCP. And 10 oil filters just to get the free shipping, haha. It's got 230k on it, it'll be a miracle if it makes it another 10 oil filters.
    32. #100
      Oct 2014
      Northern Hemisphere
      That's what... 50000 miles... look at me...
      Exponents kill
    33. #101
      Oct 2014
      Los Angeles
      That's encouraging! At this point I just want it back on the road. I attempted to hit that carbon buildup in the head with a little brass wheel dremel wheel and harbor freight dremel last night ... didn't even touch it. Let it soak in top engine cleaner for a couple hours, tried again, got a little off but none of the hard caked on stuff.
      Will try it again with my corded drill and see if I can chip away at it, if not, back to the drawing board. Am getting kind of tempted to bring it back to that engine guy who got the broken stud out and ask him to clean up the whole thing for me.
    34. #102
      Oct 2014
      Los Angeles
      Here's a pic. After soaking for a while in Seafoam upper engine cleaner. Not making a dent.
    35. #103
      Aug 2018
      Idaho
      B12 chem tool... Better than seafoam. Alternatively if you know someone with a soda blaster or walnut blaster, that should work well too.
    36. #104
      Oct 2014
      Los Angeles
      Quote Originally Posted by kTaLgsTo View Post
      Thanks for the heads up - I think I'll try it overnight, this time putting in the plugs and filling each chamber with Seafoam. If that doesn't work I'll check out B12 chem tool, looks like only $3.99 at Pep Boys.
    37. #105
      Oct 2014
      Los Angeles
      Well hopefully I just didn't tighten cyl 3 spark plug enough ... otherwise I got a valve seat issue
    38. Remove Advertisements
    Similar Threads
    1. Started. Stalled. Started. Stalled. Started.
      By peterbrown77 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-18-2020, 04:04 AM
    2. Broken exhaust manifold stud [XC90 2.5t, 2006)
      By martinvh in forum XC90 (2003 - 2014)
      Last Post: 09-02-2017, 12:03 PM
    3. Broken exhaust stud removal idea
      By kjhiggins in forum S40 & V50 (2005-2012)
      Last Post: 07-21-2017, 10:52 AM
    4. Broken exhaust stud
      By NikMA in forum XC90 (2003 - 2014)
      Last Post: 12-07-2015, 08:03 PM
    5. Replies: 25
      Last Post: 10-30-2015, 10:19 PM
