upgrading headlights
    Results 1 to 9 of 9
      hey i got the stock headlights and bulbs on a 05 2.5t but cant see anything at night! i am thinking about upgrading the bulbs, what do you guys recommend for the best lighting, i would prefer a cool white if possible.
      Member 91shelby's Avatar
      Apr 2011
      Poulsbo, WA
      I'd recommend the Philips crystal vision ultra. Plus cleaning and polishing the lenses if they are yellowed.
      2004 C70 T5 AT vert 77k Black Sapphire
      2004 V70R GT 144K Silver/Nordkap
      2005 S60R M66 151k Passion/Nordkap
      2007 XC90 V8 Sport 215k Passion Red
      Apr 2015
      So Cal / Inland Empire
      Quote Originally Posted by 91shelby View Post
      THIS! ^^^
      I myself went the aftermarket HID route and haven't looked back. I've done this on every car I've owned in fact. I have some LED headlight bulbs on hand that I plan to try out soon.
      But if you want to only go the bulb replacement route, you really can't beat the Philips Crystal Vision Ultras.
      2004 S60 2.5T - Stock for now...
      Morimoto 2Stroke 2.0 LEDs actually work in these headlights.
      Junior Member Roadboy's Avatar
      Michigan
      Is there any difference between 05 to 07 headlights? These (Morimoto) look very similar to some I have already tried to get in with no luck. They do look a bit smaller in diameter at the "radiator" (as they call it).
      Thanks
      07 S60 2.5T AWD Black Sap Metallic - The Daily ~ 125K!!
      Snabb Turbo Pipe
      ipd rear strut bar
      ipd solid strut mounts
      ipd top poly engine mount
      ipd bottom poly trans mount
      Drop in Filter
      18" Kumho's
      Quote Originally Posted by Roadboy View Post
      Thanks
      Shouldn't be. I didn't have a problem getting them in. Are you sure you had the right base? Lows are H11 and highs are 9005 but you'd be better off modifying a HIR1 base to fit since it's electrically and optimally the same just produces 600 lumens more.
      Michigan
      I had H11 for the low (which I had a problem fitting), but mine has H9 for the high (same as 9005?). What exactly is a HIR1? Google didn't help much, appears to be an upgrade bulb for 9005?
      Thanks again Scottish
      Snabb Turbo Pipe
      ipd rear strut bar
      Drop in Filter
      18" Kumho's
      Oops. My mistake. Should be h11/h9 the 9005 is p80 jewels and p2 01-04.
      Michigan
      Back from the dead! Anybody know if an 07 needs the anti flicker harness? I would think not since the drl isn't half power. Thanks
      Snabb Turbo Pipe
      ipd rear strut bar
      Drop in Filter
      18" Kumho's
    12. Remove Advertisements
    1. Is it worth upgrading to facelift headlights?
      By Stradguy93 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 03-01-2014, 12:36 AM
    2. Replacing/upgrading oem turbo & headlights on a 2000 V70 AWD
      By PPCS2000 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 08-21-2007, 05:52 PM
    3. Headlights are next, where does one buy the Euro headlights?
      By ForceReconTrojan in forum R Forum (2004-2007)
      Last Post: 06-03-2005, 06:15 PM
    4. US Headlights vs Euro Headlights... possible Svenske product
      By Barry in forum R Forum (2004-2007)
      Last Post: 01-15-2005, 09:12 PM
    5. Day running headlights vs. night headlights...?
      By Chronic in forum General Volvo Discussions
      Last Post: 02-01-2003, 10:42 AM
