Stock wheels from 2007 S40 for 2016 S60 Premier
    Results 1 to 3 of 3
      Junior Member Mikcol1's Avatar
      Mar 2019
      Pittsburgh
      Hi all,
      New to the forum. The wife and I traded her 2007 S40 and purchased a 2016 S60 Premier. I am a firm believer in snow tires and had a extra set of wheels set up for winter and summer. They are stock Volvo wheels. My question is can I use the stock 16" wheels on the newer 2016 S 60 for a snow tire wheel? I researched this on Tire Rack and they do call for a 16" with a larger tire instead of using a stock 17" for snow. The bolt patterns are the same but not sure about the back spacing and clearance to the brakes. I tried finding info online but can't find anything.
      Thanks,
      Mike
      Jul 2014
      I’m not 100% sure but if it’s AWD 16” might not be acceptable.
      Jan 2019
      ON, Canada
      You can check here for specs on the wheels for the S40 and S60:
      https://www.wheel-size.com/size/volvo/s40/2007/ for the 2007 S40
      https://www.wheel-size.com/size/volvo/s60/2016/ for the 2011 S60
      Then use the details to calculate differences with original tire here: https://www.willtheyfit.com/index.php?width=225&aspect=50&diameter=17&wheelwidth=7&offset=50&width2=225&aspect2=50&wheel_size=17&wheel_width=8&offset2=55
    1. Looking at a 2016 XC60 T5 Premier
      By gorj in forum XC60 (2010 - 2017)
      Last Post: 10-13-2017, 02:13 AM
    2. Replies: 0
      Last Post: 05-18-2017, 12:02 PM
    3. Replies: 0
      Last Post: 04-16-2017, 02:38 PM
    4. Puredrive's 2016 XC60 T6 AWD Premier
      By PureDrive07 in forum XC60 (2010 - 2017)
      Last Post: 08-15-2016, 07:33 AM
    5. Are Xenon headlights available on the 2016 T5e Premier
      By darb224 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 03-18-2016, 12:16 AM
