Project: Wander3 - 2010 XC60 3.2 AWD - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 40 of 40
    1. #36
      Member 95WanderWagen's Avatar
      Aug 2016
      Berks Co., PA
      Fuel pressure sensor in today. Made some difference, smoothed out the idle and less delay on throttle. Weíll see if that is/was part of my missing 4 mpg.
      Sea foam in the gas tank, new Pcv box will be here Thursday. Iíll sea foam the oil and clean everything up inside when I replace it and do an oil change and do a power steering fluid/brake fluid reservoir drain and fill.
      Need to figure out why Iím having trouble filling my gas tank. Itís almost like itís vapor locking and kicks off the pump constantly. Blocked vent in the fill neck? Acting like a vent tube on the p80 cars but no fuel smell.
      Help fund a trip across the country for a volunteer position working with rescued wolves and wolfdogs!
      https://www.gofundme.com/Ptsd-therap..._co_campmgmt_m
      Want brighter, whiter interior lights in your Volvo? PM me for details or email me at [email protected]. Full kits in stock for p80 platform cars
      Ghosts of the past
      3x AMC XJ (84 Cherokee 2.5l, 86 wagoneer 2.8l, 87 Cherokee sport 2.8l 5 sp) || 4x Subaru (96 legacy outback, 97 legacy gt wagon, 92 svx 4.44 auto swap, 88 DL coupe) || 2x Pontiac (88 Fiero 2.5l notchie, 96 grand Prix GT 2.4L) || 3x DSM (92 eclipse GS 4g63 n/a, 99 eclipse gs 420a n/a, 3000gt vr4 sport roof) || 2x Hyunda (96 Elantra 4g63 coupe, 2000 Elantra 4g63 wagon) || 1x Geo storm || 1x VW [93 Fox) || 1x Ford(93 Escort LX 1.9l) || 1x Chevy(2000 venture extended) || 3x Volvo (96 855 2.4l, 95 855 2.3t, 04 xc70 2.5t) || 1x Mazda (2003 Protege5 5sp)
      Aug 2016
      Berks Co., PA
      Seafoamed and replaced pcv, changed the oil for the first time in my ownership.
      Overall what came out of pan and the filter housing were clean af. Pcv trap wasnít terrible but had some chunky carbon buildup that I soaked with seafoam and wiped up.
      Next up, fuel fill issue and growling from wheels
      Ghosts of the past
    4. #38
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      Aren't the low beams H11? I saw a YouTube video of a projector retrofit for a 2009 xc60 and it was amazing. However, I have the morimoto 2stroke LED kit that a might try. I wasn't a fan of the leds in the projector housings of my c30, but maybe they'll work better in the reflector housing on the xc60.
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
      Aug 2016
      Berks Co., PA
      Long time since Iíve been on. Life/work got in the way and Iím out on medical leave now, not sure if Iíll be going back.
      Nothing new to report really. Threw in a few leftover led bulbs in the interior/puddle lights, installed optilux h9 65w low/100w high bulbs and these for fogs:
      https://rover.ebay.com/rover/0/0/0?m...2F254179817388
      Developed the windshield leak back in October. Volvo goodwill resealed the windshield last month and when I got the car back, dealership scratched the windshield on the inside, right in my field of vision. So I ended up with a new windshield anyhow. Didnít clean any of the water damage up originally and refused to clean it up, had to fight with them on it. Still no resolution. Eff it. At least I got to drive a 2020 xc60t6, 2020 s60t5, and the new Xc40 for a few days...kinda mixed feelings on them. The 40 grew on me although the steering feel sucks on all of them (curse you lane assist). The t6 was stuuuuupid fast though and put a smile on my face when passing people.
      Currently working on a curved light bar flush mounted in the lower center grill. The high beams are abysmal even with high watt whiter bulbs.
      Ghosts of the past
    7. #40
      Aug 2016
      Berks Co., PA
      Not so flush mounted light bar. Still needs wired up and properly aligned and I need to install the modified lower grill panel. Looks good from 20 ft but the gaps in the top corner set off my need for perfection (hardware is visible). Sticks out about 1/4Ē from flush but thatís due to my stupidity. Easy enough fix.
      free photo host
      For anyone else that decides to do this, couple tips/tricks:
      1: the bumper does not need to be removed. You can pop the lower grill out by pushing in. There is a wiring harness attached to the lower tabs that need a removed.
      2: I opted to drill 2 holes thru the lower bumper crossbrace and slipped 2 bolts thru as mounting studs to mount to. I had to modify the brackets that came with the light bar by drilling out the center hole that mounts to the bar itself and ground off the front of the mount flush with the bar. With a bit of massaging the bar will mount completely flush with the bumper, there is room there.
      Pretty straightforward install. Wiring will be completed with a Hella HL15113 harness. Hot wired on its own circuit.
      Ghosts of the past
    8. Remove Advertisements
    1. 2010 XC60 T6 vs 2010 XC90 3.2
      By earthling in forum XC60 (2010 - 2017)
      Last Post: 05-14-2014, 04:20 PM
    2. 2010 18" XC60 wheels on a 2014 XC60?
      By Steve36 in forum The Wheel and Tire Forum
      Last Post: 12-27-2013, 09:31 PM
    3. Replies: 4
      Last Post: 07-27-2010, 10:54 AM
    4. Replies: 1
      Last Post: 03-10-2010, 08:37 PM
    5. Replies: 6
      Last Post: 02-12-2010, 10:33 AM
