Front End Clunk - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 57 of 57
    Thread: Front End Clunk
    1. #36
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by ScottishBrick View Post
      Hutchinson. Itís the stock and oe on the p80s.
      All I see available at FCPEuro are the bushings for the P80s, not the entire mount.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by Exocet View Post
      FCP doesnít carry that mount weirdly. Gotta look elsewhere.
      2003 V70 T5 - Mystic/Graphite - M56LK - 201k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 292k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    4. #38
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Both designs are junk. I just buy the cheapest mount and replace often.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
      SwedeSpeed.com
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by Antherzoll View Post
      Yeah, I suspect that's the case. At least with the round design, you can possibly replace the bushing.
    7. #40
      Dec 2014
      Connecticut
      Get a Hutchinson round one or its shell and punch out (or during install) rotate the bushing 90 so it acts as a rubber torque resisting mount not a vertical vibration mount. Itíll vibrate less at idle and help the shifts feel better. I did this to my moms car to bandaid old motor mounts until I can get to them this fall.
      PN 8649597
    8. #41
      Nov 2017
      Southern Tier NY
      PN 8649597
      Thanks for the suggestion. I'll have to give it a try.
    9. #42
      Nov 2017
      Southern Tier NY
      Had a new rear engine mount installed today. Not much change to the vibration while accelerating.
      Engine is definitely smoother starting and shutting off. No more crunching sounds. No real change to the overall NVH characteristics.
    10. #43
      Nov 2017
      Southern Tier NY
      Well, an alignment didn't change anything, but really didn't expect it to. Starting to get high frequency vibrations at other speeds. Really feels like a bearing or maybe a CV joint. But, if it was a bearing, I'd expect it to howl pretty bad. LF bearing and axle are new. RF bearing is original. Seems like the vibration was there before the LF axle was replaced, but after the bearing was. Replacing the RF axle didn't change as anything.
      If I had a truck, I'd think a U-joint was starting to go.
    11. #44
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      Buy a brand new GKN or Volvo axle. If they are too expensive find a decent one at the junkyard.
      I’ve tried almost every aftermarket axle available and they all suck, tolerances are wack. Same goes for aftermarket rebuilds of OE.
      I’ve heard Raxles is good but they are still expensive.
      '09 S40 2.4i
      '04 XC70 2.5T
      '04 S60R M66
    12. #45
      Nov 2017
      Southern Tier NY
      Ordered an old style (round) upper torque mount from eEuroparts (Hutchinson #524824). Received the new style mount (#538850). Now have to deal with returns. FCPEuro didn't have it.
    13. #46
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by LukeFlynn View Post
      Iíve tried almost every aftermarket axle available and they all suck, tolerances are wack. Same goes for aftermarket rebuilds of OE.
      Iíve heard Raxles is good but they are still expensive.
      IIRC, the vibration was there before I replaced the LF axle (which fixed the clunk on acceleration). LF bearing was replaced prior to that (which fixed the noise when turning). Vibration definitely there before/after replacing the RF axle. So, not ready to blame the axles, yet. Still have the original axles, just in case. Only original part remaining in the front end is the RF wheel bearing.
      My Indie is suggesting replacing the RF bearing first, before looking at the LF axle and bearing again.
    14. #47
      Nov 2017
      Southern Tier NY
      Did the RF bearing, no change. Going to pull a couple of ounces of transmission fluid and send it in for analysis to make sure I'm not dealing with a differential or transmission issue.
    15. #48
      Nov 2017
      Southern Tier NY
      Replaced the aftermarket LF axle with the old OEM axle, and the vibration issues appear to be gone. I'll give it a week of driving to be sure.
    16. #49
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      That's promising!
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    17. #50
      Oct 2014
      Boston
      What grease did you use to repack the CV boot?
    18. #51
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by vtl View Post
      Whatever was in the GKN boot kit.
    19. #52
      Oct 2014
      Boston
      Oh, I see. If it says "MOS2" on the pack and does not have consistency of a sick baby's snots then the grease is wrong. All the GKN kits I had were equipped with the grease for the outer CV joint, not tripods. For tripods you want a different grease, like GKN 1476-051. I got VW G052186A3, which says "tripods", too, however it looks a bit less watery, so I don't know how that would affect the tripod. Time will tell, but MOS2 GKN grease cost me two perfectly fine axles...
      Don't put MOS2 grease into tripods, it kills tripods instantly.
    20. #53
      Nov 2017
      Southern Tier NY
      Wonderful. It was a bit thicker than the old grease, but the old grease had 160k miles on it. Dark gray. So, I suspect it's the wrong type (molybdenum disulfide?). It is what it is at this point.
    21. #54
      Oct 2014
      Boston
      Yeah, wrong grease. MOS2 particles wear needle bearings out. The grease itself is too thick and does not provide good lubrication for needles. It also does not withstand a higher working temperatures typical for the needle bearings.
      I don't know why GKN puts MOS2 grease in the kit. Probably, for all of us to go out shopping for the new GKN axles.
    22. #55
      Nov 2017
      Southern Tier NY
      The grease in my kit was:
      GKN Bru-Moly CE 1/2
      Poking around online there's also GKN CV Joint grease, that has a different part number. I also found a patent from 1995 for a tripod grease with moly in it. Lots of discussions in various forums.
      Strange that GKN would sell a boot kit specifically for a tripod joint with an incorrect grease. But, at the same time sell a grease for tripod joints.
    23. #56
      Nov 2017
      Southern Tier NY
      Well, spent way too much time looking around online WRT inner tripod joint grease.
      The GKN tripod joint grease is an NLGI #1 polyurea thickened grease with a drop point of 260C. Seems to only be sold through racing oriented sites, which is a bit strange. This seems to be what's in the OEM axles. It's about $50 a tube (enough for 4 joints).
      For tripod joints it looks like you need something that's EP rated, NLGI #1 (though #0 might work if it's max temp is high enough), wide temp range (-30C to +170C, min), a drop point of about 250C or higher, and no solid additives (specifically MoSO2). You also want a grease that's very sticky. The choice of thickener, lithium or polyurea, really doesn't matter as long as you don't mix the two.
      I found a Russian Lada site that had a lot of info on tripod joint lubrication, though Ladas weren't the pinnacle of engineering excellence! They had a list of greases suitable for tripod joints. Those were:
      Slipkote Polyurea CV
      Castrol Optitemp XBT1LF
      Mobil SHC Polyrex 005 or 221
      Chevron Ulti-plex Synthetic EP
      Chevron Delo EP NLGI #1
      Mobilgrease XHP 222
      The first 2 specifically mention tripod joints. Unfortunately, most of these are speciality greases you won't find in your average parts stores, or are only sold in large quantities. Honda sells tubes of tripod joint grease, as well. So, that might be an option. I also found John Deere Corn Head NLGI #0 mentioned as a possible grease. EP rated with a temp range of -34C to +165C. But, I was a bit concerned with its max temp.
      I picked up a tube of the Delo EP for ~$7. NLGI #1, temp range of -40C to +177C, with a drop point of 245C. I'll try it in my spare axle and see how it works.
    24. #57
      Nov 2017
      Southern Tier NY
      Cleaned out the right tripod joint and put in 80g (GKN recommended amount) of new grease. The Delo EP is soft at room temp and quite tacky. It's even Volvo blue!
      The axle will go in Tuesday. I'll see how it does.
    25. Remove Advertisements
    Similar Threads
    1. Pop or clunk from front end
      By flyboy621 in forum R Forum (2004-2007)
      Last Post: 04-13-2016, 04:21 PM
    2. Left Turn Clunk-Clunk-Clunk
      By mgfletcher145 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 09-21-2011, 04:09 AM
    3. Left Turn Clunk-Clunk-Clunk
      Last Post: 09-20-2011, 06:39 AM
    4. BANG! CLUNK clunk clunck clunk OH [email protected]#$$%
      By Thanatos in forum R Forum (2004-2007)
      Last Post: 11-19-2010, 02:58 PM
    5. front end clunk on 99 v70r
      By besthaticouldo in forum S70, V70 & V70XC (1998-2000)
      Last Post: 06-08-2010, 07:58 PM
