How Noisy is Your XC60 T5 at Idle?
    Results 1 to 18 of 18
      Mar 2019
      I purchased an XC60 T5 but am very disappointed with the amount of engine noise in the cabin. The demo car did not seem to have that much noise, and the dealer has tried numerous things but not been able to help.
      I was curious; what are people's noise readings at idle. After the car is warm I get between 47db-48db at idle if I read the meter from the drivers seat right in front of my face. What are others getting? According to this website...
      https://www.auto-decibel-db.com/
      Even the D4 at idle should be around 43db.
      Thanks
      Ray
      Member Oceans60R's Avatar
      May 2008
      Charlotte, NC
      They are somewhat noisy. It is a Direct Inject engine and sounds very similar to a diesel. There are acoustic damping covers to help reduce the sound/noise but they are much louder than any previous non-direct injected engine. Considering a quite office is 40db and 50db is backround tv audio and 60db is moderate to quiet, I would say your noise level is a non issue.
      2011 S60 T6 Ember Black/Off Black, P* Tune, TDI-Tuning Box, DO88 Intercooler, IPD DP, Simons Sport Exhaust, IPD rear sway bar, H&R Springs, Bilstein B8's, 19" Polestar Wheels, 90mm Wheel Studs
      Jan 2003
      Music City
      Quote Originally Posted by raeldor View Post
      Thanks
      Ray
      They are noisy! My biggest gripe about this car is the engine is noisy at idle and upon acceleration. The window glass is also thin as you hear everything around you. Perhaps these are some reasons why people are not buying the XC60. September sales numbers are abysmal (-33.9%).
      The current: 2019 XC40 T5 AWD Inscription/Crystal White/Blonde - Adv, Conv, Vision, Heated Wheel & Front Seats, 19" wheels
      2018 XC60, OSD T5 AWD Inscription/Denim Blue/Blonde - Adv, Conv, Vision, Heated Wheel & F/R seats.
      The old: 2001 S60 - totaled, 2003 XC90, 2004 S80, 2005 TSX, 2006 S60, 2009 V70, 2010 S80 - totaled, 2012 C30 T5 OSD-sold but kept it in the family, 2012 XC60 Caspian Blue/Beige, 2015 Hyundai Genesis.
      Dec 2018
      Measured with some random App (that claims to be calibrated 😂)
      T8 inscription ICE idling (T6 like) and A/C off, 46dB on average with some pikes at 51dB
      T8 inscription PURE mode standing still and A/C off, 30dB avg and max 44.
      May 2019
      Thanks
      Ray
      Very noisy! I complained in other posts about its diesel like sound at idling.
      It is certainly by biggest complaint about the car.
      Not only noisy at idling but also a lot of engine noise while simply cruising.
      If this is the way 2 liter turbo direct engines are, it is my first and last.
      Mar 2011
      RI
      Quote Originally Posted by Lalin View Post
      Sorry to hear its your last, I usually spend time trying various cars before I buy, did you not notice prior to purchase?
      Dec 2017
      PNW
      I test drove a T5 and it seems just normal to me. If you feel it is really noisy, try the demo car at dealer. If it is very different, ask them to fix it.
      May 2019
      Quote Originally Posted by Putertech View Post
      I was debating whether to get the T5 or the T6 so I road tested both before leasing the Inscription T5 but truthfully I was focusing more in the difference between the engines. Also my senses were absorbing the beautiful interior and testing how the 20” wheels would feel so I did not pay attention to the coarseness of the engine at idling or simply accelerating it.
      Live and learn.
      May 2019
      Somehow the dealers always manage to determine that everything is “normal”...
      Dec 2017
      PNW
      Then contact Volvo customer support and see what they say.
      Mar 2019
      My issue is similar... At it's noisiest, a sound meter over the dash registers 52db which is WAY too noisy. My local dealers did a lot trying to fix the problem, bless them, but to no avail. However, I have isolated the sound to when seems to be vibration being carried by the upper torque rod (engine mount). When I loosen the nut on the rod the noise goes away. When I tighten it again it comes back. There's actually an 'oscillation damper' on that arm too, so this is obviously a known issue. When I remove that the noise gets worse, and when I put it back it gets better, but even in the 'better' state it's still too noisy. I tried contact Volvo Customer support by email numerous times but received no reply.
      Member rumyn's Avatar
      Dec 2015
      New Jersey
      Interesting.
      My torque rod was recently replaced in order to try and fix the vibration (the rod was worn out). Car was not noisy at idle before that.
      Now, with the new torque rod it's noisy as hell, and the vibration is a lot worse too.
      His: Osmium Grey - 2019 S60 T6 R-Design AWD, Polestar, Advanced, 19" wheels, Heated Steering Wheel & Rear Seats
      Hers: Onyx Black - 2019 XC60 T6 Inscription AWD, Maroon Brown, Advanced, Luxury, 20" wheels, Heated Steering Wheel & Rear Seats
      Lemon Law Buyback thread
      Oct 2019
      They are a bit noisy. It is a Direct Inject engine and sounds the same as diesel. Acoustic damping covers prevent the sound/noise to an extent but they are much louder than any previous non-direct injected engine.
      May 2014
      Queens, NY
      Weird, I find our new 2019 T5 serenely quiet compared our 2016 T5 XC90 ... same engine but clearly better cabin sound insulation than the 90 had.
      Oct 2019
      I have a brand new 2020. My wife thought it is a diesel car. Lol.
      Mar 2019
      Quote Originally Posted by rumyn View Post
      Interesting.
      That's interesting. It's 100% true that with the torque rod disconnected the noise in the cabin goes away completely. I wonder if this is something where the torque rod needs 'wearing in' to provide better sound insulation?
      Jul 2005
      Atlanta, GA
      Ours defenitely sounds like a diesel. We traded our Q7 TDI diesel on the XC60, and the Q7 was quieter!!
      Mar 2019
      So, I found a solution. Firstly, let me say this will only work in the case where the noise is coming into the cabin via the upper torque arm. You can check this by loosening the nut shown here (you will need to remove the oscillation damper above it).
      If the rattling sound in the cabin at idle goes away when doing this, then this solution may work for you too. Basically you need to order a second oscillation damper (about $100). It's held on by an M6 bolt. I purchased a longer (65mm) M6 bolt, a nut, and two large 22mm M6 washers. I then affixed the damper to the torque arm directly using the two of the two slits on the torque arm. The slits are quite big, so I used the two washers either side, so it's... damper -> washer -> torque arm -> washer -> nut. Then I tightened it on. It looks like this when done...
      This second damper on the arm itself (rather than the mount the arm sits in) seemed to lessen the vibration enough that the rattling sound in the cabin at idle has gone away.
      If anyone else gives this a try, or is even able to isolate their sound to the torque arm by loosening the nut, I'd be very interested to hear.
    21. Remove Advertisements
    1. Noisy vs. quiet tyres - your experience ?
      By Ivos in forum XC90 (SPA: 2016 - )
      Last Post: 03-21-2016, 12:50 PM
    2. '10 V50 T5 Noisy manual transmission
      By summitv50 in forum S40 & V50 (2005-2012)
      Last Post: 06-26-2010, 01:41 PM
    3. how noisy is your fuel pump?
      By lodi1800es in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 12-29-2009, 10:01 AM
    4. are t5's normally noisy?
      By 1sikhpt in forum General Volvo Discussions
      Last Post: 05-14-2007, 02:55 PM
    5. Are Your Fuel Injectors THAT Noisy?
      By Mr. Kotter in forum XC90 (2003 - 2014)
      Last Post: 12-05-2004, 12:55 AM
