2018 S90 Rotors/Pads - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 37 of 37
    1. #36
      Junior Member JC30's Avatar
      Jan 2011
      Corpus Christi, TX
      Quote Originally Posted by amarshall View Post
      I'm back and forth to the dealer with horrible brakes. My brother has a V60 Polestar. Can you swap the V60 Polestar brake system for V90 T6 brakes? His brakes are huge in comparison to mine.
      This is a question for mechanics or those with vehicle expertise that I do not have. Will the braking system even facilitate the larger brakes and work well, modulate properly? I do not know. Moosetech may know if they'll work on the car. May be a pricey upgrade but prove worthwhile.
      I did upgrade my previous 2014 S60 T5 with Brembo brakes (4 piston) and larger T6 rear rotors/calipers. Everything worked.
      It may be possible...
      Sent from my BBB100-7 using Tapatalk
      His: 2016 Focus ST
      Hers: 2018 S90 T5
      Past Volvos: 2014 S60 K-PAX GT5 with KPAX GTR brake kit, ELEVATE turbo intake pipe, ELEVATE intake manifold; 2009 C30 T5 R-Design; 2005 S40 2.4i; 1998 S70 T5
      Aug 2018
      Lodi NJ
      Quote Originally Posted by JC30 View Post
      Front brake pads are 31423652 from Volvo. I went with Porterfield pads that Viva Performance sells. Connor from Viva can help you find what you need if you call as I don't see the link for the pads on their website.
      I do not know the part # for the front rotors. The front rotors are 322mm and rears are 302mm. I kept the stock rear rotors the same, replaced the fronts with an Oreilly's made in India rotor (look like decent rotors despite being from local parts store). Stops well enough.
      Thanks
      Own:
      2018 s90 T6 AWD Inscription w/air suspension B&W Brown interior.
      2017 s60 inscription Platinum FWD
      2003 Oldsmobile Aurora.
      Had:
      2001, 2002 ,Oldsmobile Aurora.
      1998, 1999 Oldsmobile Intrigue.
      Paul.
    4. Remove Advertisements
    Similar Threads
    1. random thoughts: 2018 S90 vs 2018 XC60 vs 2013 S60
      By elefant in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-24-2017, 09:41 PM
    2. 2007 S80 V8 DIY Front Pads, Rear Rotors/Pads - Need Input
      By stockm3 in forum S80 (2007-2016)
      Last Post: 02-04-2014, 11:14 PM
    3. [s90] 1997 s90 p0740
      By DuckRyder in forum 940, 960, S90 & V90 (1990-1998)
      Last Post: 10-24-2011, 03:04 PM
    4. Brake Rotors? Looking for recomendations on rotors and pads.
      By x-omatic in forum S40 & V50 (2005-2012)
      Last Post: 05-04-2011, 03:42 PM
