B30 engine mounts on a 140?
    Results 1 to 7 of 7
      May 2013
      Saskatchewan, Canada
      When I rebuilt my 142, I installed new engine and transmission mounts. From the get go the mounts struck me as being quite squishy allowing quite a bit of engine movement. In fact the transmission mount sheared after 1 or 2 years. I remember that the stiffer B30 engine mounts had been touted as an upgrade; but, the 2005 IPD paper catalogue indicates that the heavy duty B30 mounts do not fit on the 140. In retrospect that strikes me as strange given that the 140 and 160 are pretty close to the same car. I also notice that VP Auto cross lists the B30 hex mount to the 140.
      Given the apparently conflicting evidence, has anybody actually tried the B30 hex mount on a 140 and can confirm that they fit or don't fit?
      Jul 2014
      St. Louis, MO
      I have the B30 gearbox mount on my 142. No issues at all with fitting.
      I think I have standard B20 engine mounts though. Mine didn't look overly squishy when installed. As a matter of fact, they were quite stiff.
      May 2013
      'Real' B30 mounts are quite obvious because they have a hex shaped plate on one side. The B20 engine mounts look very much like the transmission mount with a round metal plate on each side of the rubber mount. I have seen the normal 140 B20 engine mounts cross listed in application guides as being suitable for the B30. Got me to thinking that perhaps the real B30 mounts do fit the B20 on the 140.
      Jul 2014
      St. Louis, MO
      My gearbox mount is a "real" B30 mount, with the hex shaped plate.
      I can't remember what is on the engine, but think they are B20 mounts. The B20 & B30 mounts are both round and look the same, but I think the B30 mounts are taller or stiffer for the additional weight.
      May 2013
      All the photos of real B30 engine mounts show the hex shaped plate on one side.
      Jul 2014
      St. Louis, MO
      http://www.vp-autoparts.com/US/main....&artno=1206612
      Shows as "Heavy Duty 140 / 164", and has the hex on the bottom. I would think it will work for you.
      May 2013
      "There be the rub"
      IPD said in the 2005 catalogue that the B30 mounts were a no fit on the 140; but, as I noted in my first post VP does cross list them for the 140. However, as has been noted on this forum before, VP has had some errors / issues with there product listings. I was wondering whether anybody has actually fit the B30 engine mounts on a 140 successfully.
    10. Remove Advertisements
    1. Volvo B18 - B20 - B30 - 544 - 122s - 140's - P1800 Swedish Mechanical Fuel Pump 1963
      By senginc in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 12-19-2018, 08:28 PM
    2. WTB: Volvo B30 engine
      By capitolaxc90 in forum Want Ads
      Last Post: 01-24-2016, 10:57 AM
    3. Replies: 19
      Last Post: 03-10-2014, 06:11 PM
    4. Replies: 8
      Last Post: 03-05-2014, 06:30 AM
    5. Polyurethane mounts for square shaped upper engine mounts?
      By iLLEST-R in forum R Forum (2004-2007)
      Last Post: 08-15-2011, 08:31 PM
