Performance brake pad recommendations please.. - Page 2
    Page 2 of 2 FirstFirst 1 2
    Results 36 to 43 of 43
    1. #36
      Jul 2015
      OP, Kansas, USA
      Quote Originally Posted by mylesph1 View Post
      Do you have an R? Or do you already have the bigger brakes and carriers to fit the 330mm rotor?
      I have a 2006 V70R.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Iím seeing that, but donít see how Iíd go about buying the parts to accomplish it. Are the calipers replaced, or is it just rotors and the carriers?
      Thanks for always chiming in with your experience
      Calipers, rotors, pads, lines. Itís effectively base Xc90 brakes.
      If you were looking for 305mm brackets which is just a bracket/rotor change thatís super easy. I can easily get a set of those used for you
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    4. #38
      Sep 2009
      Los Angeles
      Quote Originally Posted by ScottishBrick View Post
      Iíll see how this setup works. If I still feel like they wonít cut it, I may order some 305mm rotors and take you up on that. Might also see if there are any XC90ís from that generation sitting at the pick n pulls and grab parts from that, but I doubt theyíre lying around.
      Thanks again
      Ď07 S60 2.5T
      SwedeSpeed.com
      Member
      Apr 2015
      So Cal / Inland Empire
      I monitor the local LA and Inland Empire LKQ yards via their app and there's at least an XC90 or two that roll through weekly... I watch Sunland, Monrovia, Ontario, Fontana and one in the Santa Fe Springs area...
      Sent from my Huawei Mate 9 using Tapatalk
      2004 S60 2.5T - Stock for now...
    7. #40
      Sep 2009
      Los Angeles
      Quote Originally Posted by Phixion View Post
      Okay cool, Iíll keep a lookout - havenít logged into LKQ in a while so Iíll see whatís around.
      Ď07 S60 2.5T
    8. #41
      Jul 2015
      OP, Kansas, USA
      My new Stoptech rotors.
    9. #42
      Jul 2015
      OP, Kansas, USA
      Quote Originally Posted by Fmfosnacht View Post
      And Akebono ceramic pads.
    10. #43
      Sep 2009
      Los Angeles
      Well, that certainly looks effective!
      Finally put some decent break-in miles on mine, Iíll see how they do this week with some harder stops.
      Ď07 S60 2.5T
    11. Remove Advertisements
    Similar Threads
    1. ok I need some performance brake pad recommendations
      By mmustangsrus in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 04-25-2017, 07:24 PM
    2. Control Arm Bushing and Brake Pad Recommendations
      By GiRaff3 in forum R Forum (2004-2007)
      Last Post: 02-20-2008, 05:04 AM
    3. S60R Brake Pad Recommendations
      By boiler92 in forum R Forum (2004-2007)
      Last Post: 11-27-2007, 11:41 AM
    4. brake pad recommendations
      By bfavre4 in forum S60 (2001-2010)
      Last Post: 09-29-2006, 10:00 PM
    5. what type of brake pad R uses for OEM pad? Ceramic/Carbon/Metallic?
      By stevectsai in forum R Forum (2004-2007)
      Last Post: 10-03-2005, 08:06 AM
