The Platinum Project aka S850R - Page 3
    Page 3 of 3 FirstFirst 1 2 3
    Results 71 to 99 of 99
    1. #71
      Aug 2018
      I did find these after we made ours. Looks like less modifications needed to the knuckle.
      https://www.l-m-r.se/p/volvo/850/bro...-v70-fram.html
      1996 850 Platinum/Charcoal Sedan, 195,000 miles, B5254T4/M56
      2006 V70R Sonic Blue/Gobi, 151,000 miles, automatic (for now)
      1999 S70 GLT Black/Black, 238,000 miles
      2005 S40T5 M66 Silver/Black, 225,000 miles
      1995 850 GLT Sedan, Regent Red/Charcoal, 186,000 miles, been in family since new
      2017 VW GTI, Graphite/Tartan, 26,000 miles, DSG
      2009 Ford Flex SEL awd, Grey/Black, 140,000 miles Wifeís daily
      2004 Mercedes-Benz C320 4matic wagon, Black Opal/Grey, 215,000 miles
      2006 S60R, Silver/Nordkap, M66, 98,000 miles, parts car, SOLD
      1999 S70 GLT, White/Taupe, 138,000 miles, TOTALED RIP
      Dec 2014
      Indy, IN
      Quote Originally Posted by HATTRICK2199 View Post
      Looking at that, they use a 350mm Nissan Z rotor, instead of the 330mm Volvo one. That probably makes it a *little* easier to fit it around the spindle.
      Looks like you need to drill/mod the rotor to get it on the car also, as they're the wrong BCD.
      '97 854 T5 & '97 855 GLT(RN LPT swap/16T/302's/ETC) (wife's)
      '78 264 (Future Whiteblock/T5 swap)
    4. #73
      Dec 2014
      Indy, IN
      The front brackets werenít exactly plug and play. There are some modifications needed to the knuckle such as cutting off the steering stops and installing the time-serts. In addition, I had to trim off the steering stop pads from the front control arms to clear the brackets. I donít know if we want the liability if something goes wrong but I will ask Jake if he would be willing to share the design (for a small fee possibly).
      I guess just see what he says. I've done several custom brake swaps on other vehicles before, so I'm not overly concerned. Just trying to save a little legwork. I'd gladly pay a fee for the design. I've paid (and charged) for similar things in the past.
      SwedeSpeed.com
      Aug 2018
      Another part we kept from the Ghettolvo was the steering wheel. Installation required slight modification. The horn contact was removed from the original wheel and installed in a carefully drilled hole in the S60R steering wheel. In addition, I had to grind off a bit from the hub on the back side of the wheel to close the gap with the steering column trim. The airbag plugged into the existing wiring. Sadly the radio and cruise control buttons do not work but the thicker rim and slightly smaller diameter really feel good in your hands.
      S60R + 850 turbo = S850R
      [IMG][/IMG]
    7. #75
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      The DOT 850 wheel is so bad. I managed to score original ECE wheels for both of my 850s. So much better. I should compare the diameter to my S60's wheel sometime.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    8. #76
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      [IMG][/IMG]
      Looks great! I dream of steering wheel control buttons in a p80 lol
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Family Fleet:
      2000 S40 1.9T White/Cloth
      COMING SOON: 2009 C30 T5 R-Design M66 Silver/Two-Tone
      Past:
      1998 V70 NA/m Classic Red/Light Gray
    9. #77
      Aug 2018
      Itís funny how you can live with things like a saggy headliner for years. However, once you fix up a few other items and take it to a couple car shows these things start to bug you.
      I bought a couple yards of Moleskin, Faux Suede from the local Fieldís Fabric store. Itís sometimes called microsuede and it was only about $10 per yard. Unlike the tailgate on the wagon, the headliner comes out the passenger side front door on the sedan. You need to recline both of the front seats and angle the headliner so the passenger side of the headliner is at the top/back side of the door opening and the driverís side is at the bottom/front. The old fabric was stripped off and the headliner was cleaned with a wire brush. We used a can of 3M Headliner and Fabric Adhesive to stick the faux suede to the original panel. We also used fabric spray paint on the sunroof trim and the clips that secure the headliner near the back window. The grab handles and visors will get the same treatment eventually.
      Overall, Iím happy with the way it tuned out. It has the look of Alcantara but is much cheaper and simpler to install. The stretch of the microsuede makes it much easier to follow the contours of the headliner.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
    10. #78
      Dec 2014
      Indy, IN
      Looks good. I just used the standard headliner fabric when I did my 854.
      I took my headliner out the trunk, though.
      Removing the side trunk panels gives just enough room to get it through.
    11. #79
      Aug 2018
      August 2019 Cars and Coffee Grand Rapids, MI
      [IMG][/IMG]
      [IMG][/IMG]
      German Auto European Car Show August 2019
      [IMG][/IMG][IMG][/IMG]
      Northern Worthersee September 2019, Frankenmuth MI
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      I trimmed and installed the P2 injector rail cover. Should be good for +5hp
      [IMG][/IMG]
      The Platinum with our Ď95 N/A 854
      [IMG][/IMG]
    12. #80
      Jul 2016
      Stockholm
      Such a nice car and that color!
      2012 V60 3.0 T6 AWD 452 black sapphire - Polestar tune, Polestar wheels 8x19". Simons 3" exhaust. JR air filter. H&R springs. R design front, diffusor, steering wheel, pedals. Frameless mirror, MY13 gear shifter, MY15 TFT DIM. MA602-90.
      1995 855 T-5R automatic 421 dark olive pearl - The long time project.
      https://www.instagram.com/t6blacksapphire/
    13. #81
      Aug 2018
      Quote Originally Posted by Briander View Post
      Thank you! Itís not often that we a have a car here in the states that wasnít available back home in Sweden.
    14. #82
      Aug 2018
      Winter in Michigan.
      The biggest drawback for the big brakes from the S60R is the limitation on wheels that will clear the calipers. I had a new set of Hakkapelitta R2 winter tires mounted on the existing Tethys only to find out that they hit the face of the calipers.
      The Tethys:
      [IMG][/IMG]
      The 17Ē diameter was fine but the 49 offset and depth of the spokes was not. The ideal setup would be 17Ē Pegs but we searched and searched and were not able to find any. We wound up getting some rough but straight Volans from my friend Dan.
      The Volans:
      [IMG][/IMG]
      Volans have an offset of 43 and still required a 10mm spacer to keep from hitting the caliper face. We used a 20mm spacer on the rear to balance the look. I had the tires dismounted from the Tethys and mounted/balanced on the Volans. I bolted on the Volans and gave them a spin. They rotated about 180 degrees and stopped with a thunk....youíve got to be kidding me. It turns out one of the stick-on wheel weights was hitting the caliper. I had the wheel and tires rebalanced with clip on weights instead.
      Close quarters:
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      In addition, we cranked up the coilovers to raise the car about an inch.
      Strangely, we havenít had any significant snow since but Iím sure itís coming. It is Michigan after all.
      [IMG][/IMG]
      This post brings us current. Jake has put about 12,000 miles on the car since the transformation in October Ď18.
      It pains me a little that he has to drive it in the winter but it is his daily driver.
      Black steelies on the the rest of the Volvo fleet:
      [IMG][/IMG]
    15. #83
      Junior Member cyester's Avatar
      Jul 2017
      Birmingham, Alabama
      Too bad the Tethys wont fit. That may be my favorite OEM Volvo wheel.
    16. #84
      Aug 2009
      Car looks amazing!! Love the bbks!!
    17. #85
      Jan 2014
      Boston, MA
      Are you saying that the Volans clear the R calipers up front with a 10mm spacer?
    18. #86
      Junior Member Flat467's Avatar
      May 2015
      Lancaster
      How did I miss this post in January! That looks great man. It's a platty R clone and I absolutely love it. Badge Idea...hear me out....S860PR. If it fits on the trunk haha
      The clearance of those calipers would scare the sh!t out of me, but props to you for making it work! I'm sure I might get burned on this comment, but...I dig Volans with winter tires on them. They look aggressive and capable of taking on anything. It's like when you see a WRX or STI with winter tires. Beats the slick look any day (except over the summer haha)
      Ever going to refurbish those Volans?
      Present:
      '87 240 DL - 177k -
      '97 855R - ???k work in progress
      Past:
      '94 855 Turbo
      '95 854 Base
      '95 854 T-5R
      '00 V70 R
    19. #87
      Aug 2018
      Took the winter tires/wheels off last weekend and reinstalled the pegs. We didnít have much of a winter in Michigan this year. It was kind of disappointing. Left the ride height raised for now.
      JaredR- 10mm is super tight. 12mm-15mm would be better.
      Flat467-Yes, planning on refinishing sometime this summer.
      And it finally happened. Jake got pulled over for his euro-plate a few weeks ago. He didnít get a ticket but the police confiscated the plate. They had him reinstall his original official plate that he had with him in the car. Iím surprised it didnít happen months ago.
    20. #88
      Aug 2018
      The low coolant light came on a few weeks ago. Coolant was low but leak was not obvious. Topped off coolant but low level light came back after about a week. Fearing the worst, I brought a block tester home from work to check for a bad headgasket (or cracked cylinder). Luckily there were no signs of combustion gasses in the coolant. Pressure tested the cooling system and found a small leak from the radiator. It was seeping from the transmission cooler connection which I had removed when we did the manual swap...maybe that created the leak?
      Jake thought it would be a good time to replace the intercooler along with the radiator.
      Dang that DO88 is heavy!
    21. #89
      Aug 2018
      Has anyone seen this before?
      [IMG][/IMG]
      I replaced this crank sensor about a week ago (just because I had a new one). There was nothing wrong with the old one.
      [IMG][/IMG]
    22. #90
      Aug 2018
      Itís not good. Something came loose in the bell housing. Found lots of metal shavings using a scope. Pulse wheel teeth on the flywheel are chipped up as well. Transmission needs to come out.
      [IMG][/IMG]
    23. #91
      Dec 2014
      Indy, IN
      That's a bummer.
    24. #92
      Aug 2018
      Now I know what damaged the crankshaft position sensor. But what caused the clutch to come apart? The clutch, pressure plate, slave cylinder/throw out bearing and single mass flywheel were all new when we built the car. The clutch is a OEM S60R assembly.
      The car has about 20k miles on it since the B5254T4/M56 swap.
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
    25. #93
      Aug 2018
      This looks odd. The bearing doesnít seem centered.
      [IMG][/IMG]
      [IMG][/IMG]
    26. #94
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Im seeing marks like the throwout bearing seized and the clutch skidded on it.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    27. #95
      Aug 2018
      The throwout bearing is not seized but Iím not sure if itís the correct one. The M56 and t/o bearing are from a P1. The flywheel, clutch and pressure plate are from a P2. I ordered a new t/o bearing-slave for a P2 M66. The outer diameter of the P2 throwout bearing is larger than the P1 but the throw is shorter. I ordered a slave cylinder for a P2 M56 to see how that compares. Maybe the slave cylinder had nothing to do with the clutch failure? Surely out of the hundreds of P80 manual swaps, I canít be the only person to use a P1 M56 with a P2 RN.
      [IMG][/IMG]
      [IMG][/IMG]
      The new throwout bearing is not centered either.
      [IMG][/IMG]
      [IMG][/IMG]
    28. #96
      Aug 2018
      Jake decided to do a little engine bay cleaning while we are waiting for parts.
      [IMG][/IMG]
      ......and I decided to add to the Volvo fleet. I know, itís not a P80.
      [IMG][/IMG]
      Ď06 V70R Sonic Blue/Gobi automatic. Future M66 swap.
    29. #97
      Dec 2014
      Connecticut
      My understanding was that the slave should always match the trans and the overall stack height of the clutch/fw remains the same despite the different configurations.
    30. #98
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      NICE!!
      [IMG][/IMG]
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    31. #99
      Aug 2018
      Quote Originally Posted by ScottishBrick View Post
      Thanks! Thatís exactly the info I was looking for.
    32. Remove Advertisements
    Similar Threads
    1. XC90 V8 Swap Project AKA The Swedish Whale
      By jcdillin in forum XC90 (2003 - 2014)
      Last Post: 06-16-2020, 08:26 PM
    2. 2015 XC70 AWD 3.2L Platinum or AWD T6 Platinum, with similar price?
      By laughers in forum V70 & XC70 (2008 - 2016)
      Last Post: 05-28-2015, 02:59 PM
    3. safe and sound aka safe and secure to end any time soon?
      By Psychwarlord in forum V70 & XC70 (2008 - 2016)
      Last Post: 04-15-2010, 10:22 PM
    4. Project Car (aka not the R)
      By FORD420diesel in forum General FWD & AWD
      Last Post: 12-30-2007, 09:06 AM
    5. Replies: 13
      Last Post: 01-11-2002, 11:46 PM
