Light for door sill plate
    Results 1 to 8 of 8
      Junior Member BigBang's Avatar
      Mar 2018
      World
      Has anyone bought and installed this ?
      Is a complicated installation ?
      https://www.volvopartswebstore.com/p.../31479061.html
      2018 XC60 T5 R-Design
      Junior Member Dystaxia's Avatar
      Aug 2017
      Tennessee
      Quote Originally Posted by BigBang View Post
      I just recently did this. The only issue I had was the wiring harnesses that are needed to connect them are on nation wide back order. So, I had to get the connectors for another site and build my own.
      One thing I did notice on the factory installed plates was, and it was a shocker, was they are actually the lighted version, but they cut off the connector. If you feel adventurous, you could trim out and repair the wire connection. I already had mine in hand, so I didnít bother with the extra work.
      I have all the part numbers for the connectors, and can post them in a couple of days; Iím currently away on vacation at the moment.
      2018 XC60 T8 R-Design | Bursting Blue | Convenience | Vision | Advanced | B&W Premium Sound | Heated | Air Suspension
      2006 XC90 2.5T AWD | Grey | SOLD
      Mar 2018
      World
      Quote Originally Posted by Dystaxia View Post
      Thanks for answer
      Is it perhaps this connector: Part Number: 31435634
      Number 6 on this diagram
      https://www.volvopartswebstore.com/s...oduct=10899435
      SwedeSpeed.com
      Aug 2017
      Tennessee
      Thanks for answer
      Yes, thatís the factory harness, but when I tried to get it, about two months ago, they were back ordered.
    7. #5
      Mar 2018
      World
      Thanks for your reply
      It is interestingly impossible to order this part online, it says: Contact your local retailer for more information. All other parts can be ordered but this one does not. Weird
      This is standard equipment in Germany for the MY2020
    8. #6
      Aug 2017
      Tennessee
      If you want to build them yourself, I can post the part numbers of the individual parts required, and where to get them.
    9. #7
      Mar 2018
      World
      Thank you very much but I gave up
      2 pieces of wire cost $ 76 + $ 252 for the door sill light
      I think $ 330 is a lot for that
    10. #8
      Nov 2018
      Mississauga, ON Canada
      Interesting!!! I am tempted to take mine apart to see if I have the LED sill installed too...
    11. Remove Advertisements
    Similar Threads
    1. Rear Door Sill Protection
      By need4spd in forum XC90 (2003 - 2014)
      Last Post: 01-04-2015, 04:10 PM
    2. crazy door sill idea...
      By Dygitalpmp in forum S40 & V50 (2005-2012)
      Last Post: 06-06-2006, 07:43 PM
    3. s40 Door Sill protector.
      By morenar-s40 in forum S40 & V50 (2005-2012)
      Last Post: 01-05-2005, 03:30 PM
    4. Aluminuim door sill rust???????
      By s70pimp in forum R Forum (2004-2007)
      Last Post: 06-22-2003, 07:04 PM
    5. Door Sill Protectors
      By rst1121 in forum XC90 (2003 - 2014)
      Last Post: 05-06-2003, 05:30 PM
