The Platinum Project aka S850R - Page 2
    Page 2 of 3 FirstFirst 1 2 3 LastLast
    Results 36 to 70 of 83
    1. #36
      Junior Member nick_rabbo's Avatar
      Dec 2009
      Dallas/Fort Worth
      Yeah I know exactly what video you're talking about. Sounds good
      Sent from my ONEPLUS A5000 using Tapatalk
      2004 Volvo S60R - SOLD - Elevate Body Kit, Tune, Downpipe and Exhaust, Snabb Intake.
      1997 Volvo 850R - 130K - 16t Angled, R Manifold, Maximizer OBX Downpipe and Exhaust, Snabb Intake, Snabb FMIC, Blue Injectors, Beust/Vast Tune, 302mm BBK, CherryTurbo Strutbrace, Do88 Silicone Hoses (All), Koni Sports Front & Rear, IPS Sways, H&R Springs, H&R rear 20mm spacers, Nokian zLine A/S 215/45/17. (Soon to be installed: S90 MAF, Quaife LSD, 7+7 hybrid K24, DW 900cc Injectors, DW200 Pump, e85. Then I'm done, I promise. Maybe.)
      Aug 2018
      Oh yeah...the OBX down pipe bolt holes didnít line up just right. I had to enlarge one hole slightly. I destroyed 2 drill bits during this process. Stainless steel is hard (huge understatement!)
      [IMG][/IMG]
      1996 850 Platinum/Charcoal Sedan, 195,000 miles, B5254T4/M56
      1999 S70 GLT Black/Black, 238,000 miles
      2005 S40T5 M66 Silver/Black, 225,000 miles
      1995 850 GLT Sedan, Regent Red/Charcoal, 186,000 miles, been in family since new
      2017 VW GTI, Graphite/Tartan, 26,000 miles, DSG
      2006 S60R, Silver/Nordkap, M66, 98,000 miles, parts car, SOLD
      1999 S70 GLT, White/Taupe, 138,000 miles, TOTALED RIP
    4. #38
      Dec 2009
      Dallas/Fort Worth
      Smh. I remember the same exact thing happened to me with my stainless steel obx unit. In the end, I had to send it back and got the black maximizer unit instead (same company).
      Maybe you got the same one I sent back LOL
      SwedeSpeed.com
      Dec 2014
      Indy, IN
      Odd. Neither of my OBX/MEX kits had that issue.
      '97 854 T5 & '97 855 GLT(RN LPT swap/16T/ETC) (wife's)
      '78 264 (Future Whiteblock/T5 swap)
    7. #40
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by nick_rabbo View Post
      Iíve heard of that on a few occasions.
      IPD is now also outsourcing and cheaping out on their p80 turbo back, last one that was installed didnít fit the turbo initially and then had to be cut and welded because it was a serious interference fit with the front subframe and then hit the gas tank even with heat shields removed.
      Quality control has gone to ****
      2003 V70 T5 - Mystic/Graphite - M56LK - 201k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 292k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    8. #41
      Aug 2018
      Rip kit and turbo inlet
      We replaced all of the intercooler piping with the Snabb reverse intercooler piping kit. There has been some debate whether RIP kits reduce turbo lag and increase throttle response and power...but I just really like the way they look. The Snabb kit we ordered came with the the larger elbow to fit the 3 inch throttle plate. We ordered the black silicone hose kit but were shipped the blue by mistake. We were anxious to to finish the build so we kept the blue. I did have to modify the over the engine pipe where it connects to the turbo. The K24 turbo compressor discharge comes out at an angle rather than straight up like the TD-04. The compressor exit side of the Snabb pipe has a short straight section, a slight bend, another short straight, and then a bend to go over the engine. I had to cut out the slight bend between the two short straights to get the pipe to line up with the turbo. I had my friend Joe weld the 2.5 inch aluminum pipe back together after I cut out the bend. I hated to cut the beautiful aluminum over the engine pipe but Joe made it look like it was always that way.
      We also installed the Snabb Performance Fresh Air Pipe fitted to the K24 turbo. This time the silicone hoses came black...Oh well. In addition, we installed the larger 3 inch MAF housing from the Volvo 960. I should have taken the MAF when I got the throttle plate from the 960 at the junk yard. I couldnít find another used one and bought a aftermarket one off ebay for $25 putting the original sensor in the aftermarket housing. I wanted to keep the look of the stock air filter housing and found that the air-box lid from a Ď99-Ď00 S/V70 with the lpt engine has a 3 inch hole that accepts the 960 MAF housing perfectly. Itís too bad it doesnít say ďTURBOĒ like the original box.
      One thing I wish we would have done at this time was to replace the intercooler with a Snabb or Do88 intercooler.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      Joe has some serious welding skills!
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
    9. #42
      Aug 2018
      The shift knob is from some random Audi we found in the junkyard. It fit like a glove once I cut the skinny part off the top of the shift lever...and it has the proper shift pattern! The shift boot is a $15 aftermarket ebay special. Itís just tucked into the console hole for now until I can come up with a better way to mount it. I think the combination of the floor mounted P1 shift assembly and the slightly shortened lever make the shifter significantly shorter than the stock manual 850. This was welcomed as I think the stock shifter is a little too tall.
      We will probably replace the shift knob at some point but I kind of like the round ball.
    10. #43
      Aug 2018
      Itís alive!
      And itís fitting this Frankenstein sparked to life around Halloween.
      Like the German monster this Swedish beast is a mixture of others pieces and parts.
      The car: Ď96 850 Platinum sedan
      The engine: B5254T4 from a Ď06 S60R
      The transmission: M56 from a Ď07 S40
      Intake manifold: N/A manifold from a Ď94 850
      Throttle plate: Ď96 960
      Air filter housing lid: Ď99 S70
      Engine mount bracket: Ď99 V70 XC
      Clutch/brake pedal assembly: Ď95 850
      Power steering lines: Ď00 V70
      Coolant reservoir: Ď99 S70
      A/C compressor: Ď00 V70
      Lots of new parts as well...
    11. #44
      Dec 2014
      Connecticut
      Get an 05+ ps reservoir. Doesnít leak, fits better, improved design.
    12. #45
      Dec 2014
      Indy, IN
      I was scrolling through pics and the wife noticed the RIP kit on it.
      She was like "What's that? Mine doesn't look like that."
      I explained it to her and she replied with "I like it. Can we do it to my car?"
      *sigh*
    13. #46
      Aug 2018
      Quote Originally Posted by ScottishBrick View Post
      I didnít use the reservoir from the S60R as it had connections for a power steering cooler which the 850 doesnít have. I did however eventually replace the reservoir with a new OEM unit.
    14. #47
      Aug 2018
      Here are a few early tune 3rd gear (and a little bit of 4th) datalog pulls. The car has been running great and has been problem free. The tuning process takes some time so you need to be patient. Aaron at Vast is very knowledgeable and helpful (and busy). It might be a day or so for a response but he always gets back to you. He looks over the datalogs, makes some adjustments and send a new tune to download to the car.
      The videos are from November 2018 or about 3 weeks after we finished the first stage of the build. The weather changed to winter in Michigan shortly after this. Winter tires and wet roads postponed 3rd gear pulls and further tunes for a little bit. Jake continued to put miles (and smiles) on it over the winter as it is his daily driver. Itís amazing how the manual swap changed the driving dynamics of the car. The M56 from the S40 has a pretty short final drive which is nice for acceleration but not the best for fuel economy. It really revs when on the highway.
      Notice the knock detection at the 20 second mark
    15. #48
      Aug 2018
      Here are a few more datalog pulls from February 2019 including clips from the laptop. For some reason the wideband reading on the laptop was displaying higher than the gauge in the car. The injector duty cycle is getting close to the limit with the original green injectors. We will most likely upgrade these in the future...and possibly go to e85. Is the dw200 fuel pump big enough for e85?
    16. #49
      Aug 2018
      The wheels:
      We kept the 18Ē Pegasus wheels from the Ghettolvo to use on the Platinum. Two of the wheels were poorly painted gold and were in pretty rough shape. The other two were decent but IPD replicas.
      [IMG][/IMG]
      The oem pegs filling in as a engine stand.
      [IMG][/IMG]
      The gold set after a chemical strip.
      [IMG][/IMG]
      [IMG][/IMG]
      The IPD fakes.
      [IMG][/IMG]
      I wound up having the oems sandblasted after the chemical strip...probably should have just had them sandblasted from the start. I hand sanded them as a final step to make them ready for paint.
      Jake sprayed them with ďBrass MonkeyĒ plasti dip after new rubber was installed. We went with 225/40R18 Nokian zline a/s...to keep with the Nordic heritage lol.
      [IMG][/IMG]
      [IMG][/IMG]
    17. #50
      Aug 2018
      April 2019. Springtime in Michigan.
      Time for phase 2 of the build.
      [IMG][/IMG]
    18. #51
      Dec 2009
      Dallas/Fort Worth
      Nice nice nice. I see some coilovers...
    19. #52
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Good taste in tires I see
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 136k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: COMING SOON! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    20. #53
      Aug 2018
      Phase 2:
      [IMG][/IMG]
      One thing we soon found when doing the 3rd and 4th gear pulls was that the brakes were no longer up to the task of rapidly slowing the car from high speeds. We had salvaged the Brembo calipers from the Ghettolvo with the intention of using them on the Platinum, however I knew it would not a simple/bolt on job. Rear caliper brackets are easily available but the fronts are not.
      Luckily Jake is a design engineer. Using a caliper and rotor from the Ghettolvo along with a knuckle I removed from a S70 at the junkyard and some inspiration from the internet he designed a bracket that looked like it would work. He had the part 3D printed so we could mock up and test fit the caliper to the knuckle. Modification to the knuckle was needed to get the calipers to fit. The steering stops were cut off and Time-Serts were installed in the caliper bolt holes. Once we were convinced it would work Jake had them CNC machined from a high strength alloy.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      Braided stainless steel brake lines replaced the rubber hoses to the front calipers. I had to modify/move the mounting bracket to give the lines more slack they were too short to fit the larger Brembo calipers.
      New OEM brake pads and rotors (330mm front and rear!) were installed along with a brake fluid change. The rear caliper brackets were sourced from IPD.
      Bigger brakes=bigger wheels...the stock 16Ē Persus wheels will no longer fit.
      [IMG][/IMG]
      In addition, the right rear wheel speed sensor was replaced which was causing an ABS and Tracs Off warning light to be on.
      New OEM lower control arms were installed to replace the cheap aftermarket ones I had put on couple years ago whose ball joints already had play. Also, as part of the suspension refresh, the shocks and springs were replaced with a new set of BC Racing coilovers. We had to roll the rear fenders and trim the rear wheel liners to keep the rear tires from rubbing. Note: We have 15mm spacers on the rear wheels for aesthetic reasons only. I was pleasantly surprised with how well the car rides. Itís firm but not harsh. Frankly, I was expecting it to be much harder considering it also is rolling on 18Ē Pegs. The front tires will rub when approaching lock. I suspect it has more to do with the 225/40R18s than the lack of steering stops.
      The braking performance in phenomenal. After performing several hard stops to bed-in the new pads/rotors I started to get light-headed. In fact, I didnít feel all that well for about a half hour after lol.
      May 2019
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
    21. #54
      Dec 2009
      Dallas/Fort Worth
      Imagine if the 3D printed bracket was left on the car lol.
      But that is pretty cool, definitely next level mechanic'ing going on. The 302mm BBK in my opinion doesn't make much of a difference.
    22. #55
      Jan 2014
      Boston, MA
      Nice adapter bracket. I've seen people doing some sketchy shiit to adapt P2R Brembos to P80s, so this is a pleasant departure from that!
      what pads are you running
    23. #56
      Dec 2009
      Dallas/Fort Worth
      Quote Originally Posted by JaredR View Post
      Akebono Euro
    24. #57
      Dec 2014
      Connecticut
      Akebono Euro
      OH. Thatís why they donít stop great. Try Hawk HPS OE even ATE pads.
    25. #58
      Dec 2009
      Dallas/Fort Worth
      Now that I'm remembering, I recall you guys saying the akebonos were crap. Yeah I'll switch them out soon.
    26. #59
      Jan 2014
      Boston, MA
      They're so bad that my dad hated them on his NA.....that car doesn't even go fast...
    27. #60
      Dec 2009
      Dallas/Fort Worth
      Lollll.
      Damn.
    28. #61
      Jan 2014
      Boston, MA
      Lollll.
      Damn.
      We're putting Hawks on it 👍👍👍👍
    29. #62
      Aug 2018
      I almost forgot about some minor cosmetic changes you might have noticed in the last postís pictures.
      We installed e-code headlight lenses, clear front parking/turn signal assemblies, and a egg-crate grill. The Volvo slash is from a XC90 that I picked from the junkyard.
      Jake took the car to a few Cars and Coffee events in the spring. It was fun showing off the hard work that went into the build although most of it goes unnoticed. Itís a compliment in a way as it doesnít look radically modified but instead looks like it could have come from Sweden this way. The Volvo enthusiasts will notice, however most of the time it was the only Volvo at the show.
      May 2019 Cars and Coffee Grand Rapids, MI
      [IMG][/IMG]
      [IMG][/IMG]
      Photos from DMD Photographic
      June 2019 Cars and Coffee M1 Concourse, Pontiac MI
      [IMG][/IMG]
      June 2019 Cars and Coffee Grand Rapids, MI
      [IMG][/IMG]
      Photo from DMD Photographic
      Jake also got a euro plate with the same letters/numbers as his regular tag. In addition, he put the proper registration sticker on the plate. Technically itís not legal to the letter of the law but he has the original plate in the car if he gets stopped.
      [IMG][/IMG]
    30. #63
      Member Chicago_Wagon's Avatar
      Jan 2016
      Chicago, IL
      Quote Originally Posted by HATTRICK2199 View Post
      Wow, around here you would be ticketed immediately. The city/state needs it's revenue!
      Current - 2000 V70R Venetian Red Pearl
      Past - 1998 V70 XC Emerald Green Metallic
      RIP - 1987 Mazda RX-7 White/Red (first car, many speeding tickets, blown rotary engine)
    31. #64
      Jan 2014
      Boston, MA
      Yeah I'm also really surprised that plate is working. I don't think that would fly in MA either. Please report back on how that works out if he ever gets pulled over lol.
    32. #65
      Aug 2018
      This damaged R front bumper was on the car when we bought it back in 2015. I took it off shortly thereafter and replaced it with a stock front bumper that we got for free (it just needed painting). I put it in the attic with the idea that someday we would repair it and reinstall it on the Platinum.
      Finally the car was worthy.
      I sanded the old/chipped paint off until the bumper was smooth. I bought a cheap plastic welder from Harbor Freight and attempted to repair the cracks. I failed miserably and quickly learned that Iím not a body man. I had a friend who has a mobile touch-up/bumper repair business fix the bumper and then had a local bodyshop spray the tri-coat platinum paint for me.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
    33. #66
      Dec 2009
      Dallas/Fort Worth
      That platinum color looks so delicious.
    34. #67
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      Wow I've been SLEEPING on this thread! Phenomenal job on the car from the last couple posts, I'll have to read through the whole build after finals because it looks like you've done an amazing job. I've been thinking of doing brembos on my 850R, do you still have a .stp file or part file for those front brembo adapters? I'd love to get my hands on those if you're willing
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Past:
      1998 V70 NA/m Classic Red/Light Gray
    35. #68
      Dec 2014
      Indy, IN
      Phase 2:
      From your post on the brake upgrade.
      What rear brackets were sourced from IPD? Didn't see anything in a quick scan under either application.
      (EDIT- I might also be interested in the part file for those front adapters, if you're willing to share.)
    36. #69
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by Chuck W View Post
      What brackets were sourced from IPD? Didn't see anything in a quick scan under either application.
      I've been digging around, haven't found any front brackets for brembos but found this from Yother's website https://yother.com/collections/brakes
      Past:
    37. #70
      Aug 2018
      Sorry guys, my mistake. The rear brackets came from Yotherís not IPD.
      The front brackets werenít exactly plug and play. There are some modifications needed to the knuckle such as cutting off the steering stops and installing the time-serts. In addition, I had to trim off the steering stop pads from the front control arms to clear the brackets. I donít know if we want the liability if something goes wrong but I will ask Jake if he would be willing to share the design (for a small fee possibly).
    38. Remove Advertisements
    Similar Threads
    1. XC90 V8 Swap Project AKA The Swedish Whale
      By jcdillin in forum XC90 (2003 - 2014)
      Last Post: 07-11-2019, 08:28 AM
    2. 2015 XC70 AWD 3.2L Platinum or AWD T6 Platinum, with similar price?
      By laughers in forum V70 & XC70 (2008 - 2016)
      Last Post: 05-28-2015, 03:59 PM
    3. safe and sound aka safe and secure to end any time soon?
      By Psychwarlord in forum V70 & XC70 (2008 - 2016)
      Last Post: 04-15-2010, 11:22 PM
    4. Project Car (aka not the R)
      By FORD420diesel in forum General FWD & AWD
      Last Post: 12-30-2007, 10:06 AM
    5. Replies: 13
      Last Post: 01-12-2002, 12:46 AM
