A required field called ip is missing or has an invalid value.
    Results 1 to 7 of 7
      May 2019
      I am getting pretty frequently the error shown above.
      It happens almost randomly regardless of the browser I am using on my iPad running 12.4
      I did a search online and it seems to be a known issue with v.bulletin but I could not find any solution.
      The weird thing is that I am a member of other forums using v.bulletin and don’t have the issue with them.
      Does anybody know how to fix it?
      TIA
      Jun 2019
      Probably better off sending this to the Swedespeed staff.
      In the meantime though I would recommend clearing your browser's cache, and see if that helps.
      Junior Member RootDKJ's Avatar
      Jul 2010
      North Jersey
      I see this on my iPad a lot too. I usually switch to Tapatalk when it happens.
      May 2019
      Quote Originally Posted by ssskelton View Post
      I cleared the cache and did not help.
      How do you contact the site's admins?
      Junior Member skibum50's Avatar
      May 2017
      Northern Kentucky
      Quote Originally Posted by Lalin View Post
      At the bottom of every page is a "Contact Us" link. That will do the job.
      2018 XC60 Momentum T8 (OSD March 2018)
      Apr 2015
      Pittsburgh, PA
      I just submitted this link to the admin and tech support. It's an ongoing issue which they are working to correct.
      2006 XC70
      Previous: 2006 S60R, 1999 F250 Powerstroke, 2005 TSX, 1997 Bonneville, 1998 Concorde
      May 2019
      Quote Originally Posted by R-Pow3R3d View Post
      Thank you as well as skibum
    10. Remove Advertisements
    1. Invalid Media Error Message
      By volvobuff in forum S90 & V90, V90CC (SPA: 2017 - )
      Last Post: 11-25-2017, 01:17 PM
    2. Security Certificate Invalid????
      By HiPSI in forum The Suggestion Box
      Last Post: 11-04-2013, 01:54 PM
    3. APC Softloader - Invalid serial number?
      By benrpd in forum S40 & V50 (2005-2012)
      Last Post: 09-14-2013, 11:28 AM
    4. new IP test
      By darell in forum Testing Forum
      Last Post: 09-11-2001, 02:16 AM
