1998 v70 t5 build - white reaper
    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 35 of 150
      Oct 2019
      phoenix, az
      hey everybody - fairly new to the volvo scene but have been browsing the forum for a few years now. first got introduced to volvos by my girlfriend who had a sweet 850r back in the day that she never stops talking about! i never got to see it in person because she traded it for a lexus before we met, but just talking about it got me pretty hyped about getting my first volvo project.
      so about four years ago i bought a 1998 V70 T5 with 140k miles for $1500 out in CA. it was bone stock, original white paint, had a loud squeak coming from the passenger front side, but other than that in great condition. the owner said his daughter drove it in college and he didn't have much need for it anymore. plus the dealership quoted him way too much $$ to find out the issue and fix it, so he was ready to deal it for a low price! got it home, replaced the tie rod and bushings, problem solved for like $30 in parts. score!
      this build thread is starting like mid-build because i've already done a few things over the past couple years - lowering springs, rims/tires, tint, paint, and some minor mechanical fixes. but i've decided to turn it into my daily driver, so i'll be upgrading a few things in the next month or so and wanted to document my progress!
      future plans aren't too crazy but include:
      *k&n intake
      *silverstar ultra headlights
      *bilstein shocks
      *msd ignition
      *bosch distributor cap/rotor
      *genuine volvo plugs
      *bougiecord spark plug wires
      *brakes - rotors/pads
      *engine mounts
      *turbo boost gauge
      general maintenance:
      *oil/filter
      *cabin air filter
      *serp belt
      *coolant hoses
      *fuel filter
      *water pump/tstat
      *brake fluid
      *trans drain/fill
      *inspect turbo
      *pcv system
      *parking brake
      *anything else i find along the way
      i'm going to need some help along the way, and i'm open to all ideas and suggestions. so please follow and comment! current pictures to come shortly!
      Dec 2015
      SLC Utah
      Quote Originally Posted by gr1m_reaper View Post
      Welcome to the forum. Your pictures didnt seem to load. Try uploading them to a site like imgur.com The copy the BBC code option and paste the links.
      01 S60 T5M Black, middle sons
      00 S70 GLT Black, youngest sons
      00 S70 GLT5 SE Moondisaster, T5 Swap
      00 V70R Black, First P80 Wagon
      01 E46 325 XI Touring Silver, Wifes, totalled, bought back, repaired
      Oct 2019
      phoenix, az
      Oct 2019
      phoenix, az
      Oct 2019
      phoenix, az
      Quote Originally Posted by UT OLI View Post
      Thank you! Still getting the hang of it!
      Dec 2015
      SLC Utah
      No worries, a lot of knowledge here to help you along the way. You may not get a ton of responses to you questions, but the responses you get will be sound from hardcore enthusiasts
      Dec 2015
      SLC Utah
      And you may want to update your profile on where you live, helps locating local guys you can network with
      Couple suggestions.
      Skip the K&N intake the maf doesnt like the oiled filter. A snabb intake pipe and a good stock filter is the proper upgrade.
      E codes or jewels for the headlights bot of which do very well with LED
      302mm brakes
      e
      2003 V70 T5 - Mystic/Graphite - M56LK - 210k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 304k - Daily/Work Wagon
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      Oct 2019
      phoenix, az
      Couple suggestions.
      302mm brakes
      e
      ah man, i've already got the k&n intake and stock size brakes. will the k&n for sure have problems?
      It will kill the maf with the oil from it
      Member washdup's Avatar
      Apr 2007
      Ventura County, CA
      Not my experience, but I alternate filters, allowing plenty of time for the oil to evaporate before use. Just don’t over-oil.
      1998 V70 T5m @200k miles; 18t, turboback, Quaife LSD, Koni FSD/Eibach, IPD sways, DO88 I/C, SNAAB intake, ARD Blue, greens, etc., 50% E85
      1995 850 Turbo Sold at @168k miles.
      2004 V70R 6mt SOLD in 2008
      Oct 2019
      phoenix, az
      Quote Originally Posted by washdup View Post
      appreciate you sharing your experience - i've had k&n filters in every other vehicle i've owned and never run into any issues. but, this will be the first volvo, so i got kind of nervous when hearing it may cause maf problems. i'm happy to hear it should still work as long as i make sure not to over-oil!
      Oct 2019
      phoenix, az
      OK so getting started this weekend! here's the plan... since i need this car to be my daily driver sooner rather than later, i'm going to start with everything that makes it run/drive safely. it has basically just been parked in the garage and rarely driven the past couple years, so i'll need to go over everything mechanical first before starting any aesthetic mods. i started my own checklist, but if anyone has some suggestions on what else to specifically look at, please chime in!
      *replace fluids - oil, trans, coolant, wiper, power steering, brakes, a/c, fuel
      *replace filters - oil, fuel, air, cabin
      *replace plugs, wires, distributor cap/rotor
      *replace timing belt, tensioner, pulleys, serp belt
      *replace brakes - rotors/pads
      *check/replace hoses - radiator upper/lower, pcv system, turbo lines, oil cooler, coolant reservoir, brake lines
      *check/replace mounts - engine/trans
      *check/replace oil pump, fuel pump, water pump, tstat
      *check/replace steering components - inner/outer tie rods, cv joints, boots
      *check/replace gaskets & o-rings
      *general cleaning under the hood
      Oct 2019
      phoenix, az
      Finally got my workspace all organized and ready to get started. Always seems like there are multiple projects before even starting THE project.
      Oct 2019
      phoenix, az
      Oh boy... I've got my work cut out for me. Stupid Arizona dust storms... Only left the car outside a few different times! Gonna need some serious cleaning in addition to everything else.
      Oct 2019
      phoenix, az
      First of many knuckle-busters.. I don't understand how people can wear gloves while working under the hood. I've tried so many different kinds and they always seem to get in the way. Anyone have a pair they really like?
      Oct 2019
      phoenix, az
      Got the valve cover off and noticed some fluid. Would that be a leak or over-poured engine oil that seeped down in there?
      Oct 2019
      phoenix, az
      Removed the battery/tray, air filter assembly and air ducts, turbo pipe, and upper rear engine mount. Also, got some cleaning done. Didn't have a lot of time today but got a good start.
      Got parts on the way to get me going:
      -pcv kit
      -distributor cap/rotor
      -plugs/wires
      -fuel filter
      -cabin air filter
      Oct 2019
      phoenix, az
      does anybody have any feedback on the upper engine mount (poly vs rubber) ? i'm not a fan of engine vibration, so i'm leaning towards sticking with rubber, but open to suggestions, pros/cons
      Rubber and get the right p80 mount that’s round. 8649597
      https://www.eeuroparts.com/Parts/588...-Upper-524824/
      Dec 2015
      SLC Utah
      That oil leak should be from the rubber seal on the oil filler cap. Nothing to worry about. Get a new one.
      Oct 2019
      phoenix, az
      perfect - thank you!
      Oct 2019
      phoenix, az
      That's what I was thinking - got a rubber seal on the way. Thanks!
      Apr 2007
      Ventura County, CA
      On my T5M I see no difference in vibration between rubber and poly, but the rubber ones do not last very long at all. You have an automatic? (It would help if you had a signature with your car's specifics.)
      Oct 2019
      phoenix, az
      great idea - how do i add a signature ??
      Apr 2007
      Ventura County, CA
      Settings tab
      Oct 2019
      phoenix, az
      i only have one car in my signature (so far)....
      1998 V70 T5 - Arctic White/Beige - AW42 - 169K
      Dec 2015
      SLC Utah
      You'll get there, its a disease, very infectious and mostly incurable
      Oct 2019
      phoenix, az
      you're right - in fact, now that i've started working on the v70, the ol' lady is wanting to get a volvo again!
      Oct 2019
      phoenix, az
      working on the car again tonight and wondering what all i should check without pulling the engine?? i don't know a ton about volvos (yet) but i'm good at following instructions! anything specifically i should check for to make sure it will stay a good daily driver?
      Jun 2012
      Tidewater, VA
      Truth.
      ’98 S70 GL, '06 S40 M66 T5 FWD, '08 C70 M66 T5 Premier Plus, '11 XC90 V8 AWD, '13 C70 T5 Platinum P* ('94 854T, '05 S60 2.5T FWD, & '04 XC90 2.5T AWD R.I.P.)
      Current Fleet:
      1998 S70 Base (New project), 2006 S40 T5 M66 FWD, 2008 C70 Premium Plus M66, 2011 XC90 V8, 2013 C70 Platinum P*
      RIP:
      1994 854T FWD, 2004 XC90 2.5T AWD, 2005 S60 2.5T FWD
      Jun 2012
      Tidewater, VA
      Take a good hard look at the power steering system. Maybe your PO’s college driver knew the difference and always used ATF, but the PO of my S70 clearly didn’t and blew all the seals on the rack. Scottish and others may have good advice on how to check the ABS module before its likely demise (prone to fail and also on my to do list).
      BD
      Current Fleet:
      RIP:
      Oct 2019
      phoenix, az
      should i replace the power steering fluid?
      Jun 2012
      Tidewater, VA
      I know the manual says “no fluid change required,” but if you’re unsure whether the PO(s) ever put normal ps fluid in instead of ATF, I would. To be doubly safe, I know a few owners use the Valvoline MaxLife Transmission Stop Leak in lieu of ATF. My seals are too far gone for it to fix my problem, but it certainly did reduce the leaks.
      BD
      Current Fleet:
      RIP:
    37. #35
      Oct 2019
      phoenix, az
      i haven't noticed any leaks yet, but i'll take a closer look when i get under the car this weekend
    1. Replies: 17
      Last Post: 10-04-2013, 12:14 AM
    2. 1998 V70 T5 auto. White with charcoal interior Powhatan, VA
      By slo2gdsm in forum FWD & AWD Cars For Sale
      Last Post: 07-15-2012, 01:36 PM
    3. Converting a 1998 V70 awd GL (automatic) to a 1998 V70 T5 (manual)
      By 300zx in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-27-2009, 10:47 AM
    4. 1998 V70 T5 5 speed White/Tan
      By JRL in forum FWD & AWD Cars For Sale
      Last Post: 02-28-2008, 06:02 PM
    5. 1998 VW Conv. white/white edition, 5 speed
      By JRL in forum Non-Volvo Cars For Sale
      Last Post: 04-10-2007, 04:30 PM
